Possible NVIDIA GeForce RTX 3090, RTX 3080, and "TITAN Ampere" Specs Surface
14,992 (6.67/day)
Midlands, UK
Cooling be quiet! Dark Rock 4
Case Kolink Citadel Mesh
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
As someone who is finally looking to upgrade after 5-6 years, the amount of blue balling going on here is really getting on my nerves. Just release the friggin' specs and a expected shipping date. Absolutely ridiculous, this whole charade.
Agreed. What's the point in speculating anyway? We get what we get, that's it.
Btw, if these are real specs, I suspect a Ti or SUPER version coming for each tier later on, as none of these specs seem to operate with fully enabled GPUs. But using the same GPU for 3 tiers seems unlikely to say the least (unless production is really that bad).
3,059 (0.78/day)
Mouse Razer Abyssus
Software Ubuntu
If Ampere features "GDDR6x", we should see these memory chips launching sometime before the graphics cards.
I will not focus on speculating on precise clock speeds or SM count, I believe this is a new major architecture, totally rebalanced and changed caches, so it will be hard to predict its performance characteristics.
But I do think memory bandwidth will be a deciding factor of how well these new cards scale. I saw some of the latest speculation about Navi 21 featuring 448 bit memory at 21 Gbps… It will be interesting to see how well that could be implemented.
142 (0.04/day)
System Name Avell old monster - Workstation T1 - HTPC
Processor i7-3630QM\i7-5960x\Ryzen 3 2200G
Cooling Stock.
Memory 2x4Gb @ 1600Mhz
Video Card(s) HD 7970M \ EVGA GTX 980\ Vega 8
Storage SSD Sandisk Ultra li - 480 GB + 1 TB 5400 RPM WD - 960gb SDD + 2TB HDD
oh,huge hardware scores, alot, when we remembe ,ampere is 7nm,so clocks are much higher than usuall... i say put 250mhz easily more basic hz than usuall and then add oc'd capacity alot more.
also,seens nvidia leave bank alot cores,near 3000! max cores numbers are over 8000,yes, you read right.
big navi.. i seen it again...errh, and it cant get even near rtx 3090...what dream world some2 live?
amd cant beat now even 12nm rtx 2070 super OC gpu, and then its still must beat its four big brother..,there is enough to job legendary big navi.
also, we all KNOW fact that big navi is still 7nm gpu with nothing new special upgrade...remembe this, i bet that big navi is watercooled gpu....still i cant belive it, these days..
sure im sure it should beat now old 16nm gtx 1080 ti OC gpu..hmm, must...but remembe check it tdp and efficiency.
well 'my' leak it small, and i warn amd fans,dont except it anyhting what it CANT be, rtx 3070 is too much it.
anyway,competition is always good,you will seen both september and october. nvidia and amd.
btw, i wait also intel high end gpu...exiting...
great weekends all!
If you're not a bot, you should try to better organize your ideas. To expect any competition from intel in the GPUs market is to be, at least, misinformed. AMD and Nvidia holds tons of patents on everything GPU-related, 3D rendering and etc..
@topic 4GB should be enough for low-end GPUs. but for the 4K+ market considerable Vram upgrades will be required.
ppn
1,231 (0.35/day)
If there is GDDR6X, we have to wait for the real GDDR7. not this half baked immitation.
  • Haha
Reactions: bug
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.38/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
If they really do come out the door with an RTX 3090, NVIDIA is concerned about Sienna.
144 (0.07/day)
Yeah, but it's coming from AMD, not Nvidia. Even 5500XT had 4 GB. I'm not purposefully defending 4 GB as games will continue to climb in min. requirements with bigger VRAM capacities, but for 1080p 60 FPS the 4 GB will remain a standard till Hopper/RDNA3 or RTX 5000/RDNA4. The simple reason is most low-end users whom the 4 GB is aimed at won't really stand a chance at acquiring 6 GB or 8 GB midrange cards (sure, we could say 5500XT is low end with 8 GBs, but other specs are bottlenecking performance) and unless AMD and Nvidia produce 1650 Super like card with 6 GB VRAM, I don't see a viable reason for 4 GB to vanish yet.
Low quality post by ARF
Low quality post by cucker tarlson
7,412 (2.67/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
71 (0.04/day)
I hoped for something better.
The switch from 12/14nm to 7nm should allow twice the number of CUDA cores at the same clock speed and TDP, and roughy the same size. 20% extra doesn’t seem like much. If this is true, we will get significantly smaller chips than last gen or maybe nVidia used the extra space for more RT cores. I am not sure how I feel about that, when we haven’t even reached 4k at 120Hz. Even 3440x1440 at 120Hz can’t be done at max settings in most modern games on an RTX 2080 Ti.
19,378 (3.49/day)
There's also 'IPC' improvements to be had with the move to a new architecture.
4K 120 Hz? There are literally a small handful of those monitors around and are cost prohibitive to most in the first place. I think more would rather see a performance improvement in RT (which everyone can use) than seeing 4k/120 come to fruition in this generation.
23,477 (6.13/day)
Nah man more X is always more better.
14,992 (6.67/day)
Midlands, UK
Who needs 4k/120 Hz anyway? Even 120 Hz alone at any resolution is something only a handful of gamers will ever need. I personally think the advantage over 60 Hz is just placebo.
That's why Intel processors are not as interesting as they used to be. They're still stuck with K, while AMD switched to X years ago.
152 (0.06/day)
If the 3070 gives 2080Ti performance and doesn't cost over $600 I may actually upgrade from my 980Ti.....I'm thinking I won't be that lucky, on the price, that is.
It’s a nice thought, but never gonna happen. The only thing that will beat a 2080ti in their new lineup is a 3080ti. Its the Nvidia way...
ARF
4,670 (2.50/day)
Ex-usa | slava the trolls
Intel can pay royalties to use the aforementioned patents - it's never an obstacle. Also, Intel has so large man power that they can literally discover their own things and still be very competitive. It hasn't been their priority, though.
Also, Intel can cross-agree with AMD the use of that IP, which they have already done.
71 (0.04/day)
Yes, and there will be some clock speed improvement as well, but even if we can get to 120Hz at 4k in current gen titles, it may not be enough next year (or in CP 2077 - edit: or in any Assassin’s Creed game).
As for who needs 4k at 120Hz - plenty of tvs support it, 27” 4k monitor prices are getting lower and lower too (looking at the EVE Spectrum - I paid a similar amount for a 27” 1440p 60Hz IPS monitor 9 or 10 years ago). I don’t think it is outrageous to think that in 2020 someone who pays $1000+ for a graphics card will want to pair it with a high refresh rate 4k or ultrawide monitor. Why else would you spend so much on a graphics card?
ARF
4,670 (2.50/day)
Unfortunately, the 4K monitors prices are not getting lower. They keep the same level for dozens of months. The cheapest 4K monitor is around 230 euros, while the cheapest 1080p monitor is around 60-70 euros. This is an extremely strong prices dumping by the 1080p monitors manufacturers and it effectively distorts the whole market. And stops the innovation and progress.
5,730 (0.98/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
I still think for high end gpu's like 3080 and up minimum memory 16gb, if this is true, 10gb, disappointed.
I just wish HBM was more of a thing, maybe in some sort of combo thing to keep cost down, but then with games etc being programmed with the faster memory in mind.
76 (0.04/day)
Save you wallet for 5nm. as amazing this is, I mean 7nm 65.6Mtr/mm2 jump from 14nm 25Mtr/mm2, shrinks 2080Ti under 300mm2. ffs it is just the beginning. And you don't want to be unprepared when it happens. Yeah there will be 3080, and 3080Super, and then 4080, the right time to buy is with 4080Super, or 5080 even. or 3-4 years from now. Now you can take 3070 or something under 399 if it performs like 2080Ti.
Problem is humanity hasn't invented cryogenic sleep yet...so what are you going to do during 4 years? ;)
4K TVs are already invading our living rooms from quite a while with no juice for feeding them
bug
14,193 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
You probably forgot Turing dies are at the size limit of what 12nm manufacturing allows. That's really not where you want to be, if you can help it ;)
397 (0.22/day)
Antares
System Name BloodRage
Processor R5 2600X PBO enabled
Motherboard Gigabyte Aorus B450 Elite
Cooling Arctic Esports Duo
Memory 16GB Corsair Vengeance 3000
Video Card(s) MSI VENTUS OC 2060 Super
Storage 120GB PNY SATA + 1TB WD Blue M.2
Display(s) Samsung CRG5 144hz QD
Case CiT cheap chassis
Audio Device(s) Creative Audigy FX
Power Supply Superflower Leadex III Gold 650w
Mouse Razer Basilisk
Keyboard Red Dragon Kumara
Software Win 10
You would actually have to be blind to not notice a difference between 60 & 120hz.
3,984 (1.09/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
Have you spent any serious time with 120+hz? I used to say the same thing until I bought it. 165+hz, not really worries about it.
2,881 (1.15/day)
So much speculation going around these days. It feels like AMD and Nvidia themselves are participating in the misinformation.
Anyways, these some of the least credible specs that I've seen.
This.
The competition for next gen is going to be so fierce neither one wants to play it's hand and I have no doubt both are leaking fake specs. Even the decision of who will release first will be causing great angst in AMD and Nvidia.
MxPhenom 216
ASIC Engineer
13,134 (2.47/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
:laugh: You better sit this one out.
238 (0.05/day)
Processor 3700X
Motherboard X570 TUF Plus
Cooling U12
Memory 32GB 3600MHz
Video Card(s) eVGA GTX970
Storage 512GB 970 Pro
Case CM 500L vertical
Just like anyone can just pay royalties for x86... wait! They can pay for lawyers as Intel sues the living daylights out of any company silly enough to even consider that.
