Quadro View not available/installed despite being selected (NVCleanstall 1.9.0)
BenJW
3 (0.00/day)
Hi, I'm facing an issue with installing Quadro View on my Laptop which has a Quadro P2000: I chose "best driver" option (466.11-notebook-win10-64bit-international-dch-whql) and checked all components above/except the GeForce Experience Components, including Quadro View. I then continued through NVCleanstall and disabled both installer and driver telemetry, and enabled MSI. However, after the actual NVIDIA installer is finished, Quadro View is not available and cannot be started on my system. When chosing custom installation in the NVIDIA installer, it also does not show Quadro View as selectable component.
W1zzard
Administrator
28,154 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
When you install the driver normally, without NVCleanstall, do you get a working Quadro View installation?
770 (0.15/day)
Germany
System Name Acer Nitro 5 (AN515-45-R715)
Processor AMD Ryzen 9 5900HX
Motherboard AMD Promontory / Bixby FCH
Cooling Acer Nitro Sense
Memory 32 GB
Video Card(s) AMD Radeon Graphics (Cezanne) / NVIDIA RTX 3080 Laptop GPU
Storage WDC PC SN530 SDBPNPZ
Display(s) BOE CQ NE156QHM-NY3
Software Windows 11 beta channel
Looks like NVCleanstall does not copy the folder Display.Nview
BenJW
3 (0.00/day)
So I guess the installer for Quadro cards in laptops should actually be "466.11-quadro-rtx-desktop-notebook-win10-64bit-international-dch-whql". If I run that directly and go for custom setup, I get the option "RTX Desktop Manager", which is the new name for Quadro View. If I use NVCleanstall and "Use driver files on disk" with the same installer, the installer will not show the "RTX Desktop Manager" as available option, despite checking "Quadro View" in NVCleanstall.
BenJW
3 (0.00/day)
Hi, I just wanted to ask if this is planned to be fixed in (one of) the next release(s)? Thanks!
44 (0.01/day)
I see no mention of a fix in the release notes for 1.10 so assume this is still broken :(:(
W1zzard
Administrator
28,154 (3.72/day)
Memory 48 GB
Haven't had time to look into this, sorry
770 (0.15/day)
Germany
Memory 32 GB
W1zzard
Administrator
28,154 (3.72/day)
Memory 48 GB
@Methanoid can you check if this test build solves the problem?
W1zzard
Administrator
28,154 (3.72/day)
Memory 48 GB
I could if I could find where to DL a test build ;-)
The file icon in this post
44 (0.01/day)
Thanks, that fixed the issue for me... I was able to build the final EXE driver with the various tweaks selected :cool:
