Power limits i7 10700
23 (0.02/day)
Hi, I recently purchased a pre-assembled desktop equipped with i7 10700 but when installing throttlestop in the limits window I found power limits on cores and rings.
I bought the pc because I paid little more than the selling price of only processor and gpu but this problem demoralizes me.
I wanted to know if it is possible to do something from the throttlestop settings, although I see that many are blocked. Thank you
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
What are the complete system specs?
Adjusting the power limits in your motherboard's BIOS would be the first thing I would try.
836 (0.60/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
System Name °( ఠ ͟ʖ ఠ)°
Processor Intel | i7 _ 11700K | @ ~ 5GHz all | cooling ~ Thermal Grizzly CARBONAUT
Motherboard Asus | ROG Strix -- Z 590-E wifi
Cooling Asus | ROG Ryujin 240 2* _Noctua F PPC °3000 | 4+1* _beQuiet_ Silent/Light Wings 3 °2200
Memory G Skill | Trident Z *RGB @ 4000_ | _15-15-15-36_ |
Video Card(s) Asus | ROG Strix -- RTX 3070Ti_ #OC Edition
Storage WD black | Samsung EVO 860 / 970 EVO plus| WDC WD40 | Intenso x2
Display(s) Alienware | AW3821DW _ 38" {3840*1600} wide - curved
Case be Quiet | DARK BASE PRO 900 --- _rev. 2 --- #Silver
Audio Device(s) Asus | ROG Throne - Qi_7.1 | LOGITECH_G560 Speaker (RGB)
Power Supply be Quiet | DARK Power PRO 12 __ 1200W *titanium
Mouse Razer | NAGA Trinity (19 buttons)
Keyboard Razer | Huntsman V2 analog | Razer Goliathus (RGB) black
VR HMD Razer | Kraken Ultimate HEADSET __7.1 THX ____| DX RACER - Gaming Leather Chair_____ VR?? is odd!
Benchmark Scores See signature URL
the i7 10700K was the predecessor of my current i7 11700K. I overclocked and did never hit the 1,4V.
Yours should run smoothly @ ~1,2V. max. Approx.
18,584 (2.67/day)
System Name AlderLake
836 (0.60/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
Thermal Velocity Boost is not supported by the CPU.
go to your bios to the maximum Voltage section and set 1,2V. the direct setting on auto and your gucci
in case u'll get problems increase in 0,01V steps until its quiet and happy
23 (0.02/day)
Hello, I have a desktop Acer Nitro N50-610, the specifications are : i7 10700, rtx 3060 12gb manli , 1tb ssd m2, 2 tb hdd, 16gb ram, 500w power supply.
The motherboard is H470 based with american megatrends inc bios. R01-A2.
I have no idea how to make changes from the bios I hope so much they can be made.
Acer Nitro N50-610
Thank you very much I will try this solution as soon as I understand how to access and edit the bios
105 (0.03/day)
The land of maple syrup
System Name not done yet
Processor I5 10400
Motherboard msi h410 pro
Cooling 212 evo, 5x 120mm
Memory patriot viper 2666 ddr4
Video Card(s) xfx rx570
Storage 500gb crucial p5 m2 , 525gb crucial mx300, 3.5 7200 seagate barricuda 2tb
Display(s) 42" 120hz 3d led LG
Case rosewill line
Audio Device(s) onboard realtech 5.1 (yamah rxv373, jamo speakers)
Power Supply thermaltake gx2 600w gold
Mouse logitech m510
Keyboard microsoft
Software windows 10
Benchmark Scores 1410 in un heaven, not useless yet
usually you have to hit f11 or delete on boot to enter bios
23 (0.02/day)
I don't understand much about bios but I don't think there are options to change the voltage
2,715 (0.57/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
The i7 10700 is rated for 65w, its not overclockable and/or locked.
23 (0.02/day)
I don't want to overclock it, I would like to remove the other edp limitations on cores and rings, I'm afraid they can create framedrops during my gaming sessions
Deleted member 202104
It doesn't appear that your motherboard allows any power limit override. According to the tests at this site, it shouldn't really matter for gaming:
Power locked = Green Bar
Power Limits Unlocked = Blue Bar
Gaming rarely requires all-core boost at 100% utilization (where power limits are reached).
836 (0.60/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
that will not happen unless u operate a real flying spaceship through the galaxy.
it has its potencial, yes, but when i look to the numbers. voltage is too kinda high in some cases 1,33V for a locked i7. and the temperatures going to 80°C-91°C max. :fear:
my i7 11700K has max-load temperatures of 45°C-65°C.
Keep in mind too much volts and high temps will cause your CPU gets "older" in a faster manner. [noticable over years only, but it happens].
beside most of the games do not harm 8*8 cores. maximum maybe 4. theres still enough space. do not torture it for no reason.
cook cpu GIF
23 (0.02/day)
it has its potencial, yes, but when i look to the numbers. voltage is too kinda high in some cases 1,33V for a locked i7. and the temperatures going to 80°C-91°C max. :paura:
cucinare cpu GIF
Thank you for reassuring me about its correct functioning I had the nightmare of having bought a door stop, I come from several years of suffering on notebooks with limits regarding current and temperatures, I hoped to have freed myself from the limit reasons with the purchase of this fixed pc, unfortunately in this period creating an assembled desktop was too expensive for my pockets and this pc was an excellent opportunity to have a performance desktop.
The temperatures are so high because it is equipped with the intel stock heatsink I hope to be able to do an upgrade later.
836 (0.60/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
get a better cooling solution! invest 50€/$ to your brandnew PC and nourish it a bit.
if you are a bit broke at the moment - get a better thermal paste, tho. it helps as well! 10€/$
23 (0.02/day)
I have not yet purchased it because I fear it may void the warranty of the pc, I have not yet inquired about the presence of warranty seals inside it.
1,065 (0.29/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
the bios on that (probably very cheap) motherboard is pretty much locked down. adjusting the voltage won't make the clock speeds faster, just add more heat.
here is a video of an older model showing how locked down everything is on the models:
welcome to the crappy world of OEMs :oops:
23 (0.02/day)
Interesting I did not think that the gpu blower version had temperature problems, fortunately they put me a custom dual fan version that has not yet exceeded 50 °, I have to remedy only a worthy heatsink for the cpu
unclewebb
8,084 (1.33/day)
@Zakaru91 - To increase the Turbo Power Limits, press the TPL button.
Clear the check mark from the box, Disable Power Limit Control. Now you can set your turbo power limits to whatever you like. I would set PL1 and PL2 to the same thing, 134W. For the turbo time limit, I would use the default value of 28 seconds though this setting does not matter.
Better yet, set both turbo power limits to the maximum value. Power limits are really not necessary.
The voltages and everything else is locked down so no other adjustments are possible.
836 (0.60/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
then go to the vendor, ur PC in a bag and tell him that the heck this case must be opened.
u are not willing to fry your CPU anymore.
sooner or later u will get more problems because i guess the cooler is crap and the paste beyond aswell.
tell him he can make a better deal to serve ur interests instead u coming in 2 years with a burned CPU (~275$/€) to replace.
and when hes smart enough he sells u the new cooler and the paste right away.
u have now reasons and argumentation learned while reading our conversation
23 (0.02/day)
Thank you very much, I just set everything have not gone away the limit reasons but maybe it will work better :D
1,065 (0.29/day)
Processor i7-11700K
Cooling Custom Loop
Mouse eats cheese
Keyboard warrior!
yeah possible variables aside, two fans are usually better than one. though i hope you saw where the bios was locked down - i do think it was an older model but OEMs seem to do the same old same old through cpu/chipset generations.
i see a ninja. yeah i think following unclewebbs suggests will help work around that sparse firmware options. fwiw i have an old biostar H61 board. the stuff in the bios is a tease; try to adjust anything and it reverts back at boot.
good luck.
unclewebb
8,084 (1.33/day)
The Limit Reasons window you posted shows EDP OTHER throttling, not PL1 or PL2 power limit throttling. Your computer has locked Power Limit 4 in the TPL window and in the FIVR window it has locked the IccMax values. Adjusting these can help with EDP OTHER throttling but neither of these two options are available to you to experiment with.
It is what it is. Adjusting the power limits higher like I suggested should help prevent throttling during some tasks.
Run something simple like Cinebench and see if you can maintain full speed for the entire test.
23 (0.02/day)
It actually also shows pl1 on core but I had cleaned the interface a few minutes before and it didn't appear anymore
