System Name | Blackbelt 2 |
Processor | AMD FX 8350 |
Motherboard | ASUS M5A99FX PRO R 2.0 |
Cooling | Cooler Master Hyper TX3 evo |
Memory | 8GB Corsair Value Select DDR3 |
Video Card(s) | ASUS R7260X DC2OC 2GB |
Storage | INTEL 530 series SSD 120 GB, Seagate Barracuda 1 TB 7200 RPM |
Display(s) | DELL ST 2240L |
Case | Cooler Master Elite 311 |
Power Supply | CORSAIR VS Series 550W |
Software | Windows 7 Ultimate 64 Bit |
Benchmark Scores | 3DMark 11 6532 |
System Name | Americas cure is the death of Social Justice & Political Correctness |
Processor | i7-11700K |
Motherboard | Asrock Z590 Extreme wifi 6E |
Cooling | Noctua NH-U12A |
Memory | 32GB Corsair RGB fancy boi 5000 |
Video Card(s) | RTX 3090 Reference |
Storage | Samsung 970 Evo 1Tb + Samsung 970 Evo 500Gb |
Display(s) | Dell - 27" LED QHD G-SYNC x2 |
Case | Fractal Design Meshify-C |
Audio Device(s) | on board |
Power Supply | Seasonic Focus+ Gold 1000 Watt |
Mouse | Logitech G502 spectrum |
Keyboard | AZIO MGK-1 RGB (Kaith Blue) |
Software | Win 10 Professional 64 bit |
Benchmark Scores | the MLGeesiest |
Processor | Ryzen 9 5900X |
Motherboard | MSI B450 Tomahawk ATX |
Cooling | Cooler Master Hyper 212 Black Edition |
Memory | VENGEANCE LPX 2 x 16GB DDR4-3600 C18 OCed 3800 |
Video Card(s) | XFX Speedster SWFT309 AMD Radeon RX 6700 XT CORE Gaming |
Storage | 970 EVO NVMe M.2 500 GB, 870 QVO 1 TB |
Display(s) | Samsung 28” 4K monitor |
Case | Phantek Eclipse P400S (PH-EC416PS) |
Audio Device(s) | EVGA NU Audio |
Power Supply | EVGA 850 BQ |
Mouse | SteelSeries Rival 310 |
Keyboard | Logitech G G413 Silver |
Software | Windows 10 Professional 64-bit v22H2 |
Does the card have a adaptive fan off feature? My XFX RX 480 has the fans off when idling unless the GPU heats up past 60° C. My GPU temperature fluctuates between 43-52° C when idle.I ordered RTX 2060 yesterday, but I have issue. In idle, It reaches 45-49 degress. My case has 2 fans. It is ATX case.
System Name | My PC |
Processor | 4670K@4.4GHz |
Motherboard | Gryphon Z87 |
Cooling | CM 212 |
Memory | 2x8GB+2x4GB @2400GHz |
Video Card(s) | XFX Radeon RX 580 GTS Black Edition 1425MHz OC+, 8GB |
Storage | Intel 530 SSD 480GB + Intel 510 SSD 120GB + 2x500GB hdd raid 1 |
Display(s) | HP envy 32 1440p |
Case | CM Mastercase 5 |
Audio Device(s) | Sbz ZXR |
Power Supply | Antec 620W |
Mouse | G502 |
Keyboard | G910 |
Software | Win 10 pro |
Only 2-3 degrees decrease.Open case and see what temps you get on idle.
Powerboost ATX case. Sorry I don't know.Which case please...?
Do you have a sound card or any other cards in nearby slots?..
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
I tried but It doesn't work.go into nvidia control panel, change power setting to either adaptive, or power saving, then hit apply. it might help.
remember, your GPU will only be able to be as cool as your cases ambient, so whatever the temp in your case is, thats the LOWEST your GPU can be.
System Name | AlderLake / Laptop |
Processor | Intel i7 12700K P-Cores @ 5Ghz / Intel i3 7100U |
Motherboard | Gigabyte Z690 Aorus Master / HP 83A3 (U3E1) |
Cooling | Noctua NH-U12A 2 fans + Thermal Grizzly Kryonaut Extreme + 5 case fans / Fan |
Memory | 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13 |
Video Card(s) | MSI RTX 2070 Super Gaming X Trio / Intel HD620 |
Storage | Samsung 980 Pro 1TB + 970 Evo 500GB + 850 Pro 512GB + 860 Evo 1TB x2 / Samsung 256GB M.2 SSD |
Display(s) | 23.8" Dell S2417DG 165Hz G-Sync 1440p / 14" 1080p IPS Glossy |
Case | Be quiet! Silent Base 600 - Window / HP Pavilion |
Audio Device(s) | Panasonic SA-PMX94 / Realtek onboard + B&O speaker system / Harman Kardon Go + Play / Logitech G533 |
Power Supply | Seasonic Focus Plus Gold 750W / Powerbrick |
Mouse | Logitech MX Anywhere 2 Laser wireless / Logitech M330 wireless |
Keyboard | RAPOO E9270P Black 5GHz wireless / HP backlit |
Software | Windows 11 / Windows 10 |
Benchmark Scores | Cinebench R23 (Single Core) 1936 @ stock Cinebench R23 (Multi Core) 23006 @ stock |
Whether I replace thermal paste, Will it changes?That card has just a block of aluminium with a few heatpipes to cool it, ofcourse it runs hotter than any other card with actual fins.
System Name | Ryzen Reynolds |
Processor | Ryzen 1600 - 4.0Ghz 1.415v - SMT disabled |
Motherboard | mATX Asrock AB350m AM4 |
Cooling | Raijintek Leto Pro |
Memory | Vulcan T-Force 16GB DDR4 3000 16.18.18 @3200Mhz 14.17.17 |
Video Card(s) | Sapphire Nitro+ 4GB RX 580 - 1450/2000 BIOS mod 8-) |
Storage | Seagate B'cuda 1TB/Sandisk 128GB SSD |
Display(s) | Acer ED242QR 75hz Freesync |
Case | Corsair Carbide Series SPEC-01 |
Audio Device(s) | Onboard |
Power Supply | Corsair VS 550w |
Mouse | Zalman ZM-M401R |
Keyboard | Razor Lycosa |
Software | Windows 10 x64 |
Benchmark Scores | https://www.3dmark.com/spy/6220813 |
If I use this graphic card in 80 degrees, Will it reduces lifespan or it makes other risks?
Thanks.it will slow itself down to accommodate the temperature if it gets too hot.
id highly suggest you follow the advice given earlier in the thread. the answers to this issue are in the thread.
good luck.
I set %100 load to fan.Msi afterburner, download it and set a more aggressive fan profile.
Thermal and Power Specs:
Maximum GPU Temperature (in C) = 88
Graphics Card Power (W) = 160
Recommended System Power (W) = 500
Supplementary Power Connectors = 8 pin
System Name | Best AMD Computer |
Processor | AMD 7900X3D |
Motherboard | Asus X670E E Strix |
Cooling | In Win SR36 |
Memory | GSKILL DDR5 32GB 5200 30 |
Video Card(s) | Sapphire Pulse 7900XT (Watercooled) |
Storage | Corsair MP 700, Seagate 530 2Tb, Adata SX8200 2TBx2, Kingston 2 TBx2, Micron 8 TB, WD AN 1500 |
Display(s) | GIGABYTE FV43U |
Case | Corsair 7000D Airflow |
Audio Device(s) | Corsair Void Pro, Logitch Z523 5.1 |
Power Supply | Deepcool 1000M |
Mouse | Logitech g7 gaming mouse |
Keyboard | Logitech G510 |
Software | Windows 11 Pro 64 Steam. GOG, Uplay, Origin |
Benchmark Scores | Firestrike: 46183 Time Spy: 25121 |
Processor | i7 8700k 4.6Ghz @ 1.24V |
Motherboard | AsRock Fatal1ty K6 Z370 |
Cooling | beQuiet! Dark Rock Pro 3 |
Memory | 16GB Corsair Vengeance LPX 3200/C16 |
Video Card(s) | ASRock RX7900XT Phantom Gaming |
Storage | Samsung 850 EVO 1TB + Samsung 830 256GB + Crucial BX100 250GB + Toshiba 1TB HDD |
Display(s) | Gigabyte G34QWC (3440x1440) |
Case | Fractal Design Define R5 |
Audio Device(s) | Harman Kardon AVR137 + 2.1 |
Power Supply | EVGA Supernova G2 750W |
Mouse | XTRFY M42 |
Keyboard | Lenovo Thinkpad Trackpoint II |
Software | W10 x64 |
I will try. I used GTX 1050 Ti, sometimes It reached 75 C and I replace paste, It reduced 10 C.I bought a Gigabyte Vega 64 Gaming card and was having the same issues as you. What I did was open the card only to find that most of the Thermal Paste was stuck in the heat pipes. I used some Noctua thermal paste and it dropped temps by over 20 C. From the low 80s to the low 60s when gaming.
Processor | AMD Ryzen 5 2600 (Covered with Cooler Master MasterGel Pro) |
Motherboard | ASRock B450 Steel Legend, BIOS Version: 8.01 [Beta] |
Cooling | Cooler Master MasterLiquid ML120L V2 RGB, 5x Galax Vortex Wind-02 (3xFront Intake, 2x Top exhaust) |
Memory | Kingston FURY Beast RGB 3600 MT/s 32 GB (8 GB x4), (KF436C17BBA/8) |
Video Card(s) | Palit GeForce GTX 1660 Ti Dual OC |
Storage | Kingston NV2 1 TB |
Display(s) | MSI PRO M251 (HDMI), Running @104 Hz |
Case | Cooler Master MasterBox MB520 |
Audio Device(s) | HP H360G USB |
Power Supply | Cooler Master MWE 550 80+ White |
Mouse | HP G200 Black |
Keyboard | Redragon MITRA K551-1 RGB |
Software | Windows 11 Home |
Actually no , but your temps should be lower than that , i mean those new cards are cold.If I use this graphic card in 80 degrees, Will it reduces lifespan or it makes other risks?
System Name | 4K-gaming |
Processor | AMD Ryzen 7 5800X h2o |
Motherboard | Gigabyte B550M Aorus Elite |
Cooling | Custom loop |
Memory | 48GB Kingston DDR4-3200 |
Video Card(s) | Asus GeForce RTX 3080 TUF OC h2o |
Storage | ~3TB SSDs + 6TB external HDDs |
Display(s) | Acer 27" 4K120 IPS + Lenovo 32" 4K60 IPS |
Case | Corsair 4000D Airflow White |
Audio Device(s) | Asus TUF H3 Wireless |
Mouse | Logitech MX518 + Asus TUF P1 mousepad |
Keyboard | Roccat Vulcan 121 AIMO |
VR HMD | Oculus Rift CV1 |
Software | Windows 11 Pro |
Benchmark Scores | It runs Crysis |
Mouse | XTRFY M42 |
80C ain't nothing. I consider a GPU/CPU running too hot when it throttles.
System Name | The work PC /2700x/5950x |
Processor | 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V |
Motherboard | Gigabyte AORUS Master X570/2xMSI X470 M7 AC |
Cooling | Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE |
Memory | 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400 |
Video Card(s) | 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI |
Storage | 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro |
Display(s) | Dell UltraSharp U2518D/2408WFP |
Case | Corsair 800D / Lian test bench/NZXT 500 |
Power Supply | AX 850 Titanium/AX 860i/AX 760 |
Software | Dual boot/Win 10 / Linux / Win 10+Linux |
