RX 580 fan controller bypass query. Stuck at almost full fan speed.
246 (0.06/day)
Assam (India)
System Name myLastOne
Processor Intel Core i7 12700F @ PL1=PL2=150 Watts
Motherboard MSI B660M MAG Mortar
Cooling Deepcool AK400 + CM Sickleflow 120mm (Push|Pull)
Memory 2x 16GB Crucial Ballistix 3600MHz 16-18-18-38
Video Card(s) Asus TUF RTX 3060 Ti Gaming OC
Storage TeamGroup MP33 Pro M2 1TB + (1+2)TB Seagate + 2TB WD
Display(s) BenQ EW2775ZH
Case CM Elite 371 USB3 With Arctic F14 (Side+Front) + Arctic Bionix F120 (Back) + CM 120mm (Top)
Audio Device(s) Realtek ALC 1200 + Swans D1010-IV
Power Supply MSI MPG A750GF
Mouse Logitech G102 LightSync
Keyboard Logitech G100
VR HMD None
Software Windows 11 PRO
Hi, I have a Sapphire RX 580 8GB OC.
SKU# 11265-05-41G
My graphics card fans are stuck at full speed irrespective of the load and heat. Trying to control fan speed through the driver or Afterburner has resulted in failure. Removing and reseating the 4pin pwm fan header also yielded no positive results either. While searching techpowerup forums I came across a thread with similar problems underlined. In that same thread the graphics card was diagnosed with a failed fan controller and was advised to return it.
I would like to ask if my fan controller is damaged would there be a way to connect the graphics card fans into the motherboard itself bypassing the graphics cards fan controller and using the fan controller of the motherboard. Also, could something be done with a software tool (maybe) to read the temperature of the gpu and adjust the fans accordingly through the pwm fan controller of the motherboard.
Any help would be greatly appreciated. Thank you.
146 (0.04/day)
Processor Amd Ryzen 7 Pro 1700@3.6Ghz
Motherboard Asus Prime B350 Plus (needed pci slot for Ht Omega Claro Halo)
Cooling Noctua C-14
Memory 16GB A-Data DDR4-3200
Video Card(s) AMD Radeon Pro Duo
Storage Patriot Torch 512gb, Seagate Barracuda 512gb , Adata 128gb SSDs & 1TB Western Digital Black
Display(s) Seiki 39" 4k
Case MetallicGear Neo Air
Audio Device(s) Ht Omega Claro Halo
Power Supply Rosewill Glacier 850 watts
Mouse Ancient Razor Diamondback
Keyboard Logitech Illuminated
Software Windows 10 Home 64-Bit
I have to ask since you didn't specify, did you exit out of Afterburner? The fans should go back to normal speeds once you exit the program. You may have to go into 'Task Manager' and do an 'end task' on MSIafterburner.
246 (0.06/day)
Assam (India)
VR HMD None
Yes I did, even in safe mode the fans are full speed. Even during POST!
146 (0.04/day)
Cooling Noctua C-14
I would turn the pc off, switch the power supply off and leave it for a few minutes. Then try again.
246 (0.06/day)
Assam (India)
VR HMD None
Yes did that too.
146 (0.04/day)
Cooling Noctua C-14
Ok, Go into Amd Radeon Software and go to the performance tab for your gpu and reset it (top right corner) under 'sidebar'.
You can also try resetting your pc bios.
246 (0.06/day)
Assam (India)
VR HMD None
No change, I even boot up with a live disc linux!
Edit: Ran pc without driver still fan almost at full speed
146 (0.04/day)
Cooling Noctua C-14
Well, if the fan is 100% right from when you boot the pc and it wasn't before msiafterburner I would have to assume the fan speed is sticking for some reason. Did you try removing the bios battery when you turned off the power supply?
Also, if you capable, you could remove the graphics card from the pc and leave it off for a few hours maybe even overnight, then re-install the card and turn the power supply back on and boot the pc.
Are you sure you didn't do anything else to cause this? Such as bios mods?
246 (0.06/day)
Assam (India)
VR HMD None
Yes 100% right from boot. The temperature is below 45C and no load still. Motherboard bios battery not removed. I did remove and leave the graphics card overnight no change. No bios mod, bought it new 4 years ago.
Edit: I was playing a game when this happened.
146 (0.04/day)
Cooling Noctua C-14
Maybe the bois screwed up on it? I have seen that before, although not often.
246 (0.06/day)
Assam (India)
VR HMD None
Which bios you are talking about, gpu bios or motherboard bios?
146 (0.04/day)
Cooling Noctua C-14
FreedomEclipse
~Technological Technocrat~
23,753 (3.75/day)
London,UK
System Name Codename: Icarus Mk.VI (Soon to be retired)
Processor Intel 8600k@Stock
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G502 X
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Looks like this is a continuation of an issue from May 2020
At this stage-
1) Either the thermal sensor is toast and causing the fans to run at 100%
2) the onboard fan controller is toast and runs the fans at 100%
There are a few solutions.
1. Look for a dead card with the same SKU and rip the cooler off that one
2. Replace the cooler with one from Raijintek or Arctic Cooling.
3. Replace the Graphics card entirely.
4. Rip the shroud off the heatsink assembly and ghetto rig your own fans on to the heatsink with cable ties
Use a 3pin fan to sata adapter to run those fans. Arctic Cooling P12 fans are absolutely cheap as chips in most places and they are exceptionally good fans
Option 1 & 2 are not guaranteed to fix your graphics card.
146 (0.04/day)
Cooling Noctua C-14
In reality, 100% fan on a Rx580 probably isn't all that loud. I have been running 4 pc's full of cards with 100% in different rooms and it's not that terrible.
246 (0.06/day)
Assam (India)
VR HMD None
Not actually, in that case the temp. has to reach 70C and only then fan would rev up (to maintain 70C all along). This time its not the case, even at 40C fans are 100%.
Yes, I agree with the fan controller going bad.
#1 Not possible at the moment
#2 gpu coolers are not available in my country. Maybe atleast not at the moment.
#3 Not possible at the moment
#4 Yes possible and the exact thing I was thinking but why run the fans through sata? Also the gpu fans are working fine, only the fan controller is gone, could I connect the fans onto the mobo header instead?
Again if I go with your Arctic cooling fans hack would it be possible to connect them the motherboard itself and not the sata ones; Could these be temperature controlled as in when the gpu temp. rises, fan speed rises too?
Thank you.
FreedomEclipse
23,753 (3.75/day)
London,UK
Thank you.
Its upto you however you wish to power them. the sata power adapter was just a suggestion in case you didnt have spare fan headers.
Optionally you can get the PWM version of the P12 fans and a PWM splitter. Depending on your board manufacturer and age of your board you can set which fans ramp up when your graphics card reaches a certain temperature.
You might not even need two P12's Maybe even one will be fine as it will push more air than the stock fans ever could at full RPM.
Run one P12 at full RPM or Two P12s at half RPM if youre not doing the PWM thing.
246 (0.06/day)
Assam (India)
VR HMD None
...you can set which fans ramp up when your graphics card reaches a certain temperature.
How to do this? I think motherboard fan header controllers can read only cpu temp. and control fan speed accordingly (not sure)? Can the motherboard fan header and fan controllers read gpu temp. and adjust fan speed accordingly? What softwares would you need to do this? Afterburner?
Thank you.
FreedomEclipse
23,753 (3.75/day)
London,UK
You do it in the bios. I think for Asus it should be in the fan control or a Q-Fan settings.
All headers should read fan RPM but fan control will only be provided if you have 4 pin PWM fans in a pwm header.
Its alot easier just to get something like a 3-pin Fan Resistor Cable that can lower the fan speed by 25-50% and have them going at that speed 24/7 rather than mess with the bios. Buy the P12 fans first and see how loud they are at full rpm, If they are too loud then get one of those fan resistor cables to slow them down so you get all of the cooling but without the noise. The one i linked to is just an example, There are many other manufacturers that make the same kind of cable/adapter if you cant manually lower the fan speed in the bios.
246 (0.06/day)
Assam (India)
VR HMD None
I do not have q-fan but would this do?
I have got two free 4pin fan headers. So there's no way of controlling fan rpm with 3pin header? Did not knew that, thanks.
I do not like this idea, guess I will go with the bios one.
Currently I do not have the fans, will have to order. Will get back when I get it.
Thank you so much!
FreedomEclipse
23,753 (3.75/day)
London,UK
Im not familiar with that bios so you'll just have to read through your manual or just play around to see if its possible. You want to set the GPU as 'target source' - if you cant see anything about that in the bios then I assume its not possible.
Some Asus boards allow traditional 3 pin fans to be controlled in the same way as a PWM 4 pin fan from the bios but I have never managed to get it to work. I may have needed to install Asus Ai Monitor to get it working but I never install the software that is normally supplied with motherboards and there are better software available when it comes to monitoring voltages and temperatures so i dont bother.
500 (0.28/day)
Processor i9-9900K @ 5.1GHz (H2O Cooled)
Motherboard Gigabyte Z390 Aorus Master
Cooling CPU = EK Velocity / GPU = EK Vector
Memory 32GB - G-Skill Trident Z RGB @ 3200MHz
Video Card(s) AMD RX 6900 XT (H2O Cooled)
Storage Samsung 860 EVO - 970 EVO - 870 QVO
Display(s) Samsung QN90A 50" 4K TV & LG 20" 1600x900
Case Lian Li O11-D
Audio Device(s) Presonus Studio 192
Power Supply Seasonic Prime Ultra Titanium 850W
Mouse Logitech MX Anywhere 2S
Keyboard Matias RGB Backlit Keyboard
Software Windows 10 & macOS (Hackintosh)
is that even the real MSI BIOS? (doesn't look to be so to me) or is that "hardware monitor" a software suite of monitoring sensors, much like "HWInfo" ? or....something else?
I've never been familiar with a MB BIOS that can read the sensor on your GPU! ie one of the sensors on the GPU die specifically. What the MB will likely measure/monitor is the PCIe slot temp that the GPU is plugged into. My opinion is that is not as as accurate as having the GPU fans controlled by the sensors on the GPU. It will work, but that is not where the heat is directly being made so the residual heat that makes it to the slot doesn't provide as accurate of a picture for the system to use to control your fans
246 (0.06/day)
Assam (India)
VR HMD None
No GPU as target source in my bios, only target temp., min and max fan speed. I think its not possible in my board. Could you think of any third party app. that could do it?
Hardware Monitor is a tab in my uefi bios, yes it is real msi bios. You can set system fan speed wrt temp. in it. It also displays voltages and other info.
How to make it work?
500 (0.28/day)
Case Lian Li O11-D
read up on your MB manual. I'm not familiar with MSI BIOS, literally have never seen anyone post a screen shot of the "hardware monitor" tab you have shown already. but the concept you are trying to do is universal regardless
you will need to
1) connect the fans that are physically attached to the GPU to an available fan header on your MB. Take note of what that fan header is labeled as
2) In the MB BIOS go to your fan control tab and select that specific header and select that it should be controlled via the specific PCIe slot the GPU is plugged into
For ex: You plug the GPU fans into the header labeled "CPU_OPT". Then go to your fan control tab, find the "CPU_OPT" header and where you can select which source is used to control the PWM signal. You should have selections like the CPU, VRMs, PHC, PCIe slots, etc. You would want the specific PCIe slot GPU is plugged into. Assuming you are using the top most slot of your board it will be called something like PCIE16_1 (for 16X PCIe slot #1)
KapeII
3 (0.00/day)
zkus odinstalovat ovladače grafiky (asi to není nutné) vždy se přeinstalují. Hlavní je mít všechny ventilátory nastavené automaticky v BIOSu. Vždy existuje možnost automatické konfigurace ventilátorů. Pomohlo mi to.
try to uninstall the graphics drivers (probably not necessary) they will always be reinstalled. The main thing is to have all fans set automatically in the BIOS. There is always the option to automatically configure the fans. It helped me.
IZ
v BIOSu také nevidím gpu.
i also don't see gpu in the BIOS. But BIOS set som setting for fans and software in win too.
try letting the BIOS set all the fans.
bad communication at BIOS and OS priority for me like a jerk
KapeII
3 (0.00/day)
I finally decided to clean up. I disassembled the gpu, blew the compressor, cleaned the old paste and applied a new one. And now everything is fine
