PSA: Intel I226-V 2.5GbE on Raptor Lake Motherboards Has a Connection Drop Issue: No Fix Available
22,020 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Software Gentoo Linux x64
Which means it's likely not a hardware problem.
Or FreeBSD just has a more effective work around Intel refuses to implement in mainline drivers for whatever reason. Either way, hardware errata exists. That's already been established.
200 (0.13/day)
Processor 265K (running stock until more Intel updates land)
Motherboard MPG Z890 Carbon WIFI
Cooling Peerless Assassin 140
Memory 48GB DDR5-7200 CL34
Video Card(s) RTX 3080 12GB FTW3 Ultra Hybrid
Storage 1.5TB 905P and 2x 2TB P44 Pro
Display(s) CU34G2X and U2724D
Case Dark Base 901
Audio Device(s) Sound Blaster X4
Power Supply Toughpower PF3 850
Mouse G502 HERO/G700s
Keyboard Ducky One 3 Pro Nazca
Supposedly they finally fixed everything with these drivers: Windows 11 driver to 2.1.3.15 or Windows 10 driver to 1.1.4.42 and sounds like there may be a motherboard/firmware update as well, but I didn't see it on vendor sites.
I'd still love to know what part was the issue because the windows drivers are significantly more featured than *nix (so there's a lot more to go wrong) and even then not everyone on windows was seeing the issues. I know I certainly didn't while I had windows running, but that system was also hooked up directly to one of my router box i226s so it wasn't going through a switch/router.
1,019 (1.38/day)
System Name Never trust a socket with less than 2000 pins
As mentioned above, the most likely explanation is that FreeBSD simply lacks those power management features that presumably cause the problems on Windows.
In any case, the FreeBSD driver is open source, so it could be ported as an alternative driver to Windows.
3,899 (1.74/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Any idea where to get 1.1.4.42 from? after a while searching I managed to find 1.1.4.38, Intel seem to be hiding the Windows 10 specific drivers now and interestingly is none on WU.
139 (0.06/day)
Should be on your mobo support site. I just checked on MSI and it shows that driver for Win 10.
200 (0.13/day)
Case Dark Base 901
The 28.3 driver pack has that driver version, but it doesn't list the i226-V so I'm not sure whether it's covered or not. Check the date of the driver release on your motherboard OEM and if it's late last year it might be correct whether it cites the right version or not.
3,899 (1.74/day)
UK, Midlands
System Name Main PC
Processor 13700k
I am using it on a NUC sourced from china. :)
I will grab from MSI then thanks and add to my ISO.
60 (0.02/day)
Its mid 2024 and while testing i226 on a Proxmox/OPNsense machine I have issues with weird speed drops and network drops
I immediately sold it. Dropped in 8125BG and never looked back (Wish my ONTs have SFP+ so I can hook my BCM57810s directly but alas no...)
(Not surprised to see kiriakos being stupid in here, I remember on OCN he was known for that and got banned eventually)
