Project: Aluminum Water Cooling Case
4,016 (0.66/day)
Ohio
System Name Desktop|| Virtual Host 0
Processor Intel Core i5 2500-K @ 4.3ghz || 2x Xeon L5630 (total 8 cores, 16 threads)
Motherboard ASUS P8Z68-V || Dell PowerEdge R710 (Intel 5520 chipset)
Cooling Corsair Hydro H100 || Stock hotplug fans and passive heatsinks
Memory 4x4gb Corsair Vengeance DDR3 1600 || 12x4gb Hynix DDR3 1066 FB-DIMMs
Video Card(s) MSI GTX 760 Gaming Twin Frozr 4GB OC || Don't know, don't care
Storage Hitachi 7K3000 2TB || 6x300gb 15k rpm SAS internal hotswap, 12x3tb Seagate NAS drives in enclosure
Display(s) ViewSonic VA2349S || remote iDRAC KVM console
Case Antec P280 || Dell PowerEdge R710
Audio Device(s) HRT MusicStreamer II+ and Focusrite Scarlett 18i8 || Don't know, don't care
Power Supply SeaSonic X650 Gold || 2x870w hot-swappable
Mouse Logitech G500 || remote iDRAC KVM console
Keyboard Logitech G510 || remote iDRAC KVM console
Software Win7 Ultimate x64 || VMware vSphere 6.0 with vCenter Server 6.0
Benchmark Scores Over 9000 on the scouter
Wow looks good but this case is hilariously big! Could fit a small cluster of computers in there if you wanted :p
Yes, an all-in-one server farm :laugh:
You have to go big though if you want to fit a bunch of monster-sized rads.
125 (0.02/day)
New Hampshire, USA
Two cutouts were routed out of the back sheet for the bottom mounted PSU (left hand side of the pic) and intake fan, and two intake fans up top.
Eventually, some "adapter plates" will be mounted over the two cutouts.
To attach the MB tray to the back sheet, four PEM cinch nuts were pressed into the interior side of the .10-inch thick aluminum sheet. I love these nuts because they make quick work out of adding some threads to sheet metal.
Wile E
Power User
24,318 (3.60/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
You're gonna love my nuts.
125 (0.02/day)
New Hampshire, USA
Another awesome feature of this case is the "false" back, which is simply a sheet of aluminum between the removable back panel and the motherboard tray. The "false" back prevents the case from racking and is the primary cable management feature. In this case, the "false" back consists of three pieces of .10-inch thick aluminum.
The sheets that make-up the "false" back are threaded along the top via PEM nuts. Fastening them to the top support beam is simplified via the addition of slots routed out of the support beam. These allow the hex wrench to be raised into position as the socket cap screws are driven into the sheet.
Along the bottom, the sheets are fastened to some 1/2-inch angle.
4,016 (0.66/day)
Ohio
This is coming along very nicely.
Wile E
Power User
24,318 (3.60/day)
It is such a monster. I am entirely jealous of it.
1,585 (0.28/day)
Los Angeles/Orange County CA
System Name Vulcan
Processor i6 6600K
Motherboard GIGABYTE Z170X UD3
Cooling Thermaltake Frio Silent 14
Memory 16GB Corsair Vengeance LPX 16GB (2 x 8GB)
Video Card(s) ASUS Strix GTX 970
Storage Mushkin Enhanced Reactor 1TB SSD
Display(s) QNIX 27 Inch 1440p
Case Fractal Design Define S
Audio Device(s) On Board
Power Supply Cooler Master V750
Software Win 10 64-bit
Ah, the old false back trick! :D
749 (0.13/day)
Netherlands
System Name gaming system
Processor 2600k @ 4.2 ghz
Motherboard MSI Z77 MPower
Cooling Thermalright ultra extreme 120 rev.C w/noctua NF-S12B push/pull
Memory 16gb corsair vengeance 2400 c11 @1.5 v/
Video Card(s) GB gtx670 WF3x sli @1080/1372/6660(core/boost/mem)
Storage 2x samsung 850evo 250gb raid 0 ,2tb wdblack, 3TB wd purple
Display(s) Samsung Syncmaster P2770FH, asus VH242t/19" lg 1440x900
Case fractal design r4
Power Supply Corsair HX1050
Mouse Razer abyssus
Keyboard corsair k70
Software Windows 10 pro x64
are you dead? haha
can't wait for the next update;)
9,922 (1.81/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
i love aluminum things
749 (0.13/day)
Netherlands
Mouse Razer abyssus
125 (0.02/day)
New Hampshire, USA
Slots for wire and tube routing were cut out of the top and bottom shelves. I attempted to use a pattern router bit, but the deep cut forced the bit's bearing into the 3/8-inch thick particle board, ruining it.
So I switched to using a pattern to guide the base of the router.
The slots along the edge of the bottom shelf were cut in such a way to allow tubing and wiring to pass without significantly weakening the 1/2 x 1-inch u-channel.
Bottom shelf slots:
Top shelf slots:
Finally, two slots were also cut out of a portion of the "false" back:
1,585 (0.28/day)
System Name Vulcan
Processor i6 6600K
Good to see an update.
125 (0.02/day)
New Hampshire, USA
Up until now the front of the case has been held on with masking tape, but its now time to attach it securely. I had originally planned on drilling through holes and bolting the front to the case, but there wasn't much room for my hands to hold onto a nut, so I increased the size of the through hole a bit and pressed-in some PEM nuts.
The front frame consists of 1x1 and 1/2x1 u-channels.
Button head bolts were used to attach the front to the case.
DeAtHWiSh
197 (0.03/day)
Miami, FL
System Name Desktop / Laptop
Processor AMD Thuban 1090T@3.6GHz HT@2.6GHz / Intel i7 2630QM @ 2.0GHz
Motherboard Asus CH V 990FX / Intel HM67
Cooling Corsair H100 CPU Load @ 48C (Fans on Low 24/7) / Stock
Memory G.SKILL Sniper Series (2 x 4GB) DDR3 1600 9-9-9-24-2T / Corsiar Vengence DD3 1600 (4GB x 2)
Video Card(s) ASUS 580 GTX DCII / NVidia 555M 1.5GB
Storage OCZ Vertex III 120GB (OS) - Seagate Barracuda 320GB-7200RPM (X2 in RAID 0) / PNY 128GB SSD
Display(s) HP 2711x 1080P 27'' LED ON DVI / 14'' LED 900p
Case Cooler Master HAF X 942 / Alienware
Audio Device(s) Realtek ALC892 8-Channel HD Audio / Realtek HD Audio
Power Supply Cooler Master Silent Pro 850W / Stock
Software Windows 7 Ultimate 64 Bit / Windows 7 Home Premium
Benchmark Scores Real Men Crunch 4 TPU!
This is filled with pure awesomeness!
125 (0.02/day)
New Hampshire, USA
The side panels were cut via the help of a large makeshift square made from a small square clamped to a ruler.
The radiator ventilation cutouts were made with the help of a router template. Some bits of scrap aluminum were bolted to the underside to eliminate any errors with placing the template accurately on the sheets.
Determining where to make the cutouts was easily done via a dab of India ink on the head of a screw and some masking tape. The panel was repeatedly pushed up against the inked bolt.
I'll round the corners later.
125 (0.02/day)
New Hampshire, USA
In order to accurately drill the bolt holes to attach the perforated aluminum to the side panels, I fabricated a drill template from some left over flat bar stock and a drill bushing I had lying around the shop.
A couple of spacers was used to quickly and accurately place the jig on the work piece (to avoid having to measure/layout the location of the holes).
Some .063 perforated aluminum cut to size:
To accurately cut the rounded corners on the side panels a router jig was fab'd from a piece of the corner round used on the body of the case, 1-inch u-channel and a couple of 1-2-3 block hot glued to some particle board. Two strips of Mylar from an old drum head was used to smooth out any irregularities.
Tah-dah!
28,883 (4.56/day)
Miami, Florida
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ARCTIC Liquid Freezer III 360 A-RGB // X12 Phanteks D30-120 D-RGB Fans
Memory G.SKILL Trident Z5 Neo RGB Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL30
Video Card(s) ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO
Storage Samsung Pro 980 2TB NVMe (OS and Games) // WD Black 10TB HDD (Storage)
Display(s) SAMSUNG 34-Inch Ultrawide 75Hz (Desk Games) // SAMSUNG 49-Inch Ultrawide 144Hz (Sim Racing Rig)
Case Phanteks NV7
Power Supply Seasonic Vertex GX-1200, 1200W 80+ Gold, ATX 3.0
God this thing is coming out beastly!
de.das.dude
Pro Indian Modder
9,216 (1.70/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad | Old Monke
Case Ant Esports Tempered case | Thinkpad | NZXT Guardian 921RB
Audio Device(s) Logitech Z333 | Jabra corpo stuff | Some USB speakers
Mouse Logitech G400 | nipple | Dell
VR HMD ;_;
the best thing i love about spotswood is that i can tell he really thinks about it and carefully measures everything out. also the attention to detail and perfection begs for :respect:
861 (0.16/day)
System Name FragBox
Processor Intel Core i7 2600K @ 5.0GHz/1.45 volts
Motherboard Asus P8Z77 WS
Cooling Custom CPU loop
Memory Kingston 12GB DDR3 1600
Video Card(s) Galaxy GTX 680/Zotac GTX 680 in SLi/EVGA GTX 650Ti
Storage 2 Vertex 3 120's, raid 0, 2 Seagate Momentus XT 500GB's in raid 0, 1 Hitatchi 2TB for backup
Display(s) 3 Acer S232HLX2 in nvidia surround
Case Corsair C70 White
Power Supply Corsair AX1200
Software Win 7 x64 Pro
That decorative looking "corner round" or whatever you'd call it... where do you get that? I've been thinking of using your build as a bit of inspiration and make one myself, but I have -zero- ideas on where to get the materials.
-Oh crap, you're in NH? Hi, neighbor!-
125 (0.02/day)
New Hampshire, USA
I had to order $100 of the corner extrusion, which means I have a ton left over. PM me if your interested in a chunk.
de.das.dude
Pro Indian Modder
9,216 (1.70/day)
VR HMD ;_;
you are so awesome i would work with you for free, just because i would learn so much from you lol.
125 (0.02/day)
New Hampshire, USA
Another requirement for this case is a hidden door latching mechanism.
Look Ma! No latches!
A length of .125x.75-inch flat bar was bolted to the bottom of the door to act as a lip that will hook into the u-channel along the bottom of the case, for example:
Along the top of the door, there is a piece of angle with three "hooks", which were routed out using a cobbled together router template.
A thick piece of flat bar was filed down to where it'll slide easily inside the u-channel along the top of the case. To that three "posts" were bolted to it. When slid forward, the posts will engage the hooks.
125 (0.02/day)
New Hampshire, USA
A large area of the right side panel was cutout for a 16x15-inch acrylic window.
