Reliable 1TB External Drive
118 (0.04/day)
Chile
Processor Intel Core i7-6700K 4.0GHz Quad-Core Processor
Motherboard Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard
Cooling CRYORIG M9i 48.4 CFM CPU Cooler
Memory G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory
Video Card(s) EVGA GeForce GTX 1070 8GB FTW Gaming ACX 3.0 Video Card
Storage (SSD) PNY CS2211 480GB 2.5" Solid State Drive
Power Supply EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply
Hi folks,
im looking for a good reliable External Drive that has at least 1 TB, ive always bought Seagate HDDs but i dont know how are their externals are. I have a page from my country where you can find lots of drives at different prices and brands.
https://www.solotodo.com/external_s...nology=&format=&advanced_controls=0&ordering=
so far these options seems good, what do you think? :
https://www.solotodo.com/products/20016-seagate-expansion-2-tb-stea2000400/
https://www.solotodo.com/products/22995-seagate-backup-plus-1-tb-stbu1000103/
https://www.solotodo.com/products/30680-western-digital-my-passport-1-tb-wdbynn0010bor-wesn/
id appreciate your recommendations
5,408 (0.91/day)
Australia
WD Black 1TB I would buy and have many of them, none have failed on me.
118 (0.04/day)
Chile
6,661 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW | Sapphire PULSE RX 590
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
I have a WD elements 2tb and it is amazingly fast and reliable.
200 (0.04/day)
Switzerland
Processor Intel i5 12600K
Motherboard ASUS TUF GAMING Z690-PLUS WIFI D4
Cooling Noctua NH-U14S
Memory Crucial Ballistix DDR4 2x8GB 3600Mhz
Video Card(s) ASUS TUF RTX 3070Ti
Storage Samsung 980 PRO 1TB
Display(s) Dell S2721DGF
Case Phantek P600S/ Corsair ML140 Pro
Power Supply Seasonic Prime PX 750W
Mouse Razer Deathadder V2 Mini
Keyboard Razer Huntsman
Software Windows 11 x64
There aren't really external HDD's that are "made to be reliable". If you want "reliable" you could put a WD Red 2.5'' in a USB3 2.5'' enclosure. Otherwise any name branded HDD should be fine, the My Elements is the newer of the bunch, I would choose that.
9,781 (2.28/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
Whenever anyone asks me about external hard drive's ,I always have pretty much the same answer except for a few limited exceptions.
When you need an external drive for anything other than a low power required solution ,(imo/ime)your best bet is to purchase an external hard drive cage, or caddy, or dock and install a standard sata Drive in it. The reason I avoid external drives is because they will only ever be an external drive ,but with an external mounted sata hard drive, you have the option of using it for other applications as an internal drive or continue to use as an Extertal drive. I also use them all the time for my kids Xbox and PlayStation's for external expansion & swapping them is way easier for me, Plus there are often far more inexpensive than dedicated external drives.
So I would say purchase a $5 or $10 hard drive cage and install either one of your existing internal drives or purchase a one.i recommend Orico brand enclosures/caddies/docks. They are inexpensive & well made.
If it must be a dedicated external drive I purchased a Western Digital passport I believe and it's run for years perfectly fine as an expansion drive for my nephews Xbox one
my iphone was loading really slow, so if someone suggested this already, just ignore
mac_user
15 (0.01/day)
I would suggest this one. WD My Passport Ultra 2 TB Externe Festplatte - WDBBKD0020BWT - USB 3.0
118 (0.04/day)
Chile
the only western Drives i could buy are these
i couldnt find My passport ultra 2, there is only version 1 and it looks different.
Im between elements and My Passport, the latter one has encription, do you know if its good? the price difference is very small
https://www.wdc.com/products/portable-storage/wd-elements-portable.html
https://www.wdc.com/products/portable-storage/my-passport.html
Aquinus
Resident Wat-man
13,152 (2.89/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
I've RMA'ed two of the 4 in my RAID-5 but, the other two and the two replacements have been rock solid but, they most definitely can fail.
5,408 (0.91/day)
Australia
Im not saying WD Blacks wont fail, ALL drives fail at some point, but from all the drives I have used and sold to my clients the WD Black has been the best out of the lot, rock solid performance and with 5 yr warranty, cant be beat.
9,781 (2.28/day)
Massachusetts
Processor i7-11700K
I really never had terrible experience with any current hard drive maker. Of course I tend to stick to reliable well-known brands. Western Digital Seagate etc.
Having a warrantee is always great the problem is when it comes to hard drives, a warranty is kind of a cruel joke. because if you're at the point when your considering RMA ,your storage is lost ,your info is gone ,and you're really pissed off. I don't ever want to have to use a warranty on a hard drive, unless its a new system.
The best performing hdd, as far as reliability,& long life I've ever had are, Maxtor, then Seagate, and in last place would be western digital. I wouldn't say any of those in the list are bad , or better,those are just anecdotal experiences. My longest lasting Drive would've been a Maxtor, then followed by several long lasting Seagate drives ,& the Shortest hdd lifespan I personally had is with western digital (Maxtor is long gone too iirc) but western dig offers a good warranty, in case your patient enuff to give them another shot.seagate is like 2 years. But ime, having a hdd warranty is like having coffin insurance, or a defective codom extended warranty...if your using it, your already boned
12,304 (2.32/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
I have three Seagate USB 3.0 drives. None have failed in 4 years. Most manufactures now are fairly reliable but remember. BACK IT UP
As long as its a newer model your golden
mac_user
15 (0.01/day)
I had a positive experience with the one that I suggested, I am not 100% sure. Overal their products are good, I haven`t heard complains.
