Recommended voltages for 7800X3D
3,325 (1.17/day)
System Name The de-ploughminator Mk-II
Processor i7 13700KF
Motherboard MSI Z790 Carbon
Cooling ID-Cooling SE-226-XT + Phanteks T30
Memory 2x16GB G.Skill DDR5 7200Cas34
Storage Kingston KC3000 2TB NVME
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
Well I just built a SFF rig for my gaming buddy with 7800X3D + 4080 Super.
What are the recommended voltage settings for 7800X3D running 2x16GB 60000Cas36 G.Skill? I will set for best thermals possible.
6,440 (2.96/day)
California
System Name His & Hers
Storage lots of SSD.
All 3 I worked with ran pretty cool but all 3 were in larger cases with a 360 aio..... All I would do is find out what curve optimizer settings it likes some like as low as negative 30 There are plenty of youtube videos that would go into better detail than me.
tabascosauz
7,981 (2.38/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
I'm not sure what you mean by best thermals possible, as the uncore voltages within reason don't really affect thermals much and RAM would obviously depend on what you test to be stable. And CO is also impossible to say as there is known appreciable variances from chip to chip. Also not confident enough to say if CO alone can create massive temp reductions as it once did on 5800X3D.
VSOC as low as possible without penalizing performance of any kind or causing iGPU artifacting or other problems. Probably looking at somewhere between 1.0-1.2V for 6000. Using iGPU actively for display output affects VSOC requirements. The FCLK you want to run can also affect your choice of VSOC (both the way you'd expect, but also possibly inversely as high VSOC can inhibit stable high FCLK).
VDDIO_MEM_S3 can start at 1.25V as a safe estimate I think. 1.35V is also fine for me but idk if that's a generally safe recommendation.
Don't think VDD_MISC needs to budge from 1.1V usually
afaik VDDP is similar to on AM4 and can stay at 0.9-1.0V in normal use case.
DDR5 voltages should work the same way as they do on Intel.
3,325 (1.17/day)
Software win11
Well I will probably underclock the CPU by 200mhz to lower thermals
Just tried CP2077 at 1080p and it is reaching 80C, I will try to lower it to 70C
Since I build for somebody else, playing it as safe as I can :)
Toothless
Tech, Games, and TPU!
9,478 (2.49/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Probably needs more airflow but other than that it looks like everything is within spec. Just use the poor thing.
6,440 (2.96/day)
California
Anything under 89c is more than fine those cpus just automatically boost based on cooling in my experiences they all run in the high 70s low 80s no matter what cooling you throw at them... Some of it probably just comes down to lottery in how flat the ihs is.
Cyberpunk is a pretty good test though it's decently cpu heavy especially with RT.
I usually loop timespy gpu test 1 with cinebench r23 for 2 hours and take down the averages... extreme maybe but I like it as a worst case scenario.
290 (3.02/day)
System Name Kuro
Processor AMD Ryzen 7 7800X3D@65W
Motherboard MSI MAG B650 Tomahawk WiFi
Memory Corsair DDR5 6000C30 2x48GB (Hynix M)@6000 30-36-36-48 1.36V
Video Card(s) PNY XLR8 RTX 4070 Ti SUPER 16G@200W
Storage Crucial T500 2TB + WD Blue 8TB
Case Lian Li LANCOOL 216
Audio Device(s) Sound Blaster AE-7
Power Supply MSI MPG A850G
Software Ubuntu 24.04 LTS + Windows 10 Home Build 19045
Benchmark Scores 17761 C23 Multi@65W
You might have better success lowering wattage limits, which won't impact single thread performance within reasonable limits, though that would produce somewhat-lower-than-expected multicore benchmark rating, so look out if that matters.
A low VSOC should help as @tabascosauz mentioned. The IOD+IF could indicate upwards of 20W even in idle. If anything, it would leave more TDP budget to the core chiplet.
3,275 (2.13/day)
System Name Mean machine
Processor 12900k
Motherboard MSI Unify X
Cooling Noctua U12A
Memory 7600c34
Video Card(s) 4090 Gamerock oc
Storage 980 pro 2tb
Display(s) Samsung crg90
Case Fractal Torent
Audio Device(s) Hifiman Arya / a30 - d30 pro stack
Power Supply Be quiet dark power pro 1200
Mouse Viper ultimate
Keyboard Blackwidow 65%
You can run those ram at 6000c30-34-34-34-58 + 65k trefi at 1.435v. It's the samsung dies right?
3,325 (1.17/day)
Software win11
Disabling boost clocks and curve optimizer -20
4080 Super also run at lowest voltage possible at 900mV
Looks like temps are good, room temp at 33C atm
Oh I will try setting lower TDP instead of disabling boost, 4200mhz would probably hurt single core perf.
Yes It's samsung Bdie, overclocking or lowering CAS don't work :/, tREFI 65k would cause instability when sphub temp is above 50C, I will try for 1.35V DDR to lower temp though
3,275 (2.13/day)
Processor 12900k
Cooling Noctua U12A
Memory 7600c34
Storage 980 pro 2tb
Case Fractal Torent
Yeah overclocking for sure doesn't work on those dies, but tightening down the timings should be possible. Maybe it's the platform difference, had them on Intel and 6000c30 was pretty easy.
tabascosauz
7,981 (2.38/day)
Western Canada
System Name ab┃ob
Temps lookin' good :toast:
No need to really worry about the CPU temps at all, 7800X3D keeps itself in check pretty well. If it never breaks 80C, then I just wouldn't even bother to look at the temp at all. Doesn't run quite as cool as 5800X3D in games but it's no problem at all
11,082 (5.40/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Storage 2 TB Corsair MP600 GS, 2 TB Corsair MP600 R2, 4 + 8 TB Seagate Barracuda 3.5"
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
SoC Voltage shouldn't exceed 1.35 V, but with 6000 MHz RAM, you're good to go anywhere between 1.2 and 1.3 V. Everything else should be fine on Auto.
Nice setup, btw! :toast:
1,517 (1.79/day)
G-City, UK
System Name My 2nd new build
Processor Ryzen 7 7800X3D
Cooling Thermalright Peerless Assassin 120 ARGB
Memory G-Skill Trident Z Neo RGB 6000 CL30 32GB
Video Card(s) Powercolor 7900 GRE Red Devil
Storage Samsung 870 QVO 1TB x 2, Lexar 256 GB, TeamGroup MP44L 2TB, Crucial T700 1TB
Display(s) 32" LG GN600-B
Case Montech 903 MAX AIR
Audio Device(s) Corsair void wireless/Razer Kraken
Mouse Glorious Model D l Pad GameSir G7 SE
Keyboard Redragon Vara K551P
Benchmark Scores Lets get my GPU working first...
Damn those Peerless assassins are everywhere, lol. Great cooler!
5,894 (2.93/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
1,517 (1.79/day)
G-City, UK
1,622 (0.88/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
The most important is curve optimizer and ppt. Find best curve values using occt avx2 extreme. I got around 800 points mote in cinebench R23 going from stock to -36 avg CO so about 5%. Ppt of anywhere from 60-80W if there is too much noise/throttling.
SOC will probably work at 1.0-1.2v. Find lowest. Vddp at 0.9-1.1v. vddio at 1.1-1.25v. vdd18 to 1.6-1.7v, vdd misc may work at 1.0v. vddgs at 0.8-0.9v.
Example of the latter:
- Soc 1.29v, vddp 1.15v, vdd18 1.8v, vddio 1.35v
Idle consumption 22-26W
- Soc 1.08v, vddp 0.99v, vdd18 1.6v, vddio 1.24v
Idle consumption 15-19W, load 15W lower in cinebench R23.
1,349 (0.63/day)
SortOfGrim
System Name Merc v8| Project DRS
Processor Ryzen 7800X3D|5800X
Motherboard Gigabyte X670 Gaming X AX|B550 AORUS ELITE
Cooling Noctua NH-D15|Arctic LFII-360
Memory 2x 16GB-6000|2x16GB-3600
Video Card(s) MSI RTX 4070 Ti SUPER|RTX 3070 Ventus
Storage Solidigm P44 1TB & 2TB, Crucial MX500 2TB|2x1TB SSD
Display(s) Acer Predator XB271HU|LG 34GP950G
Case Caselabs Mercury S8|Phanteks G500A
Audio Device(s) Schiit Magni & Modi, Edifier S351DB|DT 770 PRO headphones
Power Supply Seasonic Vertex PX-850|Prime TX-750
Mouse Logitech G600
Keyboard Epomaker F75|Logitech K400
Software W11Pro
Things I did to temper my 7800X3D, things might sound/look different so a little searching in the bios is needed;
Precision Boost Overdrive: from auto to Advanced
Curve Optimizer
: All Cores
All Core Curve Optimizer Sign
: from Positive to Negative
All Core Curve Optimizer Magnitude
: 0-30 (start with 30, run benchmarks, if CTD lower the number, mine is set at -15)
Platform Thermal Throttle Control: from Auto to Manual
Platform Thermal Throttle Limit
: 80 (in Celsius) or whatever you're comfortable with
PPT Limit [mW]: max cpu wattage. I have not touched this but you can change it to let's say 85000 [= 85 Watts]
With these my sig rig does not run higher than 80 degree Celsius. And I can still play Crysis ;)
3,325 (1.17/day)
Software win11
Thanks for your suggestions, I set SOC at 1.1V and it has been stable thus far with 6000Cas36 RAM.
Do you have any weird errors without crashing with CO set too low? like WHEA errors?
If performance is not significantly reduced I would disable single core boost and run all-cores 4.2ghz, I will do some gaming benchmarks to check.
1,622 (0.88/day)
If CO is set to low you get instant reboot, no bluescreen.
1,267 (2.20/day)
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Storage 512+512+1+2+2+2+2+6+500+256+4+4+4
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
Software EMDB
Benchmark Scores 0>1000
I'll try CPU Boost OFF, playing LiS 2 and True Colors (RT)
3,325 (1.17/day)
Software win11
Wait this is looking pretty funny
Cyberpunk 2077 1080p High
Core boost disabled, all cores 4.2ghz, CO -30
Core boost enabled, 65W PPT, CO -30
Not only all cores 4.2ghz gives higher avg FPS, but also much higher 1% Low FPS, about 15C cooler and 20W less
Cyberpunk 2077 probably doesn't care about clocks but rather the Cache
Edit: with Core Performance Boost disabled, CO disabled the performance is way way higher. Look like Curve Optimizer might be detrimental to performance
1,267 (2.20/day)
System Name KLM
Case 4000D Airflow
Mouse 502 Hero
Keyboard K68
Software EMDB
For me it's 79 to 50°c
IDK... i've XMP OFF
Beware if you installed 560.70, bc i had 90 to 120 FPS in CP2077 befor GPUBoost OFF, i tested bc some user reported it in 3DGuru forum
3,325 (1.17/day)
Software win11
IDK... i've XMP OFF
What is GPU Boost? I overclocked+undervolt the 4080Super to 2520mhz/900mV so GPU clocks stay fixed the entire time
1,267 (2.20/day)
System Name KLM
Case 4000D Airflow
Mouse 502 Hero
Keyboard K68
Software EMDB
No, a typo, it's CPU Boost, my iGPU is OFF too in the BIOS. it's good on x3d chip gets cooler( i think it's the cache tho).
1,622 (0.88/day)
Could be unstable CO resulting in performance degredation.
