Power Matters with EVGA PowerLink - Clean up your Power and System!
2,005 (0.48/day)
Everyone here focusing on the capacitors. But you all miss the mark. Does this new PowerLink have the ability to reverse polarity? Problably not.
I will explain why this matters. You see PowerLink is only compatible with cards that have power connectors facing one specific way. Im speaking about wheter the release latch is at the top or at the bottom.
Im pretty sure all EVGA cards have the latch at the bottom (when the card is installed).
However not all cards from ather manufacturers do. For example at one point i ordered PowerLink for my Zotac GTX 1080 only to discover that since it had latches at the top i was unable to use PowerLink.
There's actually a topic on EVGA forums where someone modded theirs to reverse polarity: https://forums.evga.com/EVGA-powerlink-polarity-modification-m2619471.aspx
So while i really like this concept im afraid it has limited compatibility. Just FYI if you do plan on buying it - do your research.
7,762 (2.73/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
Have a peek in our PSU review section I linked, and what graphs are there. You can draw it also like that if you look through a scope.
There cannot be a 1V ripple anyways... they aren't taking mushrooms or LSD...
Oh wait...
I looked before I posted. Transient tests have very distinct changes in the graphs, of which there are none in the PR images here. The PR images are clearly meant to be ripple/noise measurements, simply due to how they look (even, fuzzy lines with no steps or changes) and the focus on one being less "fuzzy" than the other. And the entire point of my posts is how ridiculous it is to demonstrate a feature with 1V ripple, given that it's way outside the ATX spec - but that is likely what has happened here, and I'd chalk it down to overeager PR reps thinking a change from 1008 to 728 looks way better than a change from 60 to 43. And of course you can have 1V ripple, you just need a really, really terrible PSU. It wouldn't work in any PC, but it's definitely possible to make.
Ruru
S.T.A.R.S.
13,340 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
I know what you mean, for example Asus cards have a cut on the PCB and the latches are facing up.
412 (0.07/day)
System Name ARiA
Processor AMD Ryzen 3600
Cooling Noctua NH-D15S
Memory 32GB Corsair Vengeance LPX 3200MHz C16 DDR4 (2x16GB)
Video Card(s) Nvidia RTX 2070 Super FE
Storage Samsung 970 EVO NVMe (1TB), 850 EVO SATA (500GB), WD Ultrastar (6TB)
Display(s) Asus VG279 144 Hz IPS
Case Fractal Design Define R6
Audio Device(s) Chord Hugo 2 to lots of headphones
Power Supply Seasonic Prime+ 850W Gold
Mouse Steelseries Rival 600
This is as close as audiophile snakeoil as you can get with mainstream PC hardware...
2,005 (0.48/day)
EVGA also makes a sound card. Capacitors aside clean cable routing is no snake oil. There is legitimate use case for PowerLink but unfortunately it's held back by compatibility and also i wish it were slimmer. Better yet instead of putting power connectors mid board GPU manufacturers should go back to putting them at the end of the card.
The current way of placing power connectors is legacy from era where people were complaining that it made the cards longer and that they ran into clearence issues with hard drive cages. These days most people don't even have hard drive cages anymore or hard drives for that matter. Plus cards have gotten shorter thanks to HBM and the death of SLI/CF/DualGPU monstrosities.
Ruru
S.T.A.R.S.
13,340 (3.00/day)
Jyväskylä, Finland
I don't see it like that. Many (including me) has sleeved cables with cablecombs etc..
Of course if you haven't got a windowed case and you don't care how your cables are organized etc., then I agree with you.
6,215 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
He's not talking about aesthetics, but about the logic of introducing the electrical component.
2,357 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
Is this thing one size fits all or only nvidia ref pcbs and gl for those with custom PCBs?
2,005 (0.48/day)
In terms of power connector spacing and horizontal placement it's compatible with most.
Problem occurs with power connector vertical alignment. Meaning if connector relase latches are at the top then you can't use PowerLink on that card without doing hardmod to PowerLink itself. See my previous posts here about that.
1,458 (0.29/day)
Processor Ryzen 9 7950X3D
Motherboard MSI X670E MPG Carbon Wifi
Cooling Custom loop, 2x360mm radiator,Lian Li UNI, EK XRes140,EK Velocity2
Memory 2x16GB G.Skill DDR5-6400 @ 6400MHz C32
Video Card(s) EVGA RTX 3080 Ti FTW3 Ultra OC Scanner core +750 mem
Storage MP600 Pro 2TB,960 EVO 1TB,XPG SX8200 Pro 1TB,Micron 1100 2TB,1.5TB Caviar Green
Display(s) Alienware AW3423DWF, Acer XB270HU
Case LianLi O11 Dynamic White
Audio Device(s) Logitech G-Pro X Wireless
Power Supply EVGA P3 1200W
Mouse Logitech G502X Lightspeed
Keyboard Logitech G512 Carbon w/ GX Brown
VR HMD HP Reverb G2 (V2)
Software Win 11
So is EVGA saying that the SuperNOVA P2 850W powersupply that I own is shit? And that I should be using a Powerlink because their own PSU won't provide good, clean, stable power?
Yeah... fuck that. Their marketing is terrible.
3,032 (0.78/day)
Mouse Razer Abyssus
Software Ubuntu
Snake oil was the first thing that came to mind.
If you're worried about ripple, buy a good PSU. No one needs this BS product.
134 (0.06/day)
I would of used this but for one thing. If they would of made the interface for the power connectors face downward it would of left only a few inches of cable visible. But with this device, it only moves the connectors from the front to side with the same angle to plug in the cable. It doesnt achieve its main objective at least for my case, hiding as much of the cable as possible.
Tink-GB
1 (0.00/day)
Had several of these PowerLinks for a while and whilst I agree with most posts, the point is for me anyway, is that with my EVGA 2080ti, it cable manages the 16 cables that would otherwise be sticking out the front of the card and on view. No matter how you then try to smarten them up, they either hide the writing on the card, mess up air flow or look aweful in a glass case... Thus powerlink solves my issue perfectly and manages those cables to the dark unlit side of my case and you can only see an inch of those cables now.
I for one am perfectly happy to pay the price for this, although not sure if the EVGA powerlink fits the EVGA 30 series onwards so I will have to reconsider going forwards.
305 (0.05/day)
Bay Area, CA
2,005 (0.48/day)
New member. Clearly. But PowerLink is still a unique way to hide cables and i use on my 2080Ti too tho it's not made by EVGA itself.
If anything they should consider making PowerLink 2 that is slimmer and has the option to reverse polarity (because not all manufacturers place power connectors the same "correct" way). Tho if fear that due to the new 12+4 pin PCIe connector (at least on NVIDIA cards) the existing PowerLink will be incompatible anyway. And if on FE cards it is in the middle of the board again then a PowerLink wont help you anyway.
