Project: APASF ("A Post-Apocalyptic Steampunk Future")
281 (0.06/day)
Málaga, Spain
Project: APASF ("A Post-Apocalyptic Steampunk Future") (Final Pictures 29-03-2013)
Hello everyone.
This is my new "Main" project, after two small projects, one for a client and the other one being the tutorial project, this being the first main project since Fallout Cause SP back in December 2011.
I´ve had this idea in my head for years now, and you could say all of my projects in the last year and a half have simply been "tests" for techniques, both paint and structural modification in order to get ready for this one.
The concept is as far as I know something that has never been done before. Mixing the post-apocalyptic style with the steampunk style in a small slimline case (the same model in fact as I used for the fallout cause sp project). The reason for this is that it gives me a compact canvas to concentrate details and because the parts do not fit, they give me a modular look that I´ve always liked since I saw the original thermaltake Level 10 case (the first one, not the redesigned GT version).
This project is being sponsored by:
Some are new and some have been with me since the begining, either way I´d like to thank all of them for their support and amazing products!
I don´t normally list the hardware I will be using on my projects, but for the first time, this project will actually become my main PC so here are the basic details.
ASUS Maximus IV Gene-Z/GEN3
Intel i7 2700K
Kingston HyperX 16Gb DDR3 1866Mhz
2x Kingston HyperX SSD 240Gb in RAID
2x MSI GeForce GTX 560 Ti TwinFreeze OC 2Gb in SLI
NZXT HALE90-M-850w
B-Move Slim II Case
As for the rest of componentes, cooling and accesories, you´ll see them as they get mounted.
Let´s start then.
I´ve started with the structural modifications I need done on the case, the B-Move Slim II. I really like this case, it´s small, simple yet stylsh.
I´ve taken it all apart, I won´t be using any of the frontal conectors (except frontal USB & Audio) nor buttons or led.
For the design I have in mind to work, I need to cut the cover in parts, fit the upper and lower parts permanently to the case so the door is just the side, so here goes.
First part done:
And the second:
And now a test mount of the side panel:
It all fits fine, mostly because they have grips underneath that grab the frontal side of the case. This way it doesn´t become flimsy or weak.
Now the frontal of the case. I´ve removed everything from it as it has to be cut down in order to be made completely square and straight (which will later be filled to suit my frontal design).
First, cutting the left side so that a drive sized device can fit through it (originally it´s designed not to as it has a trap door with a open close button). Second is cutting all the elevated parts in order to make everything perfectly staight and squared. It will later be sanded down, and filled up to make it a solid block.
Now I´m going to be modifying the lower part of the case to suit the power suply, I´m using a used PSU for refference as it´s exactly the same size as the NZXT psu that will go in. In order to accomplish this I need to cut part of the lower section and modify the grip on it so I can still be fitted without the rear screw.
And done.
and the PSU fits nicely now.
Now I´m going to start customizing the PSU.
I´m going to be using a wood "look" vinyl, mostly as a design base so I have the lines and typical look of wood to work on.
And now the first stage of it´s paintjob, which in this case is mostly a mixture of inks, and ageing effects. Here´s the first stage:
And the final stage:
And the brass detail on the side that will be poping out of the case.
The camera flash shows what it actually looks like:
And finally a comparison shot between the standard vinyl and the "modified" one:
More to come soon!
Yo_Wattup
788 (0.17/day)
Brisbane, Australia
System Name Desktop/Gamer/Digital Audio Wokstation ||| HTPC
Processor 2500k @ 4.65ghz ||| AMD A8 @ 3.6ghz
Motherboard ASUS P8Z68-V Pro
Cooling Noctua NH-D14 with single Blue Antec Tri-Cool 120mm ||| Stock
Memory 16GB G.Skill Ripjaws X 1600 @1900mhz 8-9-9-24 ||| 8GB G.Skill 1600 CL9
Video Card(s) 2x HIS HD6950 2GB Crossfire, 6970 clocks ||| HD6550D
Storage 120GB Intel 320 series SSD + 2TB storage ||| 1TB Seagate
Display(s) 32" Sony Bravia LCD 1080p ||| 50" Hitachi Plasma 1080p
Case Raidmax Raptor modded to 7 fans ||| A compact HP Case
Audio Device(s) Firewire audio interface + two 9" studio monitors, 450 REAL watts ||| onboard
Power Supply Corsair TX 750W ||| generic 400W
Software Win 7 Ultimate + Win 8 consumer preview||| Win 7 Pro
Benchmark Scores Never drops below 60fps Battlefield 3 everything on max, fov 90. :D
Pics dont work.
966 (0.17/day)
Currently somewhere around NSW, Australia
System Name hmmm...
Processor 9800X3D
Motherboard X670E-I
Cooling PA120SE
Memory 2x16gb 6400 C32
Video Card(s) EVGA GTX 1080 TI FTW3
Storage T500 1tb
Display(s) 4K 120hz
Case Jonsplus Z20
Power Supply SF-1000
Mouse Logitech
Keyboard Corsair K70 LUX RGB
Subbed! Can't wait to see it done... :toast:
9,916 (1.83/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
nice case
the steel looks solid
wait for the next :toast: :toast:
281 (0.06/day)
Málaga, Spain
Pics should work ok now, sorry about that : )
Thanks guys! And yeah, it´s why I like this case so much for structural changes since the steel is quite thick so it wont fall apart when cut.
281 (0.06/day)
Málaga, Spain
Today´s work. Power suply finished.
More tomorrow hopefully, also, last minute change, the MSI graphic cards where no longer avaliable so have settled for 2x Asus GeForce GTX 560 Ti DirectCU II TOP 1GB GDDR5, it seems that fate always brings me back to asus for one reason or another. In any case, hopefully delivered tomorrow and can fo more body work over the weekend.
281 (0.06/day)
Málaga, Spain
Time for an update.
Unluckly the new GPUs didn´t come on friday so I couldnt do much on the weekend, but they came today and as luck would have it, it was only a half day at work as I did overtime on Friday.
Right, time for a test mount.
The frontal bay system does not close by very little, so I´ve trimmed down one of them so it does.
As for the watercooling, I will be using a full copper pipe system for this project, which while it looks really good is rather complicated for two reasons, first, I need plumbing fittings, luckily I found out that 3/8 is a common size for that, so i got some G1/4 to 3/8 fittings and problem solved.
The second problem, or not really problem just, complicated fact is that there´s no flexing, here, so all the measurements have to be exact at every point, so once all the liquid cooling bits and bobs are in their place I will get the pipes and cut them to size so everything fits, nicely. Meanwhile, here´s a preview:
Right, now the case modifying for the GPUs.
I trimmed this section a bit more to make sure there´s no contact, tomorrow I will clean up all the cuts:
Right, because the fittings are so big, my original plan of taking the pipes out the back is scrapped and I have to come up with an idea to take them out the side panel and still be able to open the case as needed, so here´s the solution. I cut the side panel so I can unlock and slide downwards in order to open it.
And to cover it up, and old school grill which I´ll cut to let the pipes through, this way in order to open it, I just unscrew the grill and slide open the side panel. Problem Solved.
More tomorrow hopefully.
737 (0.15/day)
coventry UK
System Name Gwafwar
Processor Ryzen 5 3600
Motherboard Msi MPG X570 Gaming Plus
Cooling Montech D24
Memory 16Gb Adata Spectrix 3600 Cl18
Video Card(s) XFX 7900 GRE
Storage Adata 512Gb SX8200 pro
Display(s) 3x 27" 1080p Lg's
Case Montech King 95 pro
Power Supply Coolermaster 750W Masterwatt
Mouse Saitek X65-f HOTAS
Software Win10 Pro
281 (0.06/day)
Málaga, Spain
That is an epic suggestion Iceni, and one I would definately test out if I wasnt on such a tight deadline : (, I was thinking on using one of these (was going to order tomorrow, was waiting on a response on sponsorship but they never got back to me).
http://www.aquatuning.es/product_in...ctor-Core-Extreme-V-Series-400mm---Green.html
I would paint certain parts of it and simulate some glass ageing effects to suit the project. It would be in a vertical position mounted on the top of the case
737 (0.15/day)
coventry UK
System Name Gwafwar
Cooling Montech D24
Software Win10 Pro
Just noticed another problem you mentioned earlier. The lack of flex in the copper pipework.
You could get some 3/8 flexable tap fittings, Rough them up and use them as the connectors to the block.
something like this.
it would give you the play you need to be able to make the copper work removable. Most hardware stores stock them so nipping out to the local builders merchant or DIY shop should yield results.
For that reservoir you have chosen why not put a copper coil in it. Get a length of microbore home radiator pipe. 8mm. Or copper brake pipe for vehicles. Then coil it up and drop it in. To break up the large expanse of acrylic.
281 (0.06/day)
Málaga, Spain
Hey iceni, I´m not quite sure what you mean with the copper coil? could you give me an example?
Also, about the flex, you missunderstood me, removing it is easy as the copper pipe joins the fittings without having to spin around either the fitting or the pipe, it has a nut in the middle that joins both by just turning that, not sure if that makes sense, english isn´t my first language.
737 (0.15/day)
coventry UK
System Name Gwafwar
Cooling Montech D24
Software Win10 Pro
yeah no problem.
Get some soft copper tube like i said and wrap it round something smaller than the res. A broom handle ect. Then just drop it in for decoration.
sort of like this but on the inside of the res.
If you wanted to go the whole hog with it you could also add a fake reservoir on the machine and put an ultrasonic fog machine in it.
I don't suggest what he does in the second part of the vid but the first part should give you an idea of what can be done to add steam to your steampunk.
http://www.youtube.com/watch?v=hzgqxEU0sVc
de.das.dude
Pro Indian Modder
9,169 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
281 (0.06/day)
Málaga, Spain
Update.
Today I´ve started to cut and test mount the side covers. While they look like wood, they are plastic and they are not the final look, they simply come like that from the store, I will be using vinyl and ageing process so they match the PSU. The same treatment will be done on both sides of the case.
Originally I was going to use rubber covers for the cuts so they don´t look sharp, however in order to add more "wood" to the design, I will be using the same parts cut in half as on the side, this should increase the wood/copper ratio of the final look.
I´ve also ordered all the liquid cooling stuff I need, and it will hopefully arrive on Friday so I have the weekend to mount everything and start and finish the front of the case so on Monday I can go to the plumbing suplies shop and cut, test mount and buy all remaining fittings and copper tubing to complete the loop.
If the parts don´t come by friday I´ll have to delay the plumbing details till tuesday or wednesday which will only give me a 2 day painting window to finish the project, so it´d definately cutting it short, but I feel confident at this point.
Aniway, photos!
Hopefully more tomorrow.
10,962 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
This... is.... freaking.... sweet.
2,406 (0.44/day)
London, UK
System Name Slick
Processor Intel i5 2467M
Motherboard Samsung Series 5 Ultrabook
Memory 8GB Corsair Value
Storage Crucial M4 7mm 256GB
Display(s) 13"
Software Windows 8 Pro x64
I like where this is going.
281 (0.06/day)
Málaga, Spain
Quick Update.
It doesn´t seem like much but it took me all the time I had to spare today to do this, the steel on this case is really stubborn (specially on the back where it´s thicker)!
Aniway, the screws I ordered (yes I had to order them, it seems no one locally had 3mm x 50mm screws) arrived and I they did the job perfectly, now the GPUs are properly secured.
And all the borders have been cut to size and test mounted. Some trimming left to do on them and adjusting for a perfect fit, but it´s really starting to take shape now.
Aniway, more tomorrow hopefully.
281 (0.06/day)
Málaga, Spain
First update of the day...
To freshen up your memory, this is what the front looked like once I had cut out everything I didnt need out of it, remember that originally it had 2 doors and all sorts of things.
So I cut a further section to incorporate a new idea I had for the front (which you will partially see by the end of this update but not completely by a long shot till, with a bit of luck, the second and final update of today (i.e. tonight).
I then filled it all up with epoxy filler.
Once it was dry I started with what will become a couple of hours of sanding.
That´s how it looked yesterday before I called it a day and went out for a drink as I needed to disconnect badly.
Today, I started fresh this morning at around 10am and continued sanding until it was ready.
Next I used a bit of filler for the places where it had created air bubbles and ended up empty and continued sanding until it was as ready as it was ever going to be with the limited timeframe I have left (I no longer feel my hands lol).
Next I cleaned it up and aplied the vinyl (yes the front will be going in that wood look, the same as the PSU).
I thend modified the picture frame I had bought so it will simply slide in and "hug" the bottom and sides of the frontal.
Lastly and more importantly, I aplied all the ageing effects to both the vinyl and the frame and put them togueter.
Later today I will be triming the leftovers and keep on working on the rest of the design of the frontal.
Until then.
2,704 (0.45/day)
System Name Dire Wolf IV
Processor Intel Core i9 14900K
Motherboard Asus ROG STRIX Z790-I GAMING WIFI
Cooling Arctic Liquid Freezer II 280 w/Thermalright Contact Frame
Memory 2x24GB Corsair DDR5-6600
Video Card(s) NVIDIA RTX4080 FE
Storage AORUS Gen4 7300 1TB + Western Digital SN750 500GB
Display(s) Alienware AW3423DWF (QD-OLED, 3440x1440, 165hz)
Case Corsair Airflow 2000D
Power Supply Corsair SF1000L
Keyboard Chuangquan CQ84
This is epic. Subbed!
de.das.dude
Pro Indian Modder
9,169 (1.71/day)
VR HMD ;_;
281 (0.06/day)
Málaga, Spain
thanks guys, I´m regaining feeling in my hands :S
281 (0.06/day)
Málaga, Spain
I know I said only one more update today... but I´ve just finished the front of the case, or at least until the package from Lamptron arrives, fingers crossed it arrives before friday or I wont meet my deadline.
Point is, I´m in love with how it turned out so I wanted to come upstairs and post it so you guys can see it.
So what I did is, using the back of the back plastic of the frame, I sanded it down and throw some matt black paint on it. I cut it down to size and fit it in the opening. I then added two screws on the back of the middle of the frontal of the case to hang the 2 mini-pocket-watches from. I then stack them to the back plate using a bit of hot glue.
Mounted the frame on the case to make sure it all looked ok before I screwed the frame in (with it´s glass).
All good, then I put the glass in and screwed the frame on to the frontal and aplied the same paint effect to the screws so they would not be visible. I also added the same effect to the borders of the glass to make it look old and stained.
And the result...
3rd and last update for today later on.
281 (0.06/day)
Málaga, Spain
Right, final small update of the day.
I am officially knakered, I need a shower, badly (lol), a bit of dinner, a movie, and bed, can´t believe the weekend is already over and work tomorrow :S
Aniway, I finished preparing two of the borders.
Vinyl:
Leftovers on the wall, yep.
And the ageing proccess aplied, i.e. final result:
And with this we reach 99 pictures on the project! I hope you all have a pleaseant evening and again, thanks for reading.
More tomorrow.
4,357 (0.88/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
281 (0.06/day)
Málaga, Spain
cheers mate : )
No Voodoo 2 here though : ( :p
