Prolimatech Magnetic Pin to Make Shuffling Fans Around a Case Snappy
652 (0.13/day)
Fresno, CA
System Name LS Vtec B18B1 Bolt Ons
Processor AMD Phenom ii 1045t x6 @ 3.5Ghz OC
Motherboard ASRock 970 Extreme3 R2.0 AM3+
Cooling CM Hyper 212 EVO Push Pull
Memory CORSAIR Vengeance 8GB (2 x 4GB) Black 1600Mhz
Video Card(s) Sapphire 7950 Dual-X
Storage Samsung EVO 250gb SSD/Samsung 500gb 7200 rpm/WD Cavirar Green 1TB
Display(s) Acer H236HLbid IPS
Case NZXT Gamma (Powder Coated Champion White)
Audio Device(s) Creative Lab SB0460
Power Supply NZXT HALE82 V2 550W
Software Windows 7 Ultimate 64bit SP1
Benchmark Scores Vtec
not bad at all
13,791 (1.86/day)
If you are getting a super light aluminium case you probably want to move the case around quite often, I think you would want to screw the fans down securely instead. Non issue I think.
Not really, i have such light case because i often move it from where it usually stands upt o my desk where i tweak it. I've had a steel case in between and it was a total pain to move half a meter distance because it weight a freakin ton in case alone.
4,213 (0.71/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
My hard drive get really hot. With these i could easily attach a fan to keep them nice and cool. [/Troll]
Edit - Seriously tho, i can see dumb-asses doing this
Mussels
Freshwater Moderator
58,413 (7.88/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
I know magnets and computers didn't mix in the good ole' days, but are magnets completely safe inside a case nowadays? I'd hate to have my bios wiped because one of these fell off and landed on the rom.
EEPROM
Electronically Erasable. Small magnets wont do anything to a modern computers parts, except for magnetic hard drives - and even then, these would be too weak to have an effect.
the awesomeness of these gets reduced once you take into account that the wires to the fan wont come off with the fan - so if you do cable management or use zip ties, it doesnt give you that much extra freedom.
popswala
2,257 (0.39/day)
Conway, AR
System Name Deep Space // Black Mystery
Processor AMD Phen II X4 945 oc'd 3.4GHz // I7 870 oc'd 4.0GHz
Motherboard Gigabyte 990FXA-UD7 AM3+ // MSI P55-GD80
Cooling Corsair H50 w/ x2 gelid wing blue 120mm // Tt Frio OCK
Memory G. Skill Snipers DDR3 1600 2x4GB // G.Skill Tridents DDR3 2000 2x2GB
Video Card(s) eVGA GTX 275 // eVGA GTX 460 SC 768mb oc'd (830/1620/2000
Storage Seagate 1TBx2 7200.12 /1.5TB/500GB/750GB // Mushkin Collistro 60GB
Display(s) LG 23" 2353v-pf 1920x1080p // None
Case Tt Chazer MK-1 // NZXT Phantom black modded
Audio Device(s) Logitech G51 5.1 // None
Power Supply Cooler Master Silent Pro Hybrid 850w // Corsair HX1000W
Software Win 7 Ult X64 // Win 7 Ult X64
Benchmark Scores Crunching & Folding 24/7 Help Save Lives!!!
That is a shame no ones thought of these yet. That is a pretty neat idea. Will have to look into these and see if they do ever make them in other colors. That blue might just kill it for some ppl.
OneMoar
There is Always Moar
8,802 (1.63/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
this is something you could make even
get some magnets epoxy some plastic bolts to it profit ?
3,298 (0.53/day)
System Name Thakk
Processor 9800X3D
Motherboard MSI B650M Gaming Wifi
Cooling Id Cooling A410 + 2400 RPM push pull
Memory 32GB DDR5 6000 C30
Video Card(s) Zotac RTX3080 Trinity
Storage Crucial NVME 512 / Intel 250GB SSD / Samsung Pro 512 SSD / SanDIsk 1TB SSD / WD Black 6TB
Display(s) Acer Predator X34 100hz IPS Gsync
Case Generic mATX
Audio Device(s) Hyper X 7.1 USB Soundcard
Power Supply Corsair CV750 Bronze
Mouse Logitech G200
Keyboard Monsgeek MG75S Hall Effect + XDA Keycaps + Holee Mod
VR HMD HTC Vive
Software Windows
Benchmark Scores https://www.3dmark.com/3dm/123890762?
de.das.dude
Pro Indian Modder
9,154 (1.72/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
i use four tiny triangles of industrial double sided foam tape to attach fans. works good. the adhesive doesnt leave any residue.
9,899 (1.69/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
Seen this before.
Does no one go on the fans and fan accessories section on e-shops?
427 (0.08/day)
Iraq
System Name Simon
Processor Core i7 5820K @ 4.4GHz @1.25v core, 1.9v input, 1.12v system agent, 0.9v cache - 24/7 & P95 stable
Motherboard ASUS X99 Deluxe U3.1, BIOS 3101
Cooling Corsair H110i GTX + 2 x Corsair ML140 Pro Red LED, exhaust @ top panel
Memory Corsair Vengeance LPX 4x 8GB 2666 MHz 16, 18, 18, 35, 2T (Stock)
Video Card(s) MSI GTX 1080 Gaming X (OC BIOS), +60 MHz GPU, +450 MHz Memory
Storage Samsung 960 Evo 500 Gb, WD Green + White Label, total 17 TB
Display(s) 3x Samsung CFG73 (24" 1920x1080, 144Hz) in 2D Surround, LG C7 OLED TV (55", 4K, 60Hz)
Case Corsair 760T + Corsair SP120 Perf.Ed. + 3x ML 140 Pro Red + DEMCI Dust Filter Kit + DeepCool RGB LED
Audio Device(s) Creative SB Z, Topping E30 + SMSL SP200, Hifiman 4XX, beyerdynamic 770 250Ω, Audeze iSine 10, HD6xx
Power Supply Corsair RM1000i + APC BackUPS RS1500 (modded w/ 130 AH Kung Long Batteries) + APC Smart UPS SUA1500i
Mouse Razer Naga Chroma + Reflex Lab Extended Mouse Pad + Xbox One S Controller + 3 x Xbox 360 Controllers
Keyboard Corsiar K70 RGB (2016 Edition) Cherry Mx Red w/ custom Arabic-legend shine-through keycaps
Software Windows 10 Pro x64 - ver. 20H2
Benchmark Scores Onkyo TX-NR626 AV Receiver, speakers: 4x Yamaha NS-M325 + Yamaha NS-C3290 + Proson Libre Sub 8.1
My 4 years old zalman fans came with similar pins, except that they didn't have magnets.
