PSU question Regarding GPU upgrades
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
I might get an additional FuryX as well as upgrading my 5820K to an used 5960X. Right now I am using EVGA supernova g2 850watt PSU, Would it be possible for this 850watt PSU to handle two FuryX along with an overclocked 5960X?
Thanks!
2,100 (0.47/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
No problem at all.
18,584 (2.66/day)
System Name AlderLake
5,717 (0.93/day)
Damn looks like I have to get a 1200Watt PSU then. This might be too much then
I find the wattage calculator pretty accurate. My APC UPS reported highest power usage was around 650Watt while the calculator predicted my current system to be around 630~640 watt.
2,100 (0.47/day)
Spencerport NY
System Name Master
I find that most calculators are grossly over rated.
Do the math yourself
FuryX = 220w x 2 = 440w
5960x = 140w
Everything else in your case = 50w
Total = less than 650w
and mind you, these are at full loads that you'll likely never see in normal usage.
850w PSU is fine.
Overclock everything.....and you're still fine.
5,717 (0.93/day)
5960x = 140w
850w PSU is fine.
According to your calculations mu current 5820K with one single Fury X should be less than 430watt full load. Yet here is a picture of my system under actual full load.
2,100 (0.47/day)
Spencerport NY
System Name Master
If efficiency is 80% the loss will be 20% so your draw at the wall will be 120% of the power drawn from your PSU. Your current system is using less than 500w at full load, and that's assuming you're getting true 80% efficiency.
1,125 (0.36/day)
System Name Team Crimson
Processor AMD FX 8320
Motherboard Gigabyte GA-78LMT-USB3
Cooling Corsair H80i
Memory DDR3 16GB Crucial Ballistix Sport
Video Card(s) Sapphire Nitro+ RX 480 8GB RAM
Storage Samsung 850 EVO 250GB / Crucial MX300 275GB
Display(s) AOC 2752H 27" 1080p
Case NZXT Source 220 Windowed
Power Supply Antec Earthworks 650W
Mouse Logitech M510/ AGPTEK T-90 Zelotes
Keyboard Logitech K360/ iBUYPOWER TTC RED Switch Mechanical
Software Windows 8.1 64 Bit
5960x = 140w
850w PSU is fine.
These Calculators designed for PSU sellers always overestimate the power needed. The reason being quite simple---they want to sell you a more expensive unit!
2,100 (0.47/day)
Spencerport NY
System Name Master
19,376 (3.51/day)
Thanks!
absolutely... Even with overclocking.
one fury x and a 5820k... 620? what else is plugged in to the ups? what is "full load"? you do understand that is pretty much impossible, and us really obviously so, no?
220-240W is average not the max for a single Fury X
https://www.techpowerup.com/reviews/AMD/R9_Fury_X/29.html
Oy... just oy...
776 (0.24/day)
His PSU has 90+% efficiency
2,100 (0.47/day)
Spencerport NY
System Name Master
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=377
Nitpick all you want. It won't change the fact that the PSU is more than enough for his intended upgrade. It will never be loaded enough to worry about under normal everyday conditions including gaming or crunching.
Don't wanna believe the truth?, then spend your money on an overkill PSU that you'll never need instead of better GPU's or ram that you always need. It's your money. I couldn't care less what you do with it.
776 (0.24/day)
Might try stock clocks of the CPU , run a game and see the consumption
Let s adopt TPU calculations
Fury X x 2= 280W x2 =560W
CPU stock - 140W
other 100W
800W , might give it a try
If it gets hanging or restarting , new PSU
19,376 (3.51/day)
19,376 (3.51/day)
The CPU i7 3770K OC 4.8GHz
Yes, I said that already... Add 50W for an overclocked HEDT chip... that equals 700W on an 850W PSU...
For the umteenth time, a quality 850W PSU like he has is FINE.
God only knows what his UPS is reading or what else he has plugged into it. If that is just the System only, I am trying to figure out how in the world its possible to be pulling ~550W ACTUAL out of the system in his signature.
776 (0.24/day)
Perhaps not out . Or the readings got spikes
Frick
Fishfaced Nincompoop
19,819 (2.86/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
505 (0.13/day)
Cyprus
Processor 13700KF - 5.7GHZ
Motherboard Z690 UNIFY-X
Cooling ARCTIC Liquid Freezer III 360 (NF-A12x25)
Memory 2x16 G.SKILL M-DIE (7200-34-44-44-28)
Video Card(s) XFX MERC 7900XT
Storage 1TB KINGSTON KC3000
Display(s) FI32Q
Case LIAN LI O11 DYNAMIC EVO
Audio Device(s) HD599
Power Supply RMX1000
Mouse PULSAR V2H
Keyboard KEYCHRON V3 (DUROCK T1 + MT3 GODSPEED R2)
Benchmark Scores Superposition 4k optimized - 20652
The g2 is a good psu and i think it gives more than 850w if necessary (when new atleast) , also i do not think you will use 100% CPU and both GPUs at the same time so there is that.
Note that the PSU fan might be loud when drawing 750-800w , which im certain it wont reach that much.
2,724 (0.41/day)
Blighty
Processor R7 5800x3D
Motherboard MSI x570 Tomahawk
Cooling XSPC Raystorm Edge,EK QS P420M,EK D5pwm Revo Res
Memory 32gb Corsair Vengeance RT 3600 cl16
Video Card(s) Zotac 3070ti Amp Extreme
Storage Samsung 980pro 1tb x2
Display(s) MSI MPG321QRF QD
Case Corsair 7000D
Power Supply EVGA 1000 P2
Mouse G900
Keyboard Corsair k60 RGB PRO
Software Win 11
If you are going to overclock the furies i would certainly get a larger psu, they can go well over 300w per card overclocked
I ran overclocked 390's on an 850w xfx (seasonic based) and the things fan run full pelt in gaming
imo you should get a 1000-1200w psu, it may run on an 850 but it will be under a fair bit of stress and therefore noisy
a reliant robin can do at least 70mph, but i wouldnt want to use one for a daily motorway commute..
19,376 (3.51/day)
Umm, he doesn't have a POS PSU though...he has one of the best out there in the 850W supernova g2.
Just to put things into perspective, I ran a 295x2(500w card stock) overclocked and a 5820k overclocked to 4.5ghz on the G2 750W psu. The fan did spin up under load but the only reason I knew it was because I saw it, not because I heard it. Very quiet fans. 1KW+ is overkill... I dont see the point.
64K
6,773 (1.70/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
You should be fine with that PSU. It really is high quality. That 650 watt pull from your APC isn't how much the PSU is providing for your system due to inefficiency. The PSU is rated to provide 850 watts to your system. Also a quality PSU like the one you have also has a reserve capacity so you aren't in danger of overloading it.
1,125 (0.36/day)
I wonder how many of these people who are so hypercritical when it comes to the Power Consumption of various GFX cards, are running a PSU that is overkill for the power needs of their machine?
4,994 (0.69/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
I just wanna chip in with a quick tidbit.. These PSU's seem incredibly well made, mine is running almost 24/7 crunching/folding/gaming, varying between 650-820W measured at the wall depending on gpu clocks, and even seen up to 900W when running firestrike. I guess that's still around 800W when you factor in efficiency, but what impresses me is how the thing never really gets warm at all, the fan doesn't even spin up much either. I'd recommend the OP get a wattmeter so you can see what's going on, but I don't think that 850W psu is going to have any problems at all, the rating seems very conservative.
