Realtek HD Audio Drivers + Sound Blaster X-fi 5.1 Pro Surround with full Dolby & DTS.
我使用由我改装的realtek hda 8967.1 asus rog prime驱动程序
I used realtek HDA 8967.1 Asus Rog Prime driver modified by me
May I ask where this file was downloaded? I didn't see the file you modified, did you change the name
There is in the same folder other patch for add mode. Filename is: ddldtsfix zip
New version of old drivers with all enhancers and uwp apps:
-realtek hd audio manager blue rog with 5.1 virtual speaker & 7.1 dolby pro logic II mode,
-dolby audio,
-dolby digital home theatre 4,
-dolby atmos for gaming,
-dts neo & surround Sensation speaker -realtek
-dts X Ultra with added spatial mode support!!!
-blaster x720 (sound blaster connect uwp & desktop connect 2)
- sonic studio III desktop app.
-download links coming soon...
-Here are the screens...
View attachment 163897View attachment 163898View attachment 163899
[/ reference] Where can I download this driver file? Where is the link?
[QUOTE =“ H4cziLLa,帖子:4331132,成员:194920”]
这是使用dts turtlesound安装realtekdriver_2019_02.exe后音频控制台的屏幕:
View attachment 166041View attachment 166042View attachment 166043View attachment 166044View attachment 166045View attachment 166046
链接到下载文件夹:
[URL unfurl =“ true”] https://mega.nz/folder/qKwH3ToD#ij_FuVnDNC1Pl13DyPEf-g [/ URL]
这里
[URL unfurl =“ true”] https://www.techpowerup.com/forums/...ound-blaster-x-fi-5-1-pro-surround-with-full- dolby-dts.269985 / post-4331132 [/ URL]
在这里,您是hda pack 1,我称之为“乌龟”
[URL unfurl =“ true”] https://mega.nz/file/HPwimSTZ#72yzWFTYrqBiDJTNCIzXa4ZeFCV2B3qVGUcY6DbINo4 [/ URL]
或带有DTS UltraPC II的版本2
[URL unfurl =“ true”] https://mega.nz/file/SO4nQSwA#ZJMp2FqBEUvPmToOldLbXSK9wYcILKmB2N2Zb1RT-o0 [/ URL]
每个Realtek卡上具有ddl / dts的版本3 win10creators模式7071。
[URL unfurl =“ true”] https://mega.nz/file/2foihYhB#NI0Hkw0nUnKerP9dbh4cPkEw-8n4MuOauNYIaq3U_YU [/ URL]
[/引用]
I installed realtekdriver_2019_02.EXe, which, like you said, is completely different from the display console, and there's no sound. I didn't do anything, just install it. Wait for a response
链接到下载文件夹:
这里
[/引用]
Try install this drivers:
Realtekdriver_2019_03.exe
Before install delete folder c:/program files/realtek/install files
I installed Realtekdriver_2019_03.exe; It will work unless you don't have a DTS headset or control panel like this!
You need at first install new device in audio controllers like this:
Driver for this device is here:
Install from device manager. Next configure realtek audio device tweak like this:
Link to download:
At last install dts apo 4 third party drivers ( I used asus rog by mokichu) link is here:
After reboot You should have added dtsx ultra mode in spatials.thats all...
Dont forget DTSXUltra mode running ONLY in stereo mode if You use realtek audio. In 5.1 and 7.1 mode You should have dts neo active.for decoding audio signal to multichannel dolby digital live or dts interactive I using onkyo htr990 amplituner and usb2.0 external sound blaster xfi 5.1 surround pro with 7 speakers :)
View attachment 166591View attachment 166592
Link to download:
1.Run ImportCertificate.cmd
2.Device Manager > Action > Add legacy software > Next > Install the hardware that I manually select from a list (Advanced) >
Next > Next > Have Disk > Browse Select dtsapo4xultrahsa.inf > Open > OK > Next > Next Finish
DtsX ultra started working (on AAF DCH Optimus Sound 6.0.8996.1 HDA)
1. Run ImportCertificate.cmd
2. Device Manager Action Add legacy software Next Install the hardware that I manually select from a list (Advanced)
Next Next Have Disk Browse Select dtsapo4xultrahsa.inf Open OK Next Next Finish
3. In administrator mode, run Install_DTSAPO4x_Acer_DTSX_Ultra - reboot.
4. On DrvCtrl52 we check the boxes as in the screenshot H4cziLLa (What dear, it was difficult to tell you to try to check the boxes? In any case, THANKS - after three pussies on the knee - it all worked.
the second changes the Realtek dispatcher to Asus Rog) . Reboot
5. It is not displayed in the properties of the audio panel - there is generally removed the improvement subsection - this is for me personally.
6. My personal opinion the sound has become richer, bassist or something. But all this is combined with Sonic3, Cinema5, Dolby Atmos. At 7.1.
Anyone here know how to install these via device manager?...@
@dododo ,
@Sonyboi
bros u guys just installed,.... please explain how?
@H4cziLLa
Its a kind of magic my Friends.... But uncle Haczilla show You how..... :) i promise!
Has You got the problem with install dts ultra support device? I will help You. write me.
[QUOTE =“ Zonder,帖子:4334447,成员:199867”]
DtsX ultra开始工作(在AAF DCH Optimus Sound 6.0.8996.1 HDA上)
1.运行ImportCertificate.cmd
2.设备管理器操作添加旧版软件,然后安装我手动从列表中选择的硬件(高级)
下一步下一步浏览磁盘选择dtsapo4xultrahsa.inf打开确定下一步下一步完成
3.在管理员模式下,运行Install_DTSAPO4x_Acer_DTSX_Ultra-重新启动。
4.在DrvCtrl52上,我们按照H4cziLLa屏幕快照中的复选框进行检查(亲爱的,很难告诉您尝试检查这些复选框吗?无论如何,感谢-在膝盖上做了三只猫之后-一切都奏效了。
第二个将Realtek调度程序更改为Asus Rog。重启
5.它不会显示在音频面板的属性中-通常删除了改进小节-这是我个人需要的。
6.我个人认为声音已经变得更加丰富,贝斯手或其他。但这一切都与Sonic3,Cinema5和Dolby Atmos相结合。在7.1。
[/引用]
4.在DrvCtrl52上,我们按照屏幕快照H4cziLLa中的校正进行检查(亲爱的,很难告诉您尝试检查这些检查吗?无论如何,谢谢-在上面三只猫之后-都可以。
第二个更改华硕Rog的Realtek调度员)。
[/引用]
Write in english please.
[QUOTE =“ H4cziLLa,帖子:4333998,成员:194920”]
首先,您需要像这样在音频控制器中安装新设备:
该设备的驱动程序在这里:
[URL unfurl =“ true”] https://mega.nz/file/uaQXDYrB#R2z0O4aaiw76A9G4VOyHXss_ebCMFmeU_MQZpyIHzjE [/ URL]
从设备管理器安装。接下来,像这样配置Realtek音频设备:
链接下载:
[URL unfurl =“ true”] https://mega.nz/file/zC5mWQ6S#3xSaxjwsSinw5ULO0BH0P74B1kqPfC_4QQTpHrvWEMY [/ URL]
最后安装dts apo 4第三方驱动程序(我通过mokichu使用asus rog)链接在这里:
[URL unfurl =“ true”] https://rog.asus.com/forum/showthre...k-Audio-(MB-Intel-2xx-3xx-4xx-amp-AMD-3xx-4xx -5xx)[/ URL]
重新启动后,您应该已经在空间中添加了dtsx ultra模式。仅此而已...
如果您使用realtek音频,请不要忘记仅在立体声模式下运行的DTSXUltra模式。在5.1和7.1模式下,您应该具有dts neo active。使用onkyo htr990放大器和usb2.0外部音效增强器xfi 5.1环绕声专业版,将音频信号解码为多声道杜比数字直播或dts交互式I,带有7个扬声器:)
[/引用]
I installed AafAudiopackdCH-6.0.8996.1.EXe, and then installed DTSUltra X Support Drivers related components in your tutorial, but found no effect. It was suggested in the device manager that the corresponding driver was not installed, but in fact I already installed it, and finally there was no response.
该设备的驱动程序在这里:
链接下载:
[/引用]
View attachment 166754View attachment 166755View attachment 166756
100 / C230:D
MB-Intel-2xx-3xx-4xx-amp-AMD-3xx-4xx -5x:kookoo:
Not entirely true! I have Sonic3 - it shouldn't work, but it works. So don't fuck the brain like H4cziLLa. False alarm - Ultra does not work for me either. BillTaozi - don't be upset. All the best is all the same in Alan Finoti's mods - better than him and put it, as I did ...DTS Unboard - it works for me, but the sound is not very good there ... So dododo - you yourself:kookoo::kookoo::kookoo:)
[QUOTE =“ dododo,帖子:4335365,成员:177215”]
100 / C230
除了DTSUltra X支持驱动程序以外,所用功能正常,我是在这里下载i的:
[QUOTE =“ Zonder,帖子:4335374,成员:199867”]
并非完全正确!我有Sonic3-它不应该工作,但是可以工作。因此,请勿像H4cziLLa那样操弄大脑。错误警报-Ultra也不适合我。BillTaozi-不要难过。在Alan Finoti的mod中一切都一样-比他更好并且像我所做的那样... DTS Unboard-它对我有用,但是那里的声音不是很好...所以dododo-你自己:kookoo::kookoo::kookoo:)
[/引用]
100 / C230:D
MB-Intel-2xx-3xx-4xx-amp-AMD-3xx-4xx -5x:kookoo:Like you, I give up, his tutorial can not understand, study for so long, still do not understand what he said is ha;
h
Please write in english language.
Can you publish a detailed installation tutorial? There are no steps and procedures, no screenshots installed, and I can't understand your instructions. It is always different from your presentation.
Can you publish a detailed installation tutorial? No steps and procedures, no screen shots installed, I can't understand your instructions. It will always be different from your presentation.
Wow what a huge audio mod, does it have 7.1 channel support? I'm using SPDIF
SPDIF don't have support to more than 6 channels (5.1).
only in bitstream can get a 7.1 with a dolbyEX signal ( A Matrix to add a center surround channel and single rear surround channel ).
if you wanna 7.1 or more them use HDMI or DP :):):)
Hello!!! First, thanks for making these drivers.
Second, does it support ALC280? I want to install it on my laptop. If yes, what driver should I download?
Thank you. Sorry for my bad English
Someone really needs to write a detailed installation tutorial for this mod , It's a big mess rn .
Someone did need to write a detailed installation tutorial for this mod, which is a mess
4. On DrvCtrl52, we follow the check boxes in the screenshot H4cziLLa (Dear, is it hard to tell you to try checking these check boxes? Anyway, thanks - after the three cats on the lap - all right.
Second change to Asustek Rog Realtek dispatcher). restart ????????
Hello Everyone!
Here are screens from my actually audio drivers configuration with full Dolby & DTS included.
-dolby audio
-dolby digital plus
-dolby pro logic II
-dolby home theatre v4
-dolby digital live
-dolby atmos / access
-dts sound unbound
-dts ultra
-dts connect
-dts ultrapc II
-dts interactive
-blaster 720 desktop & uwp
View attachment 162366View attachment 162367View attachment 162368View attachment 162369View attachment 162370View attachment 162371View attachment 162372View attachment 162373View attachment 162374View attachment 162375View attachment 162376View attachment 162377View attachment 162378View attachment 162379
Link for download my drivers is over here:
Greatings for Alan Finotty Team Brazil!!!
Max volume level on spdif is 114db! :0)
Realtek drivers must be install from device manager!!
Full signed WHQL.
I need your help, if possible preferably with a detailed installation tutorial!
Hello Everyone!
-dolby audio
-dolby digital plus
-dolby pro logic II
-dolby digital live
-dts sound unbound
-dts ultra
-dts connect
-dts ultrapc II
-dts interactive
Full signed WHQL.
[/引用]
https://github.com/AlanFinotty1995/AAF_DCH_RealtekModded/releases
Can we combine them? Your drive is too old, and he doesn't have many things like 7.1 sound effect.
w
