Replacement fans for GPU?
165 (0.28/day)
Motherboard Asus Strix B550-A
Cooling Be Quiet! Dark Rock 4
Memory Gskill Trident Z DDR4-3200 (16GB x 2)
Video Card(s) Sapphire Pulse RX 7900 XT 20GB
Storage Samsung 970 Evo Plus NVME 1TB (Boot), Samsung 970 Evo Plus NVME 2TB, Samsung QVO Sata 2Tb
Display(s) Aoc 31.5" 1440p 75hz; Asus 24" 1080p 75hz (secondary)
Case Be Quiet! Silent Base 802 White
Power Supply Corsair RM750X 2021 w/ Corsair Type 4 Sleeved Red Cables
Where would I get replacement GPU fans for my RTX 4070 Asus DUAL? I like to have spares on hand. Ideally an exact match but I can't find a model number without pulling my card apart
Solution
could be CF1010U12S DC12V 0.45A for ASUS KO RTX 3060 RTX 3060 Ti RTX 3070 V2 OC
consists of two 4 pin fans ending with 7 pin 6 wire I found it on aliexpress
AsRock
TPU addict
19,175 (2.98/day)
UK\USA
Cooling D15
This early on in it's life ?, normally you'd get them from ebay.
No warranty on the card or some thing ?, you could ask the manufacture.
2,467 (1.16/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
If you can find pics of the fans' hubs (like, in a detailed review of the card), you might be able to get the model#s off the fans and find them on aliexpress or eBay.
The fans are probably shared with other models, and may already be on eBay, etc. just not listed for the 4070.
165 (0.28/day)
One of the fans has about 1mm of wobble at the rim when spinning so I'm concerned it's gonna cark it after a while
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
First two hits are replacement fans, third hit is you asking the same question on LTT
165 (0.28/day)
This is correct, however those first two hits do not have any that exactly match my card, or at least they don't spec them for this card but for triple models that may be different. I also posted on LTT to cast a wider net; someone who uses LTT but not TPU might know something, or vice versa.
1,134 (0.75/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
Solution
165 (0.28/day)
yeah that's the closest I've been able to find. I ordered a pair. Current fan should be okay until they arrive.
1,071 (0.67/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH Z333 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard Laptop built-in keyboard
Software Windows 10 Enterprise 20H2
aliexpress also has a lot of fans..... not only ebay...:rolleyes::D
165 (0.28/day)
5,305 (3.73/day)
Colorado, U.S.A.
Software Windows 11 Home
165 (0.28/day)
5,305 (3.73/day)
Colorado, U.S.A.
165 (0.28/day)
5,305 (3.73/day)
Colorado, U.S.A.
I was thinking of a plate that carries standard Noctua fans, and maybe not even bother with a shroud.
Mussels
58,413 (7.86/day)
Oystralia
Oh what I wouldn't do for a graphics card with easy-to-source replacement fans.
That's why I angrily went custom water for my 3090, no ability to source better air cooling.
165 (0.28/day)
See I could go for an AIO solution but I won't touch custom with a 10 foot pole. Wonder if NZXT still do those conversion brackets..
Mussels
58,413 (7.86/day)
Oystralia
They dont fit modern GPUs
it worked when all they had to do was cool the GPU die itself, but the VRM's and VRAM need the full cooling performance now too (let alone cards with VRAM on the back of the PCB) so they're not compatible.
Even simple changes like variants moving the VRMs to the left or right of the GPU caused headaches because they'd hit the retention brackets on heatsinks for the other components
I've still got my G12 here, but until i find a free/dirt cheap asetek unit it's not worth the price to cool a GTX 1080 (the most powerful GPU i have that fits it)
2,467 (1.16/day)
Olympia, WA
This fact keeps me wanting to see SOMEONE build a liquid-tight enclosure around a card for full-submersion cooling (without submerging the whole build).
I suppose, with the right filament, one could 3D print and finish-out a sealable container with fittings for a lines, pump, and radiator. Wouldn't be easy to tackle 'wicking' through...
165 (0.28/day)
Yeah I revisited them and the definite no for me was the fact that the auxiliary fan is on the complete wrong side for the 4070's VRMs, not to mention most would blow past the pcb and fail to cool the vram well either. Asus' included heatsink is fantastic, I just wish there were a strong and neatish way to mount noctua slims to that thing... not desperate enough for zip ties.
2,087 (0.79/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@Fastfishy2
i know more than one AIO that failed (incl me), none for the "custom" loops.
some decent AIO stuff (eisbaer/predator), can be upgraded/extended, so lot less complicated/harder to miss (ordering) parts etc when building a custom loop from scratch.
but the biggest improvement would be the lower system (gpu) temps.
gpu aio
Arctic always had great gpu aircoolers, but recent gens already come with bigger heatsinks/fans,
so i guess its not that much of a revenue for them anymore.
Mussels
58,413 (7.86/day)
Oystralia
The best way if its possible is to just replace the fans - but some GPU designs make that really hard, like blower designs or layouts that use custom sizes
there are custom water AIO' kits, but you still need a block that fits your GPU's PCB and going down that rabbit hole really shows how GPU makers give no shits about compatibility
165 (0.28/day)
Finding fans that are technically compatible and will fit has turned out to be the lesser problem. It'll basically take most Asus axial tech 95mm fans from the last couple of years, bonus compatibility if it's from an Asus KO or Dual. But the basic design between 30 and 40 series seems to really only differ by bearing type.
What's more frustrating is finding a reliable certified outlet, of which there are none. My current order is heading in from GpuFanReplacement and they claim the supplier for that fan is the same OEM that Asus uses. While it all looks to be mechanically identical, I'll have to take their word that the fan is OEM legit
Mussels
58,413 (7.86/day)
Oystralia
I got ali express ones designed 'exactly' for the blower GTX 970 i had, and all the screw holes were off so i ended up having to hack the crap out of the frame to replace the fan, and it was just as noisy as the original it was replacing -.-
A 3D printer would be amazing for this sort of thing, but the ones i'd trust to hold up to vibrating motors and long term heat are too expensive to be worth it
