Ryzen 3700x idle temps / Ryzen CPU boost always on ?
17,962 (2.44/day)
Pretty sure I've seen Cool'n'Quiet on my Biostar X370 board as well. I would guess that Asus renames it to something silly, likely under their "EPU" branding of anything and everything related to power delivery.
I don't have it or anything like it on my X570 Gigabyte board and never saw anything like it on my X370 Asus board.
Looks like it's part of Ryzen though...
7,762 (2.76/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
Given that there's pretty much zero enforcement of standards in BIOS feature naming, I'm not surprised. They probably felt the Cool'n'Quiet name was too old/generic/non-gamery and decided to rename the feature something like "RGB* Idle Efficiency Boost for GAMING!!!!1!1 (*not related to RGB functionality)".
431 (0.09/day)
System Name All the Cores ... (VMs)
Processor Ryzen9 5900x
Motherboard Gigabyte X570 Aorus Master (Bios F36c)
Cooling Noctua NH-D15S
Memory TridentZ neo 4x 16gb 3600Mhz C16 (F4-3600C16D-32GTZNC)
Video Card(s) RTX 3070 Ti
Storage 2x Sn750 2TB
Display(s) OPTIX MPG341CQR & LG 32UD60-B
Case CASELABS M8
Power Supply EVGA SuperNOVA g5 750w
Mouse Corsair m65 Pro
Keyboard Corsair K70
Software Windows 10pro/64
Benchmark Scores N/A .. yet updating soon
If you use Ryzen Master to monitor the cores they still clock down/sleep even with the high performance power profile. At least my 3600 still does.
Ok .. so today after reading this .. I ran Ryzen Master and switched threw all the power plans.
First thing that stuck out was Power Save & AMD power save ... Just eyeballing the numbers .. they were the only 2 that showed any change at all ...
(this here)
Windows Power Saver drops the CPU voltage to .931259 runs 2 - 3 cores @ 887 - 1240 mhz ( Lowest CPU voltae of all plan. )
AMD Power Saver .. UPs the CPU voltage to 1.4879 .... tends to only run 2 cores @ 1100 -1600mhz ( Highest CPU voltage of all plans.)
All Other plans ... seem to run around 1.474 Volts and run 4 cores
I was not happen with this ..
So I ran ea Power plan for 5mins letting my computer idle .. with only This web page open, Ryzen Master running and my normal background task. Made A spread sheet of the info..
Ea. Plan was let idle for 5mins .. and wrote down ea stat range from high - low for 1min
Again Powersave/ AMD power save really seem to be the only ones that change much ... ( AMD Balanced looks like the best over all choice tho)
But after doing all that ^ .. and looking back .. I know I was seeing 1.4879 volts when I first open Ryzen Master ... but its not showing up in that data as so
Looking at AMD power save with even more stuff open .. I am geting A 1.35volts and 33-34c temps.
AMD Power saves is trying to only use 2 core ...would say 95% of the time i just see 2 cores in use .. rarely A 3rd ... but I have seen CPU volage from 1.35 - 1.48
--- On A side note ... Ryzen master Peak speed MHz is matches nothing else ... Windows task manger or CPU z .... (CPUz shows my multiplier jumping from 34.4 to 43) ... that matches what windows is showing.
4,844 (1.51/day)
Processor Core i7-13700
Cooling Cooler Master RGB something
Memory Corsair DDR5-6000 small OC to 6200
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio
Power Supply EVGA 850 BQ
Software Windows 11 Professional v23H2
Using the AMD Balanced Power Plan Profile with all cores forced to 4,175 MHz
Cores down clock or entering sleep state
128945
Single core/thread load
128948
All cores/threads
128946
207 (0.10/day)
Processor 3700x @ 4.3
Motherboard Crosshair 7 hero
Cooling Kraken X62
Memory 16GB Trident-Z 3200
Video Card(s) EVGA RTX2080 XC Ultra
Storage Samsung 960 evo 500gb NVME
Display(s) ASUS ROG Swift PG348Q
Case NZXT H500
Audio Device(s) Phillips SHP 9500s.....Audio Technica AT 2035 microphone.....Scarlett 2i2 audio interface.
Power Supply EVGA 850W Supernova G2
Mouse Model O
Keyboard Corsair K65
I am pretty much convinced the 3700x is really 4.2Ghz CPU.
431 (0.09/day)
Case CASELABS M8
All cores/threads
You are right , not sure what windows / cpuz is reporting .
When idle ... a few cores will will show 200 - 1600 .. however .. windows and cpuz are show 3.6 - 4.3ghz ....
another funny thing is ... windows / cpu z report 4.3 alot .. master tops out a 4.2
