PSA: don't use alcohol on acrylic tubing.
l1CappYl1
16 (0.35/day)
China
Broke down my computer to give it a good cleaning. Noticed my tubing was still looking frosty inside so I tried spraying some alcohol in it to try and rinse it out. Within seconds cracks formed and it became brittle, breaking apart easily in my hands.
Dunno if that was common knowledge or not, but I didn't see any posts about it, so it doesn't hurt to share.
3,616 (2.49/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
Also don't use alcohol or other volatile solvents to clean surfaces painted with acrylic paint.
2,943 (2.07/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
Plexiglass/Acrylics are soluble in IPA and it will destroy it within seconds.
7,602 (1.48/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
It is common knowledge.
But it was bad eitherway. Not surue but I never liked hard tubing, maybe pure copper ones, but nope. I like how black tubes look, gives me HR Giger vibes lol.
l1CappYl1
16 (0.35/day)
China
Soft tubing is definitely much quicker and easier to set up. I don't mind the extra work for hard tubes, except for the sawing. That part sucks.
1,944 (0.75/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@Ferrum Master
naah. clear tube, solid black fluid :D
still haven't found one in opaque, where you see movement in the coolant.
Ruru
S.T.A.R.S.
13,015 (2.96/day)
Jyväskylä, Finland
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-K
Storage 3.3TB of SSDs / several small SSDs
VR HMD Oculus Rift CV1
Measuring and bending is the only thing which really sucks with hardtubing.
42,684 (6.68/day)
In the bends material does get thinner
l1CappYl1
16 (0.35/day)
China
@Ferrum Master
I don't use colored coolant as it tends to stain everything. After this experience, I'm going to go with frosted tubing for my next build.
For me it's the cutting, which I've hopefully solved with the purchase of a mini table saw.
1,944 (0.75/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
@l1CappYl1
depends a lot on the brand.
i had brightly green (solid) coloring, and after +2y in an (unprepped) loop, had left less stains, than the clear blue additive in less than 8 month,
and that was when i used sys-prep to coat the inside of tubing/loop.
7,602 (1.48/day)
Rīga, Latvia
Software FEDORA 41
@Ferrum Master
You run it on crude oil? Mine is violet now, I use antifreeze + distilled water like 1:4 or 1:3 ratios, my mixed metal experimental loop with aluminum rads do not corrode with that solution. 4 years long test 1 and 2 years test 2 build. No additives needed for me.
I use 10/16 EPDM tubes, they have less problems with bending, just pick a proper angled fitting, zero problems there, I even have used same sized nitrile gasoline tubes, only you have to flush the before, car stuff is crazy dirty, but cheap and eveywhere.
1,944 (0.75/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
@Ferrum Master
cant find dark opaque anymore, probably going with white on the next case change (and loop rebuild).
white
dont care for additives besides biocide+distilled water, but wanted to see how their premixed coolant holds up.
7,602 (1.48/day)
Rīga, Latvia
Software FEDORA 41
Modern antifreeze car solutions have all additives you need also. And you can pick your color too... cheap, safe, good looking. Rare combination these days. Those pastel like coolants are not for me.
You can try yellow, you could imagine what it would look like :D :roll:
1,944 (0.75/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
too many variable and no long term large scale testing i have seen that makes them safer, just preference.
yeah, wasnt for me either, until is saw the ones where you can see "swirls", but they are only for short use.
show coolant
either this, or white.
haha, the solid one looks cool, clear, not so much :D
42,684 (6.68/day)
Make sure its a fine tooth saw and not coarse
3,864 (0.59/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
@Ferrum Master
could always put in a flow indicator wheel
Or for full on bragging rights could put in an EH picomag with flow and temp readout............but if you do you'll have to go all out and use swagelok tube and fittings just because.......
6,267 (1.53/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
So the lesson here is:
If you're drinkin, don't go tubin....
If you're goin tubin, don't drink, hahaha :roll:
But seriously, I always thought this was common knowledge, just like not mixing bleach & ammonia, or hot engines with cold water :D
1,944 (0.75/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
@mechtech
already have that.
with "movement" i didnt mean the flow (of coolant) but having different shades producing swirls like you see with fluid dynamics, but the ones i find are all for show builds,
and cant be used for longer.
lol, got a temp display on the board, i'll know if the pump stops.. :D
@bonehead123
and yet, ppl are pouring hot water on frozen windshields :banghead:
460 (0.10/day)
Quodam loco Albanianae
System Name The Dark side of the room
Processor AMD Ryzen 9 5900X
Motherboard MSI MEG X570 Unify
Cooling Custom loop watercooling (Bykski CPU-XPR-POM-M-V2, Alphacool Eisblock GPX, Freezemod PU-PWM5B18W)
Memory GSkill Ripjaws V DDR4 3600 CL16 (4 x 16GB)
Video Card(s) XFX Speedster QICK 319 Radeon RX 6700 XT
Storage 1 x Kingston KC3000 1024GB (boot drive) + 2 x Kingston NV2 2TB (games & storage)
Display(s) LG 34WP65C Ultrawide 3440x1440 @ 160Hz freesync premium
Case Thermaltake Core P90 TG (slightly modded)
Audio Device(s) onboard Realtek® ALC1220 with Logitech Z906
Power Supply MSI MAG A850GF 80 Plus Gold
Mouse Generic
Keyboard Sharkoon Skiller SGK60 (with brown Kalih switches)
Software Windows 11 pro
Benchmark Scores It's a form of exhibitionism...;-), but fun in a way But showing off is triggering.............
@ |1CappY|1, just use some mild dishwasing soap it should do the trick.
You can also use some soft cloth to apply a little pressure on the stains when cleaning.
Then make sure it is rinsed properly with distilled water to removed all the soap residues.
Ethanol (Ethyl alcohol), like Methanol (Methyl Alcohol) will ruin them as you noticed, however IPA (Iso-Propyl-Alcohol) @ room temperature is compatible and won't damage it.
However IPA is not available everywhere in some countries/regions it is restriced (controlled substance) as it is used for manufactering illegal stuff o_O.
If you want to know more about chemical compatibillity of PMMA see link below:
https://marketing.industrialspec.co...mma-chemical-compatibility-chart-from-ism.pdf
l1CappYl1
16 (0.35/day)
China
Much more expensive and not easily obtainable where I am. Lesson learned and no real harm done. Turns out I was going to have to re tube anyways as my replacement GPU is longer and won't fit my pump/reservoir in the same orientation.
28,295 (6.75/day)
It's not as common as one might think.
This is a good PSA.
