RTX 3080 Crash to Desktop Problems Likely Connected to AIB-Designed Capacitor Choice
rtwjunkie
PC Gaming Enthusiast
14,030 (2.32/day)
Louisiana
Processor Core i9-9900k
I'm ha haw-ing that the scalpers bought all the first cards and they are broken.
fuck them anyway.
I doubt many of them are offering refunds. As far as they are concerned they made money and moved on. So this doesn’t hurt them at all.
874 (0.19/day)
Australia
System Name ATHENA
Processor AMD 7950X
Motherboard ASUS Crosshair X670E Extreme
Cooling ASUS ROG Ryujin III 360, 13 x Lian Li P28
Memory 2x32GB Trident Z RGB 6000Mhz CL30
Video Card(s) ASUS 4090 STRIX
Storage 3 x Kingston Fury 4TB, 4 x Samsung 870 QVO
Display(s) Acer X38S, Wacom Cintiq Pro 15
Case Lian Li O11 Dynamic EVO
Audio Device(s) Topping DX9, Fluid FPX7 Fader Pro, Beyerdynamic T1 G2, Beyerdynamic MMX300
Power Supply Seasonic PRIME TX-1600
Mouse Xtrfy MZ1 - Zy' Rail, Logitech MX Vertical, Logitech MX Master 3
Keyboard Logitech G915 TKL
VR HMD Oculus Quest 2
Software Windows 11 + Universal Blue
"The crashing with the RTX 3080 cards doesn’t appear to be down to the caps used, which is why we haven’t made a video yet, we don’t know the issue. What we do know is the FE and TUF Gaming models crash just as much as other models and they use MLCC’s."
Not over yet (although the lack of MLCC's probably doesn't help).
Rashkae
4 (0.00/day)
On Reddit many people are reporting that the crashes stop once they use 2 dedicated power connectors instead of a splitter.
874 (0.19/day)
Australia
System Name ATHENA
Processor AMD 7950X
I wouldn't be surprised, but those in the tech press such as Igor & HWU have had the same issue and they aren't that dumb, lol.
5,717 (0.92/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
EVGA has clarified the issue
Rashkae
4 (0.00/day)
True, so it seems to point more at the limits of Samsung 8nm
And Asus uses no cheap POSCAPs at all and there have been crash reports
348 (0.09/day)
Marabá - Pará - Brazil
System Name KarymidoN TitaN
Processor AMD Ryzen 7 5700X
Motherboard ASUS TUF X570
Cooling Custom Watercooling Loop
Memory 2x Kingston FURY RGB 16gb @ 3200mhz 18-20-20-39
Video Card(s) MSI GTX 1070 GAMING X 8GB
Storage Kingston NV2 1TB| 4TB HDD
Display(s) 4X 1080P LG Monitors
Case Aigo Darkflash DLX 4000 MESH
Power Supply Corsair TX 600
Mouse Logitech G300S
Sauce: https://forums.evga.com/Message-about-EVGA-GeForce-RTX-3080-POSCAPs-m3095238.aspx
5,717 (0.92/day)
POSCAP is more expensive than MLCC it seems. But sure, carry on with your pitch forks
348 (0.09/day)
Does this mean a recall is coming? If so not very good for Nvidia.
no recall, the issue happens when the chip boosts on high clockspeeds, they will "FIX" it by limiting the clockspeeds in firmware or via driver update. the consumer will get less performance but who cares amiright?
278 (0.06/day)
Processor 12900K @5.1all Pcore only, 1.23v
Motherboard MSI Edge
Cooling D15 Chromax Black
Memory 32GB 4000 C15
Video Card(s) 4090 Suprim X
Storage Various Samsung M.2s, 860 evo other
Display(s) Predator X27 / Deck (Nreal air) / LG C3 83
Case FD Torrent
Audio Device(s) Hifiman Ananda / AudioEngine A5+
Power Supply Seasonic Prime TX 1000W
Mouse Amazon finest (no brand)
Keyboard Amazon finest (no brand)
VR HMD Index
Benchmark Scores I got some numbers.
523 (0.11/day)
With all the bad press and hiccups with the rtx3000 series, AMD has the red carpet rolling for it to make a grand entrance. It's impressive how lucky they have been in the past few years. Sure they did great work, but their competition also weren't at their best.
2,837 (1.61/day)
Which MLCC? Which POSCAP?
* Here's a $0.30 POSCAP: 6.3V 150uF 3528 sizing
* Here's a POSCAP that's $1.64: 6.3V 150uF 2917 sizing
* Here's a $1.53 MLCC 6.3V 150uF 1210 size.
* Here's a $0.27 6.3V 150uF 1206 size MLCC.
Yeah, all are 150uF and 6.3V rated. I did that on purpose, because there's many, many, many other specifications on capacitors than just voltage, capacitance, chemistry, and size. (150uF is huge for the sizes we're talking about. I probably should have picked a smaller size... too late, I'm not looking all this stuff up again)
EDIT: Ah crap, I forgot to normalize for Metric-Size vs American-size. Whatever.
There are expensive MLCCs, there are cheap MLCCs, there are expensive POSCAPs, there are cheap POSCAPs. There are big MLCCs, there are small MLCCs, there are big POSCAPs, there are small POSCAPs, there are low ESR and then lower ESR caps, there are ESL-optimized caps, there are frequency optimized caps. There are multi-terminal caps, there are 2-terminal caps. There are sideways caps. There are stacked caps.
There are 755,004 MLCCs available for purchase from Digikey. There are 13,507 Tantalum-Polymer Capacitors for purchase from Digikey. There are KEMET POSCAPs, there are Panasonic POSCAPs, there are Samsung POSCAPs, there are Vishaay POSCAPs. There are AVX MLCCs, there are KEMET MLCCs, there are Murata MLCCs.
But Vishaay is more known for their resistors not really their caps. Murata is known for their MLCCs. KEMET is known for... I forget. There's a reputation for each of these companies to keep track of too.
I should note: high-speed digital circuits with high-power and high-frequencies with multilayer PCB boards was a subject I ran away screaming from in college. That's literally one of the hardest subjects I've ever seen in my life. Yes, choosing the wrong capacitor can cause issues, but other mistakes include having your PCB-traces the wrong length (too long, or too short), or come at various angles, or otherwise messing up your transmission line characteristics.
Do you see that? You literally just made a capacitor here because any copper running with some insulator in between them makes capacitance. Did your PCB trace make a turn? Congratulations, you now have parasitic inductance, and the signal may reflect off of the copper corner. Will that mess up your design? Maybe.
BigJonno
1 (0.00/day)
Looks like Asus Tuf Gaming RTX3080 also has a poscap version out there!
edit: This is the Tuf Gaming non OC version.
290 (0.08/day)
EVGA confirms the issue with the capacitors
Recently there has been some discussion about the EVGA GeForce RTX 3080 series.
During our mass production QC testing we discovered a full 6 POSCAPs solution cannot pass the real world applications testing. It took almost a week of R&D effort to find the cause and reduce the POSCAPs to 4 and add 20 MLCC caps prior to shipping production boards, this is why the EVGA GeForce RTX 3080 FTW3 series was delayed at launch. There were no 6 POSCAP production EVGA GeForce RTX 3080 FTW3 boards shipped.
But, due to the time crunch, some of the reviewers were sent a pre-production version with 6 POSCAP’s, we are working with those reviewers directly to replace their boards with production versions.
EVGA GeForce RTX 3080 XC3 series with 5 POSCAPs + 10 MLCC solution is matched with the XC3 spec without issues.
Also note that we have updated the product pictures at EVGA.com to reflect the production components that shipped to gamers and enthusiasts since day 1 of product launch.
Once you receive the card you can compare for yourself, EVGA stands behind its products!
Thanks
EVGA
https://forums.evga.com/m/tm.aspx?m=3095238&p=1
2,219 (0.43/day)
Why should any customer purchase feature stripped and unreliable hardware that performs at thermal limits of its components burning down your house.
Computer hardware is well protected against Overcurrent, Shorting out and all that. That's not the issue.
You got a AIB here that skimps out on parts that nvidia initially recommends. If the card is sold at the same price as the rest then their intention is just to make more profit over each sold card.
484 (0.15/day)
The Ampere disaster continues.
There is a consequence when you rush release GPUs made on a poor process node that use up to 400W. We've never had cards in living memory that draw so much power, it's ridiculous.
