Hi guys!
So I just got 2070 gaming z, then used msi oc scanner and when it set a curve of +135 core clock I was using it for a couple of days without problems. Then I booted up Resident Evil 2 and suddenly white artifacts everywhere! I noticed in that moment power usage was 104 while power limit was set to 100 in afterburner, so I thought I happened because there wasn't enough power so I reset clock speed to stock and raised power limit to max, then ran furmark test. After a couple of minutes same white artifacts, so I restarted pc, returned power limit to 100 and ran furmark again with everything on stock for 30 min twice and everything was fine, also all games ran fine after hours of playing (ac oddisey, kingdom come, metro exodus...)
Now my question is, what does this mean!? Is there insufficient power from psu? Is it because I raised power limit without touching core voltage? Could it be that it's just unstable at max power limit? Or is it a faulty card perhaps?
Psu is coolermaster b600 rev.2 (Yes I know its not ideal and I should get a better one, but since I don't have optical drive or ssd or anything of that sort that would draw more power I thought it was enough, am I wrong?)
It's only been 2 weeks since I got the card and if it's faulty I would really like to return it asap so any insight would be greatly appreciated! Thanks!
