RTX 3080ti AMP Holo Power limit
48 (0.01/day)
Hi all,
I recently grabbed a RMAed RTX 3080ti AMP Holo and noticed severe power throttling at 4k, it can hardly maintain 1710mhz, I had no clue about the 2 pin cards being severely power limited, its crazy that my card can only average around 330W not even hitting the 350W and power slider does nothing.
I was wondering if zotac eventually released any better bios ? , I have searched everywhere I cant find any better zotac bios and there are posts about flashing AMP Holo extreme bios but apparently it only increases the power consumption but the clocks are so low as its a 3 pin card, its worse than the original bios, so its not worth it.
I was wondering if there was any other Manufacturer BIOS that works , if anyone has tried with success?
Based on my analysis , possible contenders
EVGA RTX 3080 TI XC3 ULTRA (Port also matches)
GIGABYTE RTX 3080 Ti GAMING OC (Port mismatch)
GIGABYTE RTX 3080 Ti VISION OC (Port mismatch)
ASUS TUF RTX 3080 Ti GAMING OC (Port mismatch)
Please let me know if anyone found any better ways.
PS : attached image showing my throttling
Deleted member 185088
I will try to see how my 3080ti behaves at 4k and let you know, it's an MSI 3 thing, and also has only 2 pin power.
38 (0.01/day)
You're cooler seems maxed out as well, so don't think a higher power level bios would do much if you don't watercool it first.
48 (0.01/day)
Thanks, do let me know
Yes i am almost hitting the temp limit but I can manage to add more fans or open the case to minimize it, but before I do something for temps i want to see if anything can be done for the power throttle, Zotac asks me to send the unit for RMA, I doubt this will be fixed with RMA.
Seems mine hits 341w during gameplay with 350w as max. Frequency low 1700
48 (0.01/day)
Ah its almost the same, only mine never has hit 350 ever, 341 is the max and averages 330W, but yea the freq seems matching but I saw a lot of threads with MSI having similar issues, from what I have read Asus or EVGA seems better, haven't seen anything about gigabyte but gigabyte is the one with higher power limit in the 2 pin cards.
2,980 (2.05/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
pretty normal.
clean, repaste and get new pads.
freeagent
9,521 (4.09/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
A little O.T..
I noticed my ZOTAC 4070 Ti has a 400w limit, but can only do like 340w. I only mention it because it is the “new” 3080ish type card :D
48 (0.01/day)
pretty normal.
Dont think it has got anything to do with repasting, this is Power throttle, mostly likely bios hard coded to 90% TDP
A little O.T..
Ah wow, are they still doing these things, seriously what's the point of putting 400W in specification if they are going to gimp the card purposely
2,980 (2.05/day)
Germany
i don't talk about the powerlimit. i talk about the atrocious temps (if you don't have 40°C ambient at the moment)
i own a 3080 Ti as well and it was locked to exactly 91% of the Powerlimit (Gaming OC from Gigabyte) the powerlimit slider did nothing as well.
seems to be a 3080 Ti thing. (and i flashed mine with a handful of bioses and it never changed)
48 (0.01/day)
Yea my ambient is around 32, i agree about the temps , mostly will try RMA for the temps but with undervolting I can live with it, powerlimit is very concerning.
if you have already tried flashing different bios and its still not working, its bad, thanks for letting me know !!
1,176 (0.71/day)
System Name Gamey #1 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 ProVDH M
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) Ventus 3060 / Challenger B580
Storage 4TB Team MP34 / 2TB WD SN570
Case Corsair 4000Air / TT Versa H18
Power Supply EVGA 650 G3 / EVGA BQ 500
GPU Chip Power Draw: 150W
Board Power Draw: 316W
That CANNOT be the way it's supposed to work is it? I don't have any Ampere GPUs :( but my Turing and Pascal GPUs have the GPU Chip Power drawing about 2/3 or more of the total board power budget, not less than half. The low GPU Chip power makes sense on it's own as you're running at a low 0.862V but you should absolutely NOT have a 79°C card with such low voltages and GPU Chip power draw.
Something's wrong here but I don't know enough to suggest what the causative agent is. RMA sounds like a good strategy.
2,980 (2.05/day)
Germany
PWR SRC is often equal to the chip power draw.
48 (0.01/day)
Its strange, how the reviewer was able to get around 350w in his testing with the same card, could it be the motherboard limiting something ? , its very strange
in the Power limits sections , reviewer is talking as if the slider is working, is it possible they sent without limits on the review model or the one i am having is really having some issues
477 (0.08/day)
System Name -
Processor Ryzen 9 5900X
Motherboard MSI MEG X570
Cooling Arctic Liquid Freezer II 280 (4x140 push-pull)
Memory 32GB Patriot Steel DDR4 3733 (8GBx4)
Video Card(s) MSI RTX 4080 X-trio.
Storage Sabrent Rocket-Plus-G 2TB, Crucial P1 1TB, WD 1TB sata.
Display(s) LG Ultragear 34G750 nano-IPS 34" utrawide
Case Define R6
Audio Device(s) Xfi PCIe
Power Supply Fractal Design ION Gold 750W
Mouse Razer DeathAdder V2 Mini.
Keyboard Logitech K120
VR HMD Er no, pointless.
Software Windows 10 22H2
Benchmark Scores Timespy - 24522 | Crystalmark - 7100/6900 Seq. & 84/266 QD1 |
The GPU temps looks normal, however the RAM while prolly in-spec, is a bit toasty. Ive neve rbeen a fan of Zotac card as thier cooling solutions were always sub-par imho. If your not happy and are able to, send it back for a full refund.
48 (0.01/day)
Ah, looks good, hope something comes out for us, does it mean we can read the BIOS and see if its really hard capped power limit wise, is there any bios file reader or something?
7,542 (3.23/day)
California
System Name His & Hers
Storage lots of SSD.
What I am seeing on my EVGA RTX 3080ti FTW 3 Ultra after about 30m steady state. Only thing I changed was running with max power limits all other settings stock out of the box in the OC profile. I normally run the card at around 340w so the temps sorta surprised me not bad for over 400w I guess....
My understanding is that we can flash higher wattage bios. Maybe this weekend I'll try flashing a better bios.
3,127 (2.37/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
There's something wrong with your card.
I have a TUF Gaming 3080 Ti (2x 8-pin power) and it easily reaches 355W during benchmark runs, with momentary peaks up to 359W. This is with the factory OC, no other settings changed. Actual real-world gaming loads are probably 5W lower (depending on the title of course). This one has a full-length waterblock on it but I remember getting similar results with the factory air cooler before I modded it for liquid cooling.
There's also a TUF Gaming 3080 (also 2x 8-pin power) in the house. This one peaks at 352W with the original factory air cooler. Again, this is with the manufacturer OC, no other settings changed.
I benchmark infrequently, just to optimize fan curves since I know actual gaming loads are less. I typically do this on the hottest days of the year because I know the other 360 days the system will run quieter. This year, I probably won't bother with tweaking the fan curves; there are multiple systems in the house and their fan curves were optimized last year.
One important thing is that different benchmark software (like games) provide different loads on the graphics card. I generally rely on Unigine Heaven and Unigine Superposition to set fan curves since they seem to max the card temperature yet also are more gamelike with their varied scenes. I don't use Furmark or Kombustor for fan curve optimization for this reason.
Anyhow I'd RMA the card if I were in your shoes. It is unlikely you are getting average performance for that GPU using 20W less.
Best of luck.
6,179 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
FE here, no problems pulling 350W at stock with 99% load.
75 (0.10/day)
System Name Desktop + SteamDeck OLED
Processor i7-10700K @ -0.130mV offset
Motherboard MSI MPG Z490 Gaming Edge WiFi
Cooling be quiet! Pure Loop 280mm
Memory Corsair Vengeance RGB Pro 32GB 3200MT/s CL16
Video Card(s) RTX 3080 Ti Founders Edition @ 1830MHz, 800mV
Same, and with a powerlimit increase and under-volt it'll sit happy at 1950MHz at 900mV with 400W power draw
48 (0.01/day)
Yes, this is exactly my problem, I cant for the life of me get anywhere near 1800, let alone 1900!! , it power throttles so much, I think its to do with the ZOTAC bios in itself, that's why I thought of flashing Asus bios but people say it doesn't work. I don't want to take the risk as I don't have integrated graphics or another graphics card to rollback vbios if something goes wrong
Also techpowerup review of this same exact card could pull 350w, I am so confused, I am going to try RMA , hope I don't get the same problem again!
@GerKNG or @Xex360 , have you tried ASUS TUF BIOS ? , maybe one of the DP wont work with this vbios though.
75 (0.10/day)
You could try an under-volt to keep it off the power limit. 1830MHz at 850mV is a good target to try and that would keep you below 350W. But yeah something more seems wrong if that model performs as expected for reviews but not yours, RMA sounds like a good idea before flashing anything
3,127 (2.37/day)
The card is defective.
Consumers shouldn't have to jump through hoops (undervolting, overclocking, repasting, whatever) just to get expected average results. Those average results are with off-the-shelf units, pulled out of the box and plugged into the motherboard.
About a month ago I bought a B stock graphics card from EVGA. It crashed three times in an hour. So I did a clean uninstall and reinstall of the device driver software. Three more crashes in the next hour. So I RMA-ed it.
I didn't try to undervolt it, didn't tweak the clock settings, didn't hack the registry, didn't sacrifice a chicken, didn't do anything. I just waited for the RMA approval to show up in my e-mail inbox then shoved it in a box with the necessary documentation and walked to the UPS Store to drop it off.
I received a replacement card (again B stock) from EVGA about 10 days later. Works fine with zero effort on my behalf. I didn't even reinstall the drivers. Plug and go.
