Razer Blade Pro 17 Overheating way beyond the norm
ballparkclaw
1 (0.00/day)
So I'm well aware that gaming laptops are doomed to forever have inferior cooling. However with mine, which I just bought pre-owned, can't handle basic games without the GPU (rtx2060 model) hitting 90c and throttling my frames. This obviously seems less than normal.
I've fiddled with the fans, I've undervolted the CPU, undervolted/underclocked the card, messed with the power plan settings. The games run just fine, silky 60fps for about 5 minutes until the GPU hits 90c and boom, throttled and the frames go haywire.
I'm guessing the problem is internal, but before I send this thing back to cex to ask for a repair, anything else I should try?
FreedomEclipse
~Technological Technocrat~
23,597 (3.74/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
you can try opening it up, repasting and making sure the cooler is mounted back on correctly but i dont know if doing that will void your warranty.
If youre happy enough with the laptop and willing to take the risk then go ahead. I would use Noctua NT-H2, Prolimatech PK-3 or Gelid GC-Extreme - They are a bit more pricey compared to a lot of other pastes but they are less likely to suffer from a thing called 'pump out'
if you are tech savvy enough to undertake the work. Either find a friend or repair shop that can or send it back to CEX.
813 (0.48/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
Better not repaste it until you are sure it doesn't void the warranty
OneMoar
There is Always Moar
8,774 (1.68/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Cooling Enermax ETX-T50RGB
Storage ADATA SX8200PRO NVME 512GB, Intel 545s 500GBSSD, ADATA SU800 SSD, 3TB Spinner
Mouse Kone burst Pro
Keyboard EVGA Z15
read the op again
you can find a how-too here on how to remove the cooler and re-apply thermal paste
take care not to tear or destroy the thermal pads
if you are feeling adventurous you can use lquid metal with some proper prep work
