- Oct 9, 2007
- 47,057 (7.59/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
AMD Radeon RX 7800 XT will be a much-needed performance-segment addition to the company's Radeon RX 7000-series, which has a massive performance gap between the enthusiast-class RX 7900 series, and the mainstream RX 7600. A report by "Moore's Law is Dead" makes a sensational claim that it is based on a whole new ASIC that's neither the "Navi 31" powering the RX 7900 series, nor the "Navi 32" designed for lower performance tiers, but something in between. This GPU will be AMD's answer to the "AD103." Apparently, the GPU features the same exact 350 mm² graphics compute die (GCD) as the "Navi 31," but on a smaller package resembling that of the "Navi 32." This large GCD is surrounded by four MCDs (memory cache dies), which amount to a 256-bit wide GDDR6 memory interface, and 64 MB of 2nd Gen Infinity Cache memory.
The GCD physically features 96 RDNA3 compute units, but AMD's product managers now have the ability to give the RX 7800 XT a much higher CU count than that of the "Navi 32," while being lower than that of the RX 7900 XT (which is configured with 84). It's rumored that the smaller "Navi 32" GCD tops out at 60 CU (3,840 stream processors), so the new ASIC will enable the RX 7800 XT to have a CU count anywhere between 60 to 84. The resulting RX 7800 XT could have an ASIC with a lower manufacturing cost than that of a theoretical Navi 31 with two disabled MCDs (>60 mm² of wasted 6 nm dies), and even if it ends up performing within 10% of the RX 7900 XT (and matching the GeForce RTX 4070 Ti in the process), it would do so with better pricing headroom. The same ASIC could even power mobile RX 7900 series, where the smaller package and narrower memory bus will conserve precious PCB footprint.
