Questions about DDR5
3x0
955 (1.32/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
6200-6400 depending on the CPU (and maybe motherboard)
ir_cow
4,258 (0.73/day)
USA
To clarify here it's mixture of the CPU and motherboard BIOS (AGESA version). The AMD 7000 series has a very hard time above 6200. You may get lucky with a CPU that can handle 6400.
Some of the motherboards will not work above DDR5-6000. Best to look at the spec sheet. I would say QVL list, but a lot of them are putting 6600 on there. That's just pretty much impossible to run right now.
78 (0.11/day)
Thanks everyone,
So is it worth going Intel or AMD fine?
18,585 (2.72/day)
System Name AlderLake
Intel is more mature with DDR5.
qubit
Overclocked quantum bit
17,865 (2.91/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Go Intel. Just check out the CPU reviews on TPU to see why.
3x0
955 (1.32/day)
ir_cow
4,258 (0.73/day)
USA
I noticed that many of the under 500 dollar mb do not support above 4800 DDR5 ram
For AMD? I can see that if you are trying to load up with 128GB (4x32GB), but that isn't the limitation of the motherboard, rather the CPU IMC.
78 (0.11/day)
966 (0.44/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
Hello,
What is the highest frequency DDR5 ram that AM5 supports?
Always look at the motherboard manufacturer website for QVL list before buying any board.
The max official support speed is 6600 for 2X16GB Dimms and 6400 with some 4X16GB Dimms
Probably not a good idea to go 32GB per Dimm on this board.
Thanks everyone,
AMD is a better choice IMHO AM5 has a future update path Intel Z690/Z790 is a dead end platform.
78 (0.11/day)
Thanks
qubit
17,865 (2.91/day)
Quantum Well UK
Keyboard Yes
Any particular review to read?
There have been a few recent ones. Just have a look at them. They're quite long, so you don't have to read everything, just enough to understand how the Intel's perform. The conclusion and some of the graphs will do.
The one thing I'll say is that the top Intels use a lot of power and run very hot, being difficult to cool.
18,585 (2.72/day)
If you build a new rig and keep it using for the next 3-4 years or so you could also go Intel, you could even use your DDR4 memory if you want.
codex5600x
21 (0.03/day)
I have
7600x
Asrock x670e pro rs
G skill Trident Z5 kit DDR5 32GB 6400MHz CL32, 39,38,108, the bios set automatic at 6400MHz cl32,38,38,102 , evrething work great.
I can run at 6800mhz cl 32,38,38,102, evrething stable ,but I must increase the voltage at 1.5v and the performance in games are 0% in productivity max 5%.
I keep at 6400MHz CL32, 38,38,102
75 (0.01/day)
System Name Blah
Processor Ryzen 7950x
Motherboard Asrock X670E Taichi
Cooling BLACK ICE SR2 480,EKWB Quantum Magnitude AM4,D5 Pump,17 CORSAIR SP120 RGB ELITE
Memory 32Gig Gskill 6000 DDR5
Video Card(s) MSI RTX 4090 LIQUID X 24G
Storage Optane 900P 480GB,2x SX8200 2TB ,SAM 980 PRO 2TB,2xSAM 860 EVO 1TB,SAM 870 EVO 4TB,SAM 860 EVO 2TB
Display(s) Samsung Odyssey Neo G9 57
Case CORSAIR 7000X
Audio Device(s) Realtek ALC4082
Power Supply CORSAIR HX1500I
Mouse Corsair Harpoon
Keyboard Corsair Strafe MkII
VR HMD Oculus
I have
7600x
Asrock x670e pro rs
I can guarantee that will not be stable, and u will lose performance...
amd am5 platform hides a lot of issues.....
