Power question for Nvidia Geforce GTX 750 Ti
JTGMagic
3 (0.00/day)
Hi guys
I have a doubt regarding the power that the Nvidia Geforce GTX 750 Ti needs.
I got one Nvidia GTX 750 Ti for free and I wanted to mount it on my PC but I'm not sure if my power supply can handle this GPU.
My power supply is a MAXPOWER 650W/350W Model no. FATX650MP
My build is
Asus PRIME Q370M-C (LGA1151)
Intel Core i7-9700 CPU @ 3.00GHz
RAM 16 GB
Can I put the GTX 750 Ti on the PC without a problem it will work or need another power supply?
Thanks the experts who can help me :)
18,584 (2.67/day)
System Name AlderLake
Should be ok but if I were you I would save up for a better well known brand PSU.
1,769 (1.00/day)
Over the Hill UK
System Name AMDWeapon
Case Montech 903 MAX AIR
VR HMD -
Software Windows 11 Pro 24H2
The 750Ti is only 60 watts and has no power connectors so just chuck it in, drivers install and play away...
18,584 (2.67/day)
Isn't the 750Ti only 75 watts and has no power connectors?
Yeah it's fine but I just don't know that PSU, never heard of it, I recommend buying a PSU from a well known brand, like Seasonic, Corsair, EVGA, Enermax, FSP, Be Quiet.
Never cheap out on a PSU.
7,333 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
12,328 (2.25/day)
Oregon
Keyboard EVGA / Logitech K400
19,375 (3.52/day)
PSU is likely trash for quality. It's a 440W RMS PSU with only 300W on the 12V rail. That said, it will likely be fine at stock speeds (which is all that system can handle).
That out of the way, get another, MUCH BETTER QUALITY power supply ASAP. That thing looks like a hunk of trash just by seeing how the power is listed and distributed. Seriously... I worry a potato like that can take out your whole system.... who knows what protections it has or doesn't. It's 'just fine' or 'chuck it in' but there are clear caveats here that needed to be mentioned with statements like that using a PSU like this.
EDIT: Actually I take it all back............. I'm not sure if that would work OR if it does, I wouldn't do it in the first place. The 300W 12V is the PEAK, RMS is 192W/16A.... yikes. YIKES. It may work, but I surely wouldn't use that PSU. The distribution of the 600W (or even 440W RMS isn't 'all' on the 12V rail so it is older spec'd model it seems? I wouldn't do it.... and this is coming from a user who doens't believe in 'really' overbuying for your PSU...
1,769 (1.00/day)
Over the Hill UK
VR HMD -
Listen to Earthdog, he has a large brain. Helped me before I believe.
765 (0.15/day)
Germany
System Name Acer Nitro 5 (AN515-45-R715)
Processor AMD Ryzen 9 5900HX
Motherboard AMD Promontory / Bixby FCH
Cooling Acer Nitro Sense
Memory 32 GB
Video Card(s) AMD Radeon Graphics (Cezanne) / NVIDIA RTX 3080 Laptop GPU
Storage WDC PC SN530 SDBPNPZ
Display(s) BOE CQ NE156QHM-NY3
Software Windows 11 beta channel
JTGMagic
3 (0.00/day)
Thanks for help guys
Yea I think go try out if works with this power supply, but yea I will buy at some point a new one a better one.
Rei
656 (0.40/day)
Guam
System Name 1 Desktop/2 Laptops/1 Netbook
Processor AMD Athon X2 64/Intel Pentium 997/Intel Pentium 4/Intel Atom
Motherboard EpoX ATX motherboard/Samsung/Toshiba/Lenovo
Cooling Stock
Memory 4 GB/4 GB/2 GB/2 GB
Video Card(s) Asus GeForce GTX 780 Ti/Intel HD Graphics/GeForce 4MX/Intel GMA
Storage 6+ TB Total
Display(s) HP Pavilion 14 Inch 1024x768@60Hz 4:3 Aspect Ratio CRT Monitor
Case None
Audio Device(s) Various
Power Supply Seasonic 500 Watt & VenomRX 500 Watt
Mouse Wayes Iron Man Wireless Mouse
Keyboard Rexus VR2 Wireless Keyboard
Software Win10 & WinXP SP3
Benchmark Scores It sucks...
If I remember correctly, MAXPOWER is an cheap low quality brand. Normally a continuous wattage of 440 Watts should be fine for your PC but it's a good thing you posted a screenshot of your PSU specs cuz that power distribution looks unbalanced. It might work paired with 750 Ti but don't hold on to your PSU for too long. Your rig might not hold out for that long. Buy a better one from a well-known PSU brand with at least 650 Watts 80+ Bronze rating which should also future-proof your rig for a good while.
19,375 (3.52/day)
Sooner than later. Like, now..
That thing is, for all intents and purposes, a 192W PSU. Combine that with expected low quality and you have a potential disaster on your hands.
470 (0.14/day)
System Name Specs Last Update: 8/April/2024
Processor Intel Core i5 9400f 2.9GHz/4.0 Turbo (NoOC)
Motherboard Gigabyte Z370M D3H rev. 1.0
Cooling be quite! Dark Rock Slim 180W TDP (The Silent Wings 3 120mm Fan)
Memory Corsair Red Line 8x2 16GB 3000MHz (NoOC) DDR4-3000 15-17-17-35 (CMK16GX4M2B3000C15R) V1.35 ver 4.24
Video Card(s) NVIDIA GeForce MSI 980 Ti Golden Edition (NoOC)| Spare: GTX 650 Ti 1 GB
Storage Samsung 870 EVO 4 TB | Samsung 860 EVO 1 TB | Cold Backup: WDC Black 930 GiB WD1003FZEX
Display(s) Asus VG248QZ 1920x1080 144hz 24" (Current: 60hz)
Case Corsair Air 540
Power Supply Corsair 850W RMi
Mouse Logitech M187 wireless (First day of use 30-9-2021)
Keyboard Logitech K270 wireless
Software Windows 10 21H2 LTSC 2021 / Linux: Candidates: Bazzite - Linux MX - Tuxedo - Kubuntu
JTGMagic, :(
EarthDog did actual research and reading about the PSU. You might lose both the card and the computer. Why do you think it is okay to just go and "try" and keep as it is until you think you will or not. Don't do it. Wait until you get a real power supply. This is too risky. Imagine you lose the card only? Now you have to pay for another graphics card and a power supply. Imagine you lose both card and the motherboard or even most of the devices? Is it worth it you go this route?
  • Like
Reactions: Rei
19,375 (3.52/day)
I didnt look it up. It could be awesome (I'd bet money against that)... but since a lot of the total wattage is on the minor rails, it screams old design. Couple that with the RMS/sustained wattage being so low, I worry. It may work. It may not. It may work for a while.. who knows. But I see a lot of red flags.
JTGMagic
3 (0.00/day)
Yea MAXPOWER is not expensive brand I bought that power supply on local store.
The specs you can find online are this ones
MaxPower Power Supply 650W Peak / 350W Real
Certified for new Intel and AMD processors
Ultra-quiet ventilation system with 120mm
Over / UnderVoltage Protection Circuit
ATX Power Supply Type
Power 650W Peak / 350W Real
Output + 12V
+ 12V: 26A
Pot. Comb: 300W
Output + 3.3V / + 5V
+ 3.3V: 28A
+ 5V: 26A
Pot. Comb: 140W
Output -12V / + 5VSB
-12V 0.5A 10W
+ 5VSB 2.5A 12W
Sheets / Links
24pin motherboard (20p + 4p) x1
CPU 12 4pin x1
SATA 15pin x2
MOLEXin x2
FLOPPY 4pin x1
Fan 120 x 120 mm
230 V power supply
Other features
EU regulation
ErP Ready
CE, EMC certified
Dimensions 130 x 165 x 95 mm
2 Year Warranty
I don't now any more lol
I don't want to compromise any of the other components, the pc is relatively new.
What power supply you guys recommend? Nice one but not expensive.
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
Output + 12V
+ 12V: 26A
Pot. Comb: 300W
+ 3.3V: 28A
+ 5V: 26A
Pot. Comb: 140W
-12V 0.5A 10W
+ 5VSB 2.5A 12W
Sheets / Links
CPU 12 4pin x1
SATA 15pin x2
MOLEXin x2
FLOPPY 4pin x1
Fan 120 x 120 mm
230 V power supply
Other features
EU regulation
ErP Ready
CE, EMC certified
2 Year Warranty
Yikes... :eek: 350 Watts of real power with only 16 Continuous Amps on the 12 Volt rail. Good choice to replace it quick.
For my part, as I am not caught up on the latest model of PSU, the only recommendation I can gives are PSU specs.
Best to get from well-known brand as they should be trustworthy most of the time. Make sure the PSU has at 550 Watts of continuous power. While I can't confirm it myself but most well-known brand should have peak power & continuous power not far apart. Also be sure that it has at least 80+ Bronze rating.
8,099 (1.34/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
650 watts. They lied. The maximum on the 12v rail is 312 watts. Where do they get the other 338 watts from? If you add up all of the max currents, it only totals 556 watts!
350 watts. Nope, not going to believe that either. Not today when almost everything runs off of the 12v rail.
Even they know that this PSU can't deliver. Where is/are the PCI-e power connector(s)?
Basically, an 80+Bronze certified PSU from Seasonic, EVGA, Corsair, Super Flower, FSP.... At the very least, a power supply that has been reviewed by an independent review site. No review, no touch.
