Project Thief - CaseLabs TX10-D Dual Workstation/Gaming Build - Gulftown and SB-E
211 (0.04/day)
So I received some more primochill LRT tubing that is definitely a different color than the previous stuff I have. It's not aging or the supplier because the existing stuff I have is of different dates and different suppliers. I contacts ppc's and they said to email primochill (although I do wonder if they shipped me feser by mistake). Either way we'll see what primochill says.
The difference looks 3-4x worse than the photo shows.
Also got some parts that were correctly manufactured (EK D5 top and lots of drain ports):
Bunch of fill ports:
I also got done with the clearcoat on the radiator so I could finally take the masking tape off:
Then I built a quick and dirty tap handle:
We'll see how it works, I may have to buy one but thought I'd try this first.
I attached the D5 top to the res with a rotary male to male connector. There was about 3/8" gap between the mounting plate and the motherboard tray though, so I picked up a rubber table leg weight distributor that felt like it would be good for damping vibrations. It's just the right size to hide behind the mounting plate. I had to shave it down a bit though as it was more like 1/2":
Here it is hiding:
If it's visible from the window, I'll have to replace it, but I think it's good. Here it is with the plate bolted down lightly (the barb is temporary):
Here it is mounted from the front:
HammerON
The Watchful Moderator
8,400 (1.45/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
Thanks for the nice update:toast:
211 (0.04/day)
I made a review of the TX10. I hope it's helpful and that people like it. It's not exactly professional (iphone ftw) but I tried to do my best with what I had. To give you an idea of the scale of the case - I'm 6ft 5, so it's pretty big.
http://youtu.be/3a7kKKPs6J8
Let me know any feedback you have to improve it (or future videos). This case is a tough subject to review, simply because there are so many things to cover. I don't particularly like the ending, I'm thinking of adding on a real conclusion, but for all being one take I think it's decent :thumb:
Stren!
2,230 (0.38/day)
Look up. Look way up.
System Name Ultimate Vortex III
Processor Intel Core i7-9700K
Motherboard Asus ROG MAXIMUS XI GENE
Cooling Cooler Master Hyper 212 Black Edition
Memory Corsair Vengeance LPX 16GB (2x8Gb) DDR4 DRAM 3200MHz C16
Video Card(s) Sapphire Pulse AMD Radeon RX 7700 XT - 12 GB
Storage 2 x WD Blue SN550 1Tb NVMe in RAID 0 Striped Set
Display(s) TUF Gaming VG279QL1A 165 Hz
Case Cooler Master MasterBox Pro 5 ARGB
Power Supply Coolermaster Silent Pro 850W
Mouse Corsair RGB
Keyboard K70 Rapidfire with Cherry MX Speed
Software Windows 11 Pro x64
Subbed! OMG!!! :eek: I'm afraid to ask how much you're spending on this!!!! Nice stren!
211 (0.04/day)
So I finally tidied up the house. For some reason the wife was unhappy with every available surface being covered with stuff. This means I can start processing some photos.
So I started off by putting together the workstation upgrade. My gaming rig can be down, but I still have to work, so that's the first priority. The workstation consists of two loops:
1. i7-3930K - Mora3 140x9 - Dual PMP450S (D5 Strong)
2. EK R4E full cover block - 2 EK ram blocks - EK 8800GT block - D5 Vario - EK 250 cylinder res
As most of loop 2 was done, I started work on loop 1. So I started off mounting the fans to the mora3. Here it is with the CaseLabs "Super Mount". There are four dedicated mounting points independent of the fans which is nice:
This means you can just mount the fans to the supermount and not the radiator:
This is useful for cleaning because you can just undo the four mounting screws between the supermount and the rad. I.E. You don't have to remove every single fan for cleaning. FYI the fans are low speed 140mm yates (700rpm). I chose these because I wanted something cheap and quiet, and yates are both of those when at 700rpm.
Here's the super mount with fans mounted placed on top of the rad:
Then I attached the rad to the super mount:
The only downside to this is a tiny gap between the fan and the rad. However it's small enough that I don't think it will cause a problem:
Here it is mounted in the top of the case:
I then attached the quick disconnects to the CPU block for loop 1. Originally they were going to attach to the case and then have compression fittings on the cpu block. However there wasn't enough room to make the 90 degree turn, so i think this works better:
In the final setup I'll have some bitspower pass throughs that go to the top chamber. For now the tubing curves around to the drive bay area where the temporary reservoir and pumps are:
Again you can see the pink vs red tube. Primochill have shipped me some replacement tube - so props to them for taking care of it.
Easy Rhino
Linux Advocate
15,636 (2.35/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
mother of god...
3,145 (0.65/day)
Processor 8700k Intel
Motherboard z370 MSI Godlike Gaming
Cooling Triple Aquacomputer AMS Copper 840 with D5
Memory TridentZ RGB G.Skill C16 3600MHz
Video Card(s) GTX 1080 Ti
Storage Crucial MX SSDs
Display(s) Dell U3011 2560x1600 + Dell 2408WFP 1200x1920 (Portrait)
Case Core P5 Thermaltake
Audio Device(s) Essence STX
Power Supply AX 1500i
Mouse Logitech
Keyboard Corsair
Software Win10
The motherboard seems a micro ATX inside that case :D
I like the idea of quick disconnects on the cpu, it's practical! Too bad they don't make black coloured quick disconnects.
Awesome job stren! :toast:
Aquinus
Resident Wat-man
13,173 (2.78/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
What loop will the top radiator be on? Do you have a diagram or what you have in mind for your finished loops? Great update to the log by the way. You should take a video of it with it running when you're done too.
211 (0.04/day)
mother of god...
:cool:
Thanks dude. Yeah Koolance doesn't think there is demand for black lol. Monsoon are looking into it, but nothing definite.
II think there should be a diagram on the first page although it's not 100% correct lol. There will definitely be vids :)
Here's another update:
So to build the workstation loop I also needed a rx360 rad from my gaming rig. So this meant that it was time to take the gaming rig apart. Here you can see it minus one fan that was clicking and had been removed. Yes you can cool 3 480's, a 920 and motherboard block with 5xAP15s but yes your water gets pretty warm lol.
So once the radiators were removed, I could take some side by side pics with the new case:
Yes the TX10 is huge!
So enough posing, it's time to take the guts apart:
You can see how the window was hiding some messy wiring. I hadn't bothered to tidy and sleeve much after putting in the Koolance res and STX because the TX10 was already on the way.
Lots of dust to be cleaned, here you can see the "saddlebag" setup of the external rads
About to take the fans and reservoir out:
Top fan and PSU removed:
Parts on the ground, parts on the ground looking like a fool with my parts on the ground!
The STX is a sexy card:
2,702 (0.45/day)
System Name Dire Wolf IV
Processor Intel Core i9 14900K
Motherboard Asus ROG STRIX Z790-I GAMING WIFI
Cooling Arctic Liquid Freezer II 280 w/Thermalright Contact Frame
Memory 2x24GB Corsair DDR5-6600
Video Card(s) NVIDIA RTX4080 FE
Storage AORUS Gen4 7300 1TB + Western Digital SN750 500GB
Display(s) Alienware AW3423DWF (QD-OLED, 3440x1440, 165hz)
Case Corsair Airflow 2000D
Power Supply Corsair SF1000L
Keyboard Chuangquan CQ84
Oh. My. God.
You, sir, are a madman. And I mean that in the best way ever imagined.
Salute!
Aquinus
Resident Wat-man
13,173 (2.78/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
You should get a beagle board or RaspberryPi or some development board and build yourself a controller for the entire box. That way you can hit a button, first your cooling powers up, sends back an OK, then fire your rigs up and if you have LED BIOS output headers you could send an OK back when the BIOS is done loading. Not that your rigs needs to be any more beastly than they already are. :p
Easy Rhino
Linux Advocate
15,636 (2.35/day)
Mid-Atlantic
System Name Desktop
Mouse MX Master 3s
my question is since you have everything water-cooled then why so you need all the fans?
Aquinus
Resident Wat-man
13,173 (2.78/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
Heat exchangers use fans too. Water just moves the heat away from the CPU, something has to move heat away from the radiator and keep ambient temps low. Also note how almost all the fans are on a radiator.
Easy Rhino
Linux Advocate
15,636 (2.35/day)
Mid-Atlantic
System Name Desktop
Mouse MX Master 3s
ah ok, that was my hunch.
Huddo93
299 (0.06/day)
Perth, WA, Australia
System Name Gaming Rig
Processor i7 2600k @ 4.5GHz
Motherboard Asus Z77 Deluxe-V
Cooling Corsair H100
Memory RipjawsX 8GB @ 2133MHz 11-11-11-30
Video Card(s) EVGA GTX670 SC @ 1300MHz core
Storage OCZ Vertex 4 256GB + 1TB Samsung HDD
Display(s) 23" LG W2343T
Case Corsair 650D
Power Supply Corsiar AX-850
Holy crap, only once you put the other case next 2 it, did I really take full understanding of just how huge it is! Holy s**t!
4,016 (0.67/day)
Ohio
System Name Desktop|| Virtual Host 0
Processor Intel Core i5 2500-K @ 4.3ghz || 2x Xeon L5630 (total 8 cores, 16 threads)
Motherboard ASUS P8Z68-V || Dell PowerEdge R710 (Intel 5520 chipset)
Cooling Corsair Hydro H100 || Stock hotplug fans and passive heatsinks
Memory 4x4gb Corsair Vengeance DDR3 1600 || 12x4gb Hynix DDR3 1066 FB-DIMMs
Video Card(s) MSI GTX 760 Gaming Twin Frozr 4GB OC || Don't know, don't care
Storage Hitachi 7K3000 2TB || 6x300gb 15k rpm SAS internal hotswap, 12x3tb Seagate NAS drives in enclosure
Display(s) ViewSonic VA2349S || remote iDRAC KVM console
Case Antec P280 || Dell PowerEdge R710
Audio Device(s) HRT MusicStreamer II+ and Focusrite Scarlett 18i8 || Don't know, don't care
Power Supply SeaSonic X650 Gold || 2x870w hot-swappable
Mouse Logitech G500 || remote iDRAC KVM console
Keyboard Logitech G510 || remote iDRAC KVM console
Software Win7 Ultimate x64 || VMware vSphere 6.0 with vCenter Server 6.0
Benchmark Scores Over 9000 on the scouter
You could fit a small child in it.
t_ski
Former Staff
11,960 (1.74/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
"Honey, have you seen our kids? Oh, nevermind - they're hiding in the server again..."
de.das.dude
Pro Indian Modder
9,157 (1.72/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
2,863 (0.47/day)
Brasil
System Name Sovereign // HTPC
Processor i7 3770k 4.2 // i7 3770k 4.2
Motherboard Maximus V Gene // Sabertooth Z77
Cooling Noctua D14 // Intel HSF
Memory 16GB Samsung // 16GB VengeanceLP
Video Card(s) Deciding // 660 DC2
Storage OS (X25-M), Data (Seagate 1TB) // Samsung 840 120GB & bunch of drives
Display(s) Samsung T240HD // LG TV
Case TJ08e // Grandia GD08
Audio Device(s) DT880 Pro 250 ohm // TV speakers
Power Supply Seasonic Plat 1000 // Seasonic Gold 760
Software Windows 8 Pro x64 // Windows 7 Pro x64
Fuck i just jizzed in my brain. Dude, since the first build, did you get like an apple ceo year bonus? I mean the wc gear is worth how much? 4k?
Nope, a bigass child(s) could fit there
Also should be named project barbarian, aint no thief big like that.
This is D3 barbarian or Conan build
211 (0.04/day)
Oh. My. God.
Salute!
Haha thanks :)
Yeah I was thinking of a raspberry pi - at least for monitoring temps, fans and pumps etc
This is very true, you're just shifting heat around and spreading it out effectively, there will be a couple of fans that aren't on radiators just to keep airflow moving over the board and of course in the PSUs
a couple of them :)
Yeah it's enormous. I was going to take it around the city and take photos of it next to things, but I can't fit in my car, so that's not going to happen haha.
lol
Lol that's a very good point! Yeah I try not to think of the cost! But yes the wc gear is a lot of money!
211 (0.04/day)
Alright so more photos taking the old rig apart - we left off by removing the pci cards and the power supply:
So now let's remove the cpu block and check the tim spread:
Not the best but not awful. Now time to take the motherboard out:
Out it comes:
Which leaves a sad empty and dusty case!
Now it's time to take apart the rad setup:
Remove the steel bars:
Then the fans:
I noticed one side of the rads now had white stains on them, these were the sides on the top:
Compared side by side to the underside (bottom rad):
Anyone know what that is?
