Problem changing RTX 2060 firmware
33 (0.02/day)
Montreal, Canada
Right now my sweet spot seems to be +160 on the core clock and +515 on the memory clock. This gives me an average frame rate of 139 FPS.
Anything higher than the numbers that I have and my frame rates actually decrease. I'm thinking that I might try unlocking the voltage control in the settings and see if I can squeeze out a little bit more performance from the card.
LosSantosPro
22 (0.01/day)
I can only get +130 on my card
btw i tried the voltage control, it made literally 0% difference in my case
Ok so what the hell...
newest driver, lower score, max 82C
older driver, higher score, max 66C!
Edit: After another benchmark, temps are the same again - 82C
33 (0.02/day)
Montreal, Canada
Right now I'm downloading driver versions 442.74, 445.87 and 446.14. I'll try them and let you know what I get.
LosSantosPro
22 (0.01/day)
Whats weird, i get a worse score in 3DMark, 7980 vs 8050, not much, but confusing because the other benchmark begs to differ...
With the older driver* 442.74
33 (0.02/day)
Montreal, Canada
I decided to ignore benchmark results and focus on FPS's. To me, that's more of a "real world" test.
LosSantosPro
22 (0.01/day)
Good call, let me run gta benchmark again
Notice the Run Benchmark Tests option, do you not have that?
Still getting over double FPS than MSI!
Another update
my idle temps have tanked with the old driver
33C vs 41C
Probably because this driver allows the GPU to sit at 300MHz base instead of 1365MHz
LosSantosPro
22 (0.01/day)
Bit of an update
No crashes to report of while benchmarking with the iGame BIOS, however ive only just had the time today for a gaming session, and is incredibly unstable, even after pulling power rating back to 100% and my OC down too.
I have decided to flash the EVGA BIOS at the moment to see if it makes a difference.
I’ll update when i find out more
LosSantosPro
22 (0.01/day)
Hi, just to make you aware I have found a better VBIOS for the PG161 cards
1830Mhz Boost
190W Target / 215W Limit (Compared to stock 160W T/L)
And, all 4 ports work on this BIOS
Managed to get further O/C Stable, the issues I were having before were CPU O/C related
MSI Afterburner Settings on my Ventus 2060
113% Power (Max)
+95Mhz Core Clock
+990Mhz Memory Frequency
soul87
2 (0.00/day)
Hi Guys, any of You have any expeprience with thix RTX 2060, itsa MSI Ventus XS OC with this bios
VGA Bios Collection: MSI RTX 2060 6 GB | TechPowerUp
I have a problem, this card does not accepy ANY other bios with PG161 SKU 42 ID
I've tried many of bioses mentioned here and other from techpowerup database, off coure PG and SKU matched... issues is that after flash card only run without drivers... no screen with drivers.. I tried DDU and no luck...
Any ideas? I want to change the bios because TDP limiter set to 160W...
fun fact, its not even accepting this bios
which looks very similiar but have only different version.
44,267 (6.80/day)
Well there is no reason to flash
soul87
2 (0.00/day)
1,340 (0.35/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | Koss KSC75
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Tiny11 Windows 11 Education 24H2 x64
Forgive me if I'm wrong but Nvidia sells two variants of its chips right? One that max goes upto 100% for base versions and another that goes 100%+ for OC version cards. Or did I imagine that and it's just soft bios lock?
