Question burn mdisc and test drive
103 (1.98/day)
What is the best software to burn MDisc DVD? I have an Lite-On ATAPI iHAS 122 F F EL06 DVD drive
Is it possible to test if a sata dvd drive is good without having to insert a disc?
I see that some Lite-On iHAS 122 models support M-Disc DVD but I have the Lite-On ATAPI iHAS 122 F EL06 model and I don't know if it supports M-Disc DVD burning. What is the best software to check and which software is good for updating the firmware of this drive?
13,340 (6.09/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Case The smaller the better
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
I haven't burned a disc in ages, but Nero: Burning ROM was my go-to solution back then.
You can tell which discs a drive supports by looking it up on the manufacturer web page.
And you don't need to update your firmware, unless there is a fatal flaw with the drive that the manufacturer issued an update for.
138 (0.04/day)
I don't think MDisc needs special software, so whichever.
One option: https://cdburnerxp.se/
Not sure what's to test without a disc. If the PC recognizes the drive, and the tray can be opened, great. Next: use a disc.
Official firmware updates are self-executing packages. There's no 3rd party software needed to apply them.
28,523 (6.78/day)
I use CDBurnerXP.
It's very easy to use, comprehensive and has loads of all the right features.
It doesn't. MDisc burning is handled completely automatically by the drive firmware. Nice to see someone else uses CDBurnerXP.
3,686 (2.51/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
138 (0.04/day)
InfraRecorder showed promise, but development stopped early, and I think there's no BD support.
(Not that CDBurnerXP is feature-complete, but it's more mature.)
103 (1.98/day)
I Have DVD SATA drive Lite-On ATAPI iHAS 122 F EL06
what link download latest firmware?
this drive support M-Disc?
CDBurnerXP any configuration good burning mdisc dvd protect corruption during burn? this software test integrty files after burning?
1,214 (0.19/day)
Hampton Roads
Processor Xeon x5650
Motherboard SABERTOOTH X58
Cooling Fans
Memory 24 GB Kingston HyperX 1600
Video Card(s) GTX 1060 3GB
Storage small ssd
Display(s) Dell 2001F, BenQ short throw
Case Lian Li
Power Supply X750
Software Mint 19.3, Win 10
Benchmark Scores not so fast...
It seems to be plain old dvd dual layer and cd-r. No M-disc or blu-ray.
Are you looking to buy it, or have it and need it to work?
726 (1.18/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
Google is pretty easy to use
