Red light on ASUS Motherboard
Mladen_94
8 (0.00/day)
Hello everyone. Sorry if i made thread in the wrong section i just created account here. I am hoping that you can help me with this, i searched whole google and i couldn't find any solution. So my problem is next:
My PC won't start. I see continious dram red light, holding RAMOK button can't fix the problem.There isn't any beep sound when i turn on my PC. I tried removing Graphic card and putting it back. I tried all 4 RAM Memory slots (2x Black and 2x Blue) and the red light still appears. I don't know how to fix the problem because i don't know what is causing him. Can you please help me ?
Specifications:
Motherboard: ASUS M5A87
CPU : AMD Athlon II x4 645 3.1 Ghz
GPU : Nvidia (Gainward) GTS 450
RAM: Patrion (PSD34D16002H) 4 GB DDR3
PC worked normaly, i just turned it off to clean some dust from it, i had to remove component cuz its impossible to reach some areas without removing components. I changed thermal paste on my processor and thats all.. Thermal paste is not the problem cuz i changed it few times to see if red light would stop, i also tried without thermal paste but i still had red light.. All fans were working normaly, there isn't any smoke, any smell, everything was cool and clean.. I have no idea what to do.
1,357 (0.32/day)
Canada
System Name HTPC
Processor Intel Core 2 Duo E8400 - 3.00/6M/1333
Motherboard AsRock G31M-GS R2.0
Cooling CoolerMaster Vortex 752 - Black
Memory 4 Go (2x2) Kingston ValueRam DDR2-800
Video Card(s) Asus EN8600GT/HTDP/512M
Storage WD 3200AAKS
Display(s) 32" Irico E320GV-FHD
Case Aerocool Qx-2000
Power Supply Enermax NoiseTaker 2 - 465w
Mouse Logitech Wave MK550 combo (M510)
Keyboard Logitech Wave MK550 combo (K350)
Software Win_7_Pro-French
Benchmark Scores Windows index : 6.5 / 6.5 / 5.6 / 6.3 / 5.9
Try without the graphic card. Does it still make the same? Some components mais be not well sit in like memory sticks. It happened to me on time that I accidently bent a pin on the AMD cpu. It could also be that electro static blew one of memory stick. Oftn people make mistake to remove the components with computer plugged or just after unplugging it. You need to unplug and push on power button to empty all the circuits of the remaining electricty so it wont make a "spark" peak of discharge.
1- Remove graphic card
2- Make cpu mainboard and cpu connectors are well plugged in
3- Remove memory sticks and start computer.
4- If its beeping then the motherboard is good so you put back memory one by one and test it.
5- If not beeping then the motherboard got fried by spark discharge.
6- If beeping and memory all tested its still dont start then im afraid the cpu got busted. Try another cpu inside and if its workingthen the cpu gotta be replaced.
Mladen_94
8 (0.00/day)
Since its my friend computer i can't do anything right now. I am collecting info so i can try tomorrow since its 00:45 AM here..
I tried with removing memory stick and started PC, i heard beeping, i tried all 4 slots and i still had red light.. I will try tomorrow with removed graphic card.. I hope that CPU is okey cuz thats damn expensive, i don't have money for bubble gum lol :D
thx for the advice, if you have any more advices, tell me so i can try all of this tomorrow :)
EDIT: When all is inserted properly i dont have any beeps, i get beeps when ram is not inserted..But when its in, its only a red light, no beeps
1,357 (0.32/day)
Canada
System Name HTPC
Storage WD 3200AAKS
that's the same procedure i used for 20 years now so just do it. Even if technology and parts change it's still the same procedure. If you have spare power supply just bring it there try it after you did all the testing. if still not working with graphic card removed then plug the setup with the power supply you bring. If still not working then it is the cpu.
Mladen_94
8 (0.00/day)
Is there any way that the ram is boosted? cuz he got warranty for RAM only and its the cheapest lol :D
1,357 (0.32/day)
Canada
System Name HTPC
Storage WD 3200AAKS
As i said try step by step i told you. no need to add more until you do the step by step.
Mladen_94
8 (0.00/day)
Okey thanks, i will try all of this tomorrow, i will post here what happened and what is busted when i get home. Thanks alot man
OneMoar
There is Always Moar
8,820 (1.62/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
*if junkbears recomendations don't work*
inspect the cpu for bent or broken pins if you had to fight to get the heatsink off you may have broken one
or the socket its self in witch case you need a new board ...
system is getting pretty old time to think about a upgrade ...
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
It sounds odd, but this could be a PSU issue as well. The RAM controller is on the CPU. If there is an issue with the CPU receiving power it can cause the RAM controller to not initialize properly. This will cause the DRAM LED to light because the POST process can't initialize the RAM.
That power supply in the picture doesn't exactly look that high quality.
OneMoar
8,820 (1.62/day)
Rochester area
on asus boards the dram light doubles as post code led check the manual static on is never good tho
Mladen_94
8 (0.00/day)
I alredy checked CPU, all pins were normal, all in line, not even a single pin was bent, not even broken.. I had no problem putting CPU back to socket :)
Edit:
@newtekie1 IDK i just hope that its not CPU or GPU :D everything else is afordable..
I know that he wont charge me for that crap, but i would really feel like sh*t if something went off.. I would sell my kidney if i have to, just to fix that problem
:D
43,871 (6.80/day)
No psu info cant help you
OneMoar
8,820 (1.62/day)
Rochester area
Mladen_94
8 (0.00/day)
I will try everything you guys wrote here. Thx alot, this is one great forum :) nice community
hat
Enthusiast
21,753 (3.26/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Try to find a way to make sure it's indeed the PSU before you replace it. If it's not too much trouble take the PSU out of your rig and try it in your friend's if you have to.
2,098 (0.52/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
Did anyone here download the manual and actually look into it.
That Led is for the ram (DRAM LED)
next to it there is a small button that's called mem test try and press it and see if the memory will pass
The problem is almost definitely the ram. (At least I see it's in the proper place Bank A1)
OneMoar
8,820 (1.62/day)
Rochester area
you didn't read the thread
2,098 (0.52/day)
You got me there
43,871 (6.80/day)
You got me there
Those lights tend to give a false positive, if correct voltage isnt being provided to any system part it wont boot properly
Aquinus
Resident Wat-man
13,179 (2.76/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 14.6.1
Yeah, except that particular LED means something and if it stays lit it could be an indicator of a problem.
Like my motherboard, that's the DRAM_LED. It stays lit when the motherboard either can't place nicely with the DRAM installed or when the DRAM has failed. You can try pressing the MemOk! button which will try to bypass any DRAM checking it does but, I suggest pulling both DIMMs out and testing one at a time. Reset the BIOS while you're at it.
If it was working before and not now and it's the DRAM_LED lighting up, that's almost a surefire sign that at least one stick of memory as failed. This isn't rocket science.
I don't think you're right on that one but you never know. If the IMC can't initialize the very first stage of startup (CPU init) should fail as the IMC needs to be powered up to work with some of the cache levels and cache is checked before DRAM. This really smells like bad DRAM. It's not that hard to swap DIMMs around to rule it out.
Mladen_94
8 (0.00/day)
Hi guys, we took pc to my other friends house. RAM Memory was busted..We tried RAM from the picture above to other PC and the other PC wouldnt start either..Then we took new ram memory and put on the broken one and everything was fine. PC started normaly, bios was reseted so we had to change time and date manualy. Thanks everyone for helping me :)
AsRock
TPU addict
19,195 (2.97/day)
UK\USA
Cooling D15
Glad you got it sorted out. But please consider running a system on a quality PSU as cheap ones can do so much damage.
2,098 (0.52/day)
Well I might have not read the whole thread but still called it correctly. This makes my day
AsRock
TPU addict
19,195 (2.97/day)
UK\USA
Cooling D15
Well i read a few ASUS forum posts were the red light issue was due to a few things like not having the 8 pin connected or even the PSU not supplying the power required correctly.
