Post the power consumption of your desktop setup (including display)
952 (1.08/day)
Total power consumption of desktop setup (including display): 49.5 watts
Components:
Intel 12700KF (stock) -- G.SKILL RIPJAWS @3600 CL18 (stock) -- Sapphire RX 7600 -- ASRock B760M-ITX/D4 WiFi -- fractal design DEFINE NANO S -- ARCTIC F14 (intake fan) -- Fractal Design Dynamic GP-14 (intake fan) -- RF120W (CPU fan) -- RF120W (exhaust fan) -- bequiet! SYSTEM POWER 10 550W -- DeepCool AG500BK ARGB (with custom fan) -- EVO 850 500GB
= 42.5 watts power consumption
Display: HP 24fh (set with very low brightness because otherwise I get eye problems with IPS screens)
= 7 watts power consumption
Energy consumption meter: QUIGG GT-PM-05
You are supposed to measure it via a reliable energy meter similar to my QUIGG GT-PM-05.
Please also mention the specs of your components and display.
770 (0.13/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
Total power consumption of desktop setup (including display): 74.2 watts
Components:
Intel 3770K (overclocked to 4.5 GHz) -- 2x G.Skill F3-2400C10D-16GTX (stock) -- EVGA GTX 1080 (power modded) -- ASRock Z77 Extreme4 -- Custom water cooling, water pump, and Delta fans (fans off with low load and pump RPM low with low load) -- Seasonic PRIME 600W Titanium -- Samsung 850 Pro
= 46.8 watts power consumption
Display: Samsung 28" UE590 UHD (normal/default bright brightness)
= 27.4 watts power consumption
Reduced display brightness: 13.9 watts, and total consumption: 60.7 watts
P3 Kill A Watt (P4400.01)
120 volt outlets are not as good for switch-mode power supply efficiency for products designed for a global market. :shadedshu:
314 (0.20/day)
Texass
System Name EXTREME-FLIGHT SIM
Processor AMD RYZEN 7 9800X3D 4.7GHZ 8-core 120W
Motherboard ASUS ROG X670E Crosshair EXTREME BIOS V.2506
Cooling be quiet! Silent Loop 2 360MM, Light Wings 120 & 140MM
Memory G. SKILL Trident Z5 RGB 32MBx2 DDR5-6000 CL32/EXPOⅡ
Video Card(s) ASUS ROG Strix RTX4090 O24
Storage 2TB CRUCIAL T705 M.2, 4TB Seagate FireCuda 3.5"x7200rpm
Display(s) Samsung Odyssey Neo G9 57" 5120x1440 120Hz DP2.1 #2.Ulrhzar 8" Touchscreen(HUD)
Case be quiet! Dark Base Pro 900 Rev.2 Silver
Audio Device(s) ROG SupremeFX ALC4082, Creative SoundBlaster Katana V2
Power Supply be quiet! Dark Power Pro 12 1500W via APC Back-UPS 1500
Mouse LOGITECH Pro Superlight2 and POWERPLAY Mouse Pad
Keyboard CORSAIR K100 AIR
Software WINDOWS 11 x64 PRO 23H2, MSFS2020-2024 Aviator Edition, DCS
Benchmark Scores fast and stable AIDA64
My APC Back-UPS 1350 reports 170W~197W. Air-Cooled 5950X, Hero Ⅷ, 128GB GSkill, RTX3090 OC @ 46C°
576 (0.29/day)
Hungary
System Name Detox sleeper
Processor Intel i9-7980XE@4,5Ghz
Motherboard Asrock x299 Taichi XE (custom bios with ecc reg support, old microcode)
Cooling Custom water: Alphacool XT45 1080 + 9xArctic P12, EK-D5 pump combo, EK Velocity D-RGB block
Memory 8x16Gb Hynix DJR ECC REG 3200@4000
Video Card(s) Sapphire RX7900XT - NITRO+ Vapor-X 20GB
Storage Samsung PM9A1 1Tb + 2x PM981 512Gb + Kingston HyperX 480Gb + Samsung Evo 860 500Gb
Display(s) HP ZR30W (30" 2560x1600 10 bit)
Case Chieftec 1E0-500A-CT04 + AMD Sempron sticker
Mouse Logitech G400
Keyboard IBM Model M122 (boltmod, micro pro usbc)
Software Windows 11 Pro x64
Components: i9 7980 XE (OC 4.5GHz), 8x16GB DDR4 3200 ECC REG (OC 4GHZ), Sapphire 7900XT 20GB NITRO (UV 1075mv + power limit), Asrock X299 XE (custom modded bios), custom water loop 1080 rad, D5 pump, 9x12cm P12 fans, Superflower platinum 750w (normal mode not silent), 3x nvme samsung ssd and 2x sata ssd, 3x case fan, all RGB and light off
Idle 120-160w (and light load/youtube)
Gaming (60hz/60FPS fixed): 360-470w (stalker2 340-360w)
Benchmarking GPU 670w max
Not tested with full cpu and gpu load probably 800-900w so that is little over 100% psu load (750w/0.9 eff 833w but a good brand psu can handle for a short time +10% so ~900w is a full max for a 750w brand psu)
Display: HP ZR30W 30" 10Bit 2560x1600@60hz
120-160w (it is not a led monitor)
Normal brightness.
measured with Powercheck 3000
Power is cheap here in Hungary, I pay 18-20 usd a month (discounted family price).
2,566 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 2X D5T Vario, XSPC BayRes, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Thermaltake Xaser VI
Mouse Logitech
Keyboard Logitech
Software Win11PRO
Sig rig, 235ish.
Monitor off, ~205.
Both UPS and Kill-A-Watt P3 agree.
21,516 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
I measured 120V vs 240V switching efficiency on a pretty excellent seasonic in one of my mining articles. It did not amount to any real meaningful difference, see the first chart:
Please ignore my early misguided crypto advocacy, the stats are still relevant. :)
770 (0.13/day)
Pacific Coast
Mouse EVGA TORQ X10
I measured 120V vs 240V switching efficiency on a decent seasonic in one of my mining articles. I did not amount to any real meaningful difference, see the first chart...
My PSU specs show around 2% better efficiency on 220/240v. I assume that my monitor would be more efficient too, but maybe not if the plug packs are specific, different, and optimized. Hard to say. I just figure that if 37% of my usage is just my monitor, that's pretty bad and there must be an alternative.
I upgraded to this PSU specifically for low load efficiency once I realized that my peak load was within its range. My previous PSU was comparatively terrible during low load.
Edit: yeah, the monitor plug pack is a 110-240 volt plug pack, which means it probably isn't optimized for 120 volts.
21,516 (3.40/day)
System Name Pioneer
Yeah, so did mine but the charts told a different story.
never tested the monitor situation though.
1,655 (1.07/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
When idle the desktop in my profile uses about 57 W for the system unit, out of which the CPU is 28 W, the GPU 6 W, and the rest of the system is 23 W.
The 28 W of the CPU's power usage is 0.5 W for the cores, 13.5 W for the SOC and 14 W for the interconnects. The SOC consumption is quite high because I'm running 4 sticks of RAM at 3800 MT/s with very tight timings.
My 4K60 monitor is set to 10% brightness and 33% contrast and uses about 15 W in idle and 21 W when gaming.
Speaking of, I mostly play older titles. They usually run in 4K60 maxed out with the GPU limited to around 145 W through UC and UV. With the CPU consuming less than 60 W most of the time, my typical gaming load must be under 250 W for the whole system.
The highest momentary power usage I've seen when benchmarking with uncapped frame rate was 502 W.
Measured with a Voltcraft Energy Check 3000 meter.
394 (0.82/day)
System Name No.1
Processor Ryzen 9 9900X with custom PBO + 2200 FCLK fully stable
Motherboard B650 Gigabyte Aorus Elite v1.0
Cooling Thermaltake toughair 710 + Thermal Grizzly Kryonaut extreme
Memory Patriot Viper PVV532G740C36K @ 6200MT/s 30-36-36-63 1:1
Video Card(s) Asus TUF gaming RX 7900 XTX OC edition
Storage 1TB T-Force Z44A7 + 2TB T-Force A440 Pro
Display(s) 34 " Asus TUF Gaming VG3A series
Case Antec C8 constellation white edition
Audio Device(s) Asus Xonar AE 7.1 + Logitech Z906
Power Supply Corsair RM1000x V2
Mouse MSI Clutch GM20 Elite
Keyboard Logitech G512 Carbon
Total power consumption of desktop setup (including display);
Approx 145 watts - idle at the desktop without external connected sound system turned on. (I have permanently disabled windows from down clocking the 2nd CCD on my Ryzen 9 9900X because this is a performance gaming rig only)
169 watts - with sound system turned on (Logitech Z906)
Components: See system specs,
Monitor: 34" VA panel @ 3440x1440 - set to factory preset "Racing" with HDR on.
Energy consumption meter: CCI Pty Ltd PW10A link
Typical gaming load (DX11+12 games only) approx 300 - 590 watts
3,649 (1.70/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Hard to measure, it will be reported as about 108w idle by UPS, but this includes some networking equipment, and PS5 in standby. I will guesstimate about 90-100W.
314 (0.20/day)
Texass
My old jalopy reports 88 watts on the APC Back-UPS 1350.
109 (0.26/day)
Processor 7600x -- 8600k
Motherboard MSI B650 -- ASRock z370
Cooling TR PA120 -- CM212
Memory 2x16GB -- 2x8GB
Video Card(s) PNY 4080 -- Zotac 2080ti
Display(s) LG C3 (42) + Acer XB271HU -- Sony X950H (49)
Case Torrent Compact Steel Panel -- Define R2
Power Supply BeQuiet Darkpower13 750 -- Seasonic X750
Keyboard Epomaker TH80SE/EK21 -- Logi G710+
Software Win10 (both)
System Rig (7600x) w/ 42" LGC3:
90-120w @ idle depending on what the screen is displaying. Everything except my coffee hotplate is plugged into a UPS, were my values are from.
Includes a USB DAC, 80w 2ch amp, and a small 8" 250w sub. Add about 20w with music playing at uncomfortable levels.
Frick
Fishfaced Nincompoop
19,651 (2.86/day)
Piteå
System Name Formula 409
Processor Ryzen 5 7600
Motherboard MSI X670E Gaming Wifi Plus
Cooling Be Quiet! Pure Rock 2
Memory 2 x 16GB Corsair Vengeance
Storage Kingstong XC3000 1T | WD Black SN750 2TB |WD Blue 1TB x 2 | Toshiba P300 2TB | Seagate Expansion 8TB
Case Fractal Design Define R4
Keyboard Dell SK3205
Hovering around 220W at idle, but that is with two lamps, soundbar+sub running and the router.
