Regarding Blower fans
143 (0.14/day)
Ballkans
Hey everyone it's been a while!
Lately I have been wanting to use some blower fans for a recent project involving very limited cooling space 34mm height and I found these:
Sunon PMB1297PYB1-AY 9733
Now generally there seems to be only two types of blower fans Squirrel cage (This one)
And the other model that's used on laptops.
My question is what are the advantages and disadvantages of these two designs and when should we choose one over the other?
(Do they come in hydraulic sleeve bearing variants besides double ball)?
42,519 (6.67/day)
Look at nidec, delta even
FreedomEclipse
~Technological Technocrat~
24,149 (3.74/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming) | 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
They are LOUD. Very LOUD.
Arent as efficient moving around as normal fans. Hence why they have to spin real fast and generate a lot of noise.
As for bearings. AFAIK they are only DBB as they are most used in industrial/non-commercial environments where reliability is more important than being deafened.
GPUs of old used to use the same style of squirrel cage cooler and those bearings used to go bad pretty quickly.
I think the 5700XT was the last card from AMD to use the blower style cooler.
21,528 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
You can find MagLevs from Sunon, my preferred bearing. They invented the tech. That won't save you from the noise of high RPMs though. IIRC Sunon advertises its MagLev bearings as Vapor bearings or something like that.
Not sure if they'll have one for your particular use case, but I've used 120mm 3200RPM Sunon MagLevs and love them for everything save noise obviously.
