Problem with RX 5700 XT BIOS flashing (strange current BIOS)
ganjamafia
21 (0.03/day)
Hello, I bought a used RX 5700 XT Pulse BE card and I have some strange BIOS in it: https://www.techpowerup.com/vgabios/258029/258029
so I wanted to flash a new one (https://www.techpowerup.com/vgabios/212910/sapphire-rx5700xt-8192-190722-2) but when flashing I get an error:
Screen from GPU-Z:
Any advice?
flatfire
3 (0.00/day)
Interesting. The Pulse should have a BIOS switch on it for an A and a B BIOS. Can you give a try to switching to the other BIOS option? The switch is generally located at the top of the card, just under the shroud if I recall rightly.
ganjamafia
21 (0.03/day)
This is BE (Black edition version), from what I've read, this version doesn't have a switch
18,584 (2.67/day)
System Name AlderLake
A reason why I always buy new GPU's...
GL.
flatfire
3 (0.00/day)
You're right. I missed that, sorry. What's strange about the BIOS you have flashed, is the core clocks are actually much higher than the regular 5700 XT BIOS. I'm wondering if what's on there is a mining BIOS.
Did you try unlocking the ROM for flashing? Should be amdvbflash -unlockrom. Could be why your flash is failing.
ganjamafia
21 (0.03/day)
I haven't flashed any bios because I get an error. I bought a card with this bios https://www.techpowerup.com/vgabios/258029/258029, I tried to unlockrom but still the same
The core clocks in the current bios (In general, it is marked as 5700 and not 5700 XT) that I have on the card is much lower than in the normal 5700 XT, unless I'm wrong
flatfire
3 (0.00/day)
Sorry if my language was confusing, I was referring to the BIOS that's currently on the card itself. It has a much higher core clock than the stock BIOS, but without more information regarding things
The error you're encountering might be a result of the ROM on the card being locked. Try using amdvbflash -unlockrom 0 and then flash the 5700 XT BIOS you have to the card.
Additionally I think your parameters might be wrong. I believe amdvbflash -f -p 0 bios.rom is correct, though I may simply have not seen that particular syntax before.
43,223 (6.74/day)
Gpu specs
E426 in the bios matches the pn sticker on your card
You are getting a mismatch error by trying to put a E408 bios on your E426 card, dont do it.
Here you go (what you need)
What it appears is you have a C4 revised card which have a lower silent bios clock.
And C1 matches the SKU on Sapphires page
ganjamafia
21 (0.03/day)
Gpu specs
Hi! thank you for your answer but i have the same
43,223 (6.74/day)
Stop using the latest version, it uses a different command syntax.
Download atiflash/amdvbflash 2.93
Go here https://www.techpowerup.com/download/ati-atiflash/
Then look for Version 4.68, underneath 4.68 you will see a link to show older version, click that and you should see version 2.93
Then Follow these steps carefully:
1. Open your "C:" drive in Windows, create a new folder, call it atiflash.
2. Extract the contents of atiflash_293.zip to the "C:\atiflash" folder
3. Find the bios file you downloaded and rename the bios file to r5700.rom
4. Move r5700.rom to the "C:\atiflash" folder
5. Open the start menu, type cmd, when cmd.exe appears right click it and hit "Run as administrator"
6. At the command prompt type in cd\ and press enter until only C:\> is on the screen.
7. Type in cd/atiflash and press enter, you should see C:\atiflash>
7a. At C:\atiflash> type in amdvbflash.exe -i to identify your card with a 0, 1, or 2
8. At the C:\atiflash> prompt type in
amdvbflash.exe -unlockrom 0 (or 1, 2)
(there is a space between the e and -unlockrom and 0)(0 is the number zero)
press enter and you will be prompted that the "ROM Unlocked"
9. At the C:\atiflash> prompt type in
amdvbflash.exe -f -p 0 r5700.rom
(there is a space between the .exe and -f, and a space between -f and -p and 0)press enter.
Follow directions on screen and if flash is successful exit the command prompt and restart, windows should show up on
ganjamafia
21 (0.03/day)
Atiflash 2.93:
43,223 (6.74/day)
Ok 0 is the adapter so follow the rest of the commands
If you cant get it right copy and paste the command in bear in mind the file name and that you must be in an admin rights command prompt
ganjamafia
21 (0.03/day)
I ran with administrator rights and followed the instructions and got this error:
43,223 (6.74/day)
Where is the rom file located?
Is it in atiflash folder?
43,223 (6.74/day)
Did you rename the file to r5700.rom?
Ok try the command sequence as: amdvbflash -unlockrom
Then
amdvbflash -p 0 -f r5700.rom
43,223 (6.74/day)
43,223 (6.74/day)
Shut down, pull the card, blow dust out of the pcie slot, check the pcie pins on card to ensure they are clean. Reinsert card firmly and squared in the slot, boot back up and try again.
You may need to try using safe mode or a bootable usb drive method
ganjamafia
21 (0.03/day)
I cleaned it and still the same, i will try in safe mode
@eidairaman1 In safe mode it's exactly the same
1,891 (1.38/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hello.
When i flashed a 5700 XT, in some cases (some of them were also Sapphire) i encountered that error also.
What i did to pass the error ?
I tried the flash command again and again, until it worked.
In a case i did that 20 + times until the card decided to accept my commands.
Just be patient.
I am not kidding. So please do that
ganjamafia
21 (0.03/day)
Hello.
Just be patient.
Hi! Okay, I'll try
43,223 (6.74/day)
Hello.
Just be patient.
Yeah otherwise a bootable usb drive or spi flasher is required
