- May 8, 2018
- 1,568 (0.65/day)
- London, UK
I have set it up today and so far it looks pretty good. I have left at default first just to see the cpu-z result and how the bench was, result: single thread 500 and multithread 3820. At default, voltage, clock, nothing is fixed, all the time going up and down and clock usually stayed at 3950mhz on multithread or single thread. I then overclocked it to 4.2ghz, 1.32v and have redone the test and I'm amazed how better it was with the overclocking, also voltage and core clock very much fixed as you can see in the image below. This was my first try, set 42 core multiplier and 1.32v for the voltage. Maybe I hit the silicon lottery? 4.2ghz at 1.32v. So far this was amazing, my objective was to overclock to the precision boost maximum clock which for the 3600 is 4.2ghz and leave at the lowest voltage possible, 1.32v was my first try, I wonder how lower the voltage can go or how high can the clock go with 1.32v.
100% usage, 80c, so need a better cooler for this. It is always good to use stock cooler first to see how bad the thing really is.
CPU-Z Validation: https://valid.x86.fr/ish8yd
