- Jul 15, 2019
- 592 (0.29/day)
- Hungary
System Name | Detox sleeper |
Processor | Intel i9-7980XE@4,5Ghz |
Motherboard | Asrock x299 Taichi XE (custom bios with ecc reg support, old microcode) |
Cooling | Custom water: Alphacool XT45 1080 + 9xArctic P12, EK-D5 pump combo, EK Velocity D-RGB block |
Memory | 8x16Gb Hynix DJR ECC REG 3200@4000 |
Video Card(s) | Sapphire RX7900XT - NITRO+ Vapor-X 20GB |
Storage | Samsung PM9A1 1Tb + 2x PM981 512Gb + Kingston HyperX 480Gb + Samsung Evo 860 500Gb |
Display(s) | HP ZR30W (30" 2560x1600 10 bit) |
Case | Chieftec 1E0-500A-CT04 + AMD Sempron sticker |
Audio Device(s) | Genius Cavimanus |
Power Supply | Super Flower Leadex 750w Platinum |
Mouse | Logitech G400 |
Keyboard | IBM Model M122 (boltmod, micro pro usbc) |
Software | Windows 11 Pro x64 |
undervolt on these cards not lower the power usage, it just make the card to boost higher.I bought one of these behemoths several days ago, specifically the even more ridiculous Sapphire Nitro+, and the power consumption is simply horrific. The OC BIOS that made the card eat 400W certainly didn't help either, lol. Even with the regular one it was a miniature oven installed inside the case, so I experimented for a while and realized the boost clocks were complete nonsense and had very little to none at all effect on frame rates. I limited the max frequency to 2300MHz while lowering the power limit to the max. allowable -10%, along with undervolting the card to 1080mV (from stock 1150 - is that the same on all cards?), and now the damn remains pretty tamed at 300W. And I still have 165fps most of the time in Delta Force on ultra details.
I have a 7900XT Nitro+ (not the XTX). Voltage is 1100mv default. Undervolted to 1050mv, it boost to 2900-3000mhz in games. (driver mhz sliders at default 2600mhz, that does nothing)
I only play at 60hz so most of the time the card is on 100-150w power.
So i think the fps limit is the only way to reduce power. (if possible)
Or maybe a silent bios.
