Realtek's 5 Gbps Ethernet Solutions Will Reduce Cost and Power Draw Significantly
3,369 (1.17/day)
North East Ohio, USA
System Name My Ryzen 7 7700X Super Computer
Processor AMD Ryzen 7 7700X
Cooling DeepCool AK620 with Arctic Silver 5
Memory 2x16GB G.Skill Trident Z5 NEO DDR5 EXPO (CL30)
Video Card(s) XFX AMD Radeon RX 7900 GRE
Storage Samsung 980 EVO 1 TB NVMe SSD (System Drive), Samsung 970 EVO 500 GB NVMe SSD (Game Drive)
Display(s) Acer Nitro XV272U (DisplayPort) and Acer Nitro XV270U (DisplayPort)
Case Lian Li LANCOOL II MESH C
Audio Device(s) On-Board Sound / Sony WH-XB910N Bluetooth Headphones
Power Supply MSI A850GF
Mouse Logitech M705
Keyboard Steelseries
Benchmark Scores https://valid.x86.fr/liwjs3
Wow, what a gimick, sure downloads will be fast as hell but regular use will feel no different as it will always have to wait on the upload - not that it matters anyway as at this speeds the thing you're waiting on is latency
That's the one that the cable still suffers from, higher latency. Fiber, of course, provides as little latency as possible. I have sub-3 ms ping times to my first hop.
XGS-PON+ is the future Not docsis.
Agreed. However, you know as well as I do that cable companies will milk as much money out of their current copper plant as they can.
2,264 (0.33/day)
Toronto, Ontario
System Name The Expanse
Processor AMD Ryzen 7 5800X3D
Cooling Corsair H150i Pro
Video Card(s) XFX Radeon RX 7900 XTX Magnetic Air (24.12.1)
You know it they will deploy docsis 4.0 to the rich area's first and everyone else will be waiting years for it.
3,369 (1.17/day)
Mouse Logitech M705
If they want to compete with areas where FTTH is already deployed in, they'll have no choice. Competition, gotta love it!
18,056 (2.44/day)
Why 2xUSB 3.2 ports with the 5Gbps port I know the bandwidth has to be used for something but really :confused:
It's as I explained, for validation for stacked connectors on motherboards.
Because apparently USB3.0 is to inefficient and barely tops 300MB/s on the few available USB3.0-to-5GbE-Solutions. I don't have any practical experience, just heard about it somewhere.
See above for the actual reason.
3,369 (1.17/day)
Mouse Logitech M705
But that would then make it unable to fit into an expansion slot on the back of a PC case.
18,056 (2.44/day)
Great! Now do affordable multigig switches. Not 2 multigig ports and 24 GigE ports. 8 multigig ports for less than $100.
2.5 Gbps will reach below that by next year, not sure what 5 Gbps switches will cost, but the new PHY should help lower the cost. 10 Gbps will take a while longer for sure and it's also a matter of the actual switch IC cost as well.
Huh? This is for validation only, to make sure these types of connectors work, as you can't do this with 10 Gbps. Think of this as part of the motherboard I/O ports.
Retail NICs will have a normal port, just like you're used to.
2,881 (1.17/day)
Ok experts, what's the best PCI-E ethernet add-on card with 2.5GB-E ports? I am sick of my Intel i225's patchy performance despite being updated to the so-called fix. I think add-on is only hope for good reliable performance. This is for windows 10.
18,056 (2.44/day)
Realtek is the only other affordable option that's widely available. The RTL8125BG should be their most current revision. There's also a D version for their "gaming" chips that comes with some extra software...
Maybe something like this? No idea about that brand and the heatsink is very much not needed and just for show.
Asus does one too, if you want something branded.
You can even get cards with two ports, if that's your kind of thing.
Or even four...
You could splash out on one of the older Aquantia based cards, they run fairly hot, but goes up to 10 Gbps.
3,369 (1.17/day)
Mouse Logitech M705
Correct me if I'm wrong but when I look at the second picture, towards the right side of the picture there's a slot and a row of pins similar to that of what would slide into a PCI Express slot.
18,056 (2.44/day)
Again, this is an internal Realtek validation card. It has no correlation to retail products. Yes, it has a standard PCIe 3.0 x1 interface, as how would you otherwise be able to inteface the board with a motherboard and test the throughput etc? There are also additional test pins on the card and what not, so don't read too much into what this looks like, as it's again, only for validation. The USB ports aren't functional.
2,881 (1.17/day)
Realtek is the only other affordable option. The RTL8125BG should be their most current revision. There's also a D version for their "gaming" chips that comes with some extra software...
Or even four...
Thanks for the info, looks like they all use Realtek RTL8125(B)G. Pretty good reviews on all of them.
18,056 (2.44/day)
Avoid the A revision, there's a hardware issue with those too, but they don't seem to be available in retail any more.
The D version is for Dragon and should be Realtek's answer to Killer NICs
127 (0.07/day)
Australia
System Name wasted talent
Processor i5-11400F
Motherboard Gigabyte B560M Aorussy Pro
Cooling Silverstone AR12
Memory Patriot Viper Steel 2X8 4400 @ 3600 C14,14,12,28
Video Card(s) Sapphire RX 6700 Pulse, Galax 1650 Super EX
Storage Kingston A2000 500GB
Display(s) Gigabyte M27Q
Case open mATX: zwzdiy.cc/M/Product/209574419.html
Audio Device(s) HiFiMan HE400SE
Power Supply Strix Gold 650W
Mouse Skoll Mini, G502 LightSpeed
Keyboard Akko 3084S
Software 1809 LTSC
Benchmark Scores 3968/540 CB R20 MT/ST
Irrelevent to the discussion, but this thread has had more civil discourse than every GPU thread of past 3 years combined.
175 (0.11/day)
Processor 265K (running stock until more Intel updates land)
Motherboard MPG Z890 Carbon WIFI
Cooling Peerless Assassin 140
Memory 48GB DDR5-7200 CL34
Video Card(s) RTX 3080 12GB FTW3 Ultra Hybrid
Storage 1.5TB 905P and 2x 2TB P44 Pro
Display(s) CU34G2X and Ea244wmi
Case Dark Base 901
Audio Device(s) Sound Blaster X4
Power Supply Toughpower PF3 850
Mouse G502 HERO/G700s
Keyboard Ducky One 3 Pro Nazca
I'm hoping this development will add to the consumer switch options as most 2.5gb aren't terribly well priced from the major brands. I ended up getting a switch with 1/2.5/10gb ports rather than getting one all 2.5/10 simply due to the huge price jump.
175 (0.11/day)
Case Dark Base 901
I don't really know what that is.
The card in the picture is just for testing purposes. What they're testing is making sure everything works right with stacked connectors like you have on your motherboard I/O panel. They have to ensure signal integrity etc because the RJ45 port could be on top of any number of other ports when integrated into a motherboard.
170 (0.04/day)
And why is that the actual reason for the 5GbE-USB-NIC having USB3.2 10Gb/s instead of 5Gb/s, according to TheLost Swede?
1,993 (0.48/day)
What is the problem with A version?
Im using 8125AG (2.5G) from 2019 and i dont really have to option to "avoid" it. My board also has Intels i211 solution (1G).
So far during these years i have not noticed anything bad with 8125AG.
18,056 (2.44/day)
I didn't get a chance to properly check out the actualy switch stuff at Realtek, as both times I visited, it was really crowded in that area, but I'm going to give it a go tomorrow again. Obviously the PHY is an important aspect as well, as so far, only 2.5 Gbps and below switchings ICs are incorporating an integrated PHY and only one company has announced such a 2.5 Gbps solution. Everything else is at least a two chip solution. The more integrated these things get, the cheaper it gets to produce, to a certain point. However, pricing in every step doesn't have to related to manufacuring cost, so even if it costs someone like Realtek less, they might want to make a larger marging and their customers in turn wants to make a larger margin, which means retail pricing doesn't drop, at least not initially.
As for the USB to 5 Gbps NIC using 10 Gbps USB 3.2 instead of 5 Gbps, is because 5 Gbps USB isn't really 5 Gbps, as there are overheads. Initially it was marketed as 4.8 Gbps, but got rounded up, but often real world transfer speeds are even slower than that. 10 Gbps USB is using a different data encoding, so it's more efficient, but it still doesn't get you 10 Gbps, but you get closer and the same applies for 20 Gbps USB. So to make sure that the USB interface isn't a bottle neck and with 10 Gbps USB now being a 10 year old standard, I guess they felt pretty safe that anyone that was going to use this product, would have at least one such capable port on their system.
From what I remember, at 2.5 Gbps speeds, they were having some issues with a lot of older multi-Gig capable switches, so if you're only using Gigabit at home, it shouldn't be an issue to use that NIC. I honestly don't remember the exact issue, but I think that was it and it was fixed in the B version. I believe I have the same chips as well on my board and it has been working fine over Gigabit.
1,054 (0.17/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 970PRO 500GB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/9qw7iq https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
We are half way to have 10G ethernet as default.
18,056 (2.44/day)
1,993 (0.48/day)
Thanks for the clarification. Indeed im using 1Gbps symmetrical fiber tho my ISP should have 2.5Gbps option in the coming years based on some rumors.
But i suspect im on Zen 5 or 6 by that point where this 5Gbps NIC is standard on most boards and perhaps even 10Gbps on high end ones.
2,264 (0.33/day)
Toronto, Ontario
ASUS (XG-C100C) 10G Network Adapter PCI-E x4 Card
Supports 10/5/2.5/1 Gbps
Selling for $129.99 CAD or 87.99 USD
Supports Windows 10/8.1/8/7 and Linux Kernel 4.4/4.2/3.6/3.2
121 (0.13/day)
It's affordable enough that if it dies you won't care about trying to RMA it with Asus! ;-)
That is impressive since I did not know cat 5e spec supported speeds over 2.5GBASE-T.
You can manage 10GbE over Cat 5e over shorter distances to a point. My condo was pre-wired with 5e but I have no issues with 10GbE throughout 1,200 sq. ft. YMMV regarding a degradation point of course given it's out of spec more than an off-label Rx for meds.
