Problem with Graphics card sagging solution
2,318 (0.34/day)
System Name MONEY PIT
Processor i7-3770K @ 4800 1.20v batch #3231B415 Delided
Motherboard ASrock Z77 OC Formula w onboard waterblocks
Cooling Apogee HD, MCP655,rad MCR320-XP,Micro Rev2 res
Memory G,skill Trident X F3-2400C10D-16GTX
Video Card(s) EVGA GTX 980 Ti Classified with EK nickel/acetal waterblock installed
Storage 2x120gig Wildfire raid0 2x120gig VERTEX3 raid0
Display(s) 3/ Samsung2343bwx + 65in LG 4K
Case NZXT Phantom White w/red
Audio Device(s) ReCon3d fatal1ty pro, Logitech z906 THX
Power Supply corsair AX860i
Mouse Rat7
Software 64bit ++++ win 10
I like to use plexiglass tube. If you want to light it 1LED does the trick.
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
ive never had an issue with GPU sag....which is odd, because all of MY GPU's are full length cards (over 12"s) 6950, 7970 (but it was the LCS water block one and had a beefy plate on back n front) GTX970, GTX210, 6870,and other my memory doesnt recall.
5,731 (1.07/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
12,327 (2.25/day)
Oregon
Keyboard EVGA / Logitech K400
They make GPU jacks, or just lay it down then problem solved. Yes it can damage your slot on your MB
This is why new boards come with reinforced metal slot covers
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
42,984 (6.72/day)
you might of had the motherboard aligned in the case properly is why. My GPU doesnt exhibit any sagging either and its a Heavy SOB
1,025 (0.33/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB + Team L3 EVO 480GB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
Drill two small holes with 2,5 mm drill bit in areas marked with red dots and fasten two M3 screws. This should be enough to support your gpu.
9,914 (1.84/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
use chopstick as GPU support
5,731 (1.07/day)
West Midlands. UK.
All that effort and not 1 screw holding it in the case? Or you do that on purpose?
I must of took the picture before I screwed it in but it is.
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
Adjustable graphic card supporter, comes with options for Crossfire/SLI
Mussels
Freshwater Moderator
58,413 (7.89/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
7,080 (1.01/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
I use a card keeper.
I have a potato camera. Look for the red box, thats the card keeper. I like it a lot.
I got a couple of these, if you live in the US I could ship you one if you pay shipping.
Doesn't work with all cards, you have to have the circuit board accessible for it to clip to and you might need a different, longer pci slot screw
You can also try things like a unsharpened pencil or a chopstick or try hanging your PCI-E power cable from above so it lifts the card. I used to use zipties but I didn't like having to cut the zip ties to remove the card.
12,327 (2.25/day)
Oregon
Interesting idea
Here another one
7,080 (1.01/day)
USA
Mouse Zowie EC3-C
The card keeper looks better since it doesn't use up any slots besides the one already used for the card. I didn't pay very much for them either, bought a bunch on eBay as a lot awhile ago.
http://www.cardkeeper.net/index-2.html
I am using the
CARDKEEPER® Model CK99-1224
I had one of the larger size ones but it didn't fit my card as well, the smaller 1224 is sufficient I think. The larger size one does use two screws which is a plus, it will hold more weight more securely.
12,327 (2.25/day)
Oregon
Can't tell with your potato camera. You have a link to the item?
7,080 (1.01/day)
USA
Mouse Zowie EC3-C
Better picture, its the black horizontal beam on the videocard's pci slot screw.
rtwjunkie
PC Gaming Enthusiast
14,022 (2.33/day)
Louisiana
Processor Core i9-9900k
12,327 (2.25/day)
Oregon
5,717 (0.93/day)
AsRock
TPU addict
19,123 (2.98/day)
UK\USA
Wow! I never realized there was a dedicated, purpose-made solution. :cool:
Wow really, personally i noticed a few users here who use all sorts of things. Although i did miss Mussels if he posted it before though.
Personally i like using fishing wire, although no good if you always have your hands in your case :p.
Mussels
58,413 (7.89/day)
Oystralia
my straw method was a recent invention when i went SLI, the two cards sagged close enough the top one ran 10C hotter - so i used a bit of straw to seperate them, which pushed the bottom card lower... so more straws were needed.
Bonus points is the straws are free, and i got frozen drinks :p
5,731 (1.07/day)
West Midlands. UK.
And to thaw them out you just put them into your case, all in one solution all round!
9,914 (1.84/day)
Jakarta, Indonesia
Case Icute Super 18
That looks like bad/ sloppy motherboard alignment,
yeah especially when you buy cheap case, sometimes you need to skip 1 standoff point since the alignment is bad
2 (0.00/day)
Save it for Youtube. Want more hits on your video? Advertise on Google or FaceBook.
Okay copy dat. I'm following your orders
What do you mean by cheap case. Mastercase 5 pro? You're a billionaire then.
That looks like bad/ sloppy motherboard alignment, like the system was wam, bam, thank you ma'am :shadedshu:
I guess i was fortunate with my gpu not sagging despite being big, heavy, bulky...
You have no idea what zotac amp extreme card looks like. I didn't think of that, cooler Master mastercase designers never made a mistake then, promoting the modular design mastercase everywhere(alignment issues with popular motherboards)
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.98/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Mouse cheap
Keyboard under going restoration
I think its a good solution...well expressed, through the medium of video. I hate it when subtitles have spelling mistakes though.
