Ryzen 5800x and ram Corsair vengeance lpx 2x8Gb 3200 mhz
Dvrio
3 (0.00/day)
hi, so basically what happened is that when i put xmp profile 1 in the bios and set the mhz to 3200 , then the pc doesn't boot anymore, so i reset the cmos and then i can boot it cuz mhz are at 2133, also even if they are only 2133 my games keeps crashing to desktop with no errors. dunno what to do, i heard that these rams are a problem for ryzen. is there a way to fix it? or need to change them?
Components:
Ryzen 7 5800x
Rtx 3060
B450 gaming plus max
Corsair vengeance lpx 2x8 16gb CMK16GX4M2B3200C16
Corsair cv 550
freeagent
8,435 (3.76/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I would send that ram back and get something from G.Skill or anyone else. Vengeance is known to have many problems with Zen 3.
freeagent
8,435 (3.76/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Easiest thing to do is check your mobo qvl or use G.Skill qvl to see if it’s a match with your system :cool:
8,205 (3.93/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Yup. I've had to send back so much LPX that I'm never touching the stuff again. It's bad with Zen2, downright terrible with Zen3.
There are specific "Ryzen Tuned Vengeance LPX" kits that seem to be ok, but yours is not one of them.
The fact that Corsair even have to make a special "Ryzen" version of their LPX RAM tells you that they KNOW there's a problem with their normal LPX. Nobody else does that, nor do they need to!
I've had good success on Zen3 with Kingston Fury Beast, Crucial Ballistix, Patriot Viper Steel as decent budget dual-channel kits. If I'm trying to hit XMP speeds with 128GB (all 4 DIMMS) then G.Skill is my go-to but I've also had decent results with the Kingston Fury Renegade kits. G.Skill is usually much more expensive over here and the Kingston Renegade kits are at least 25% more than their Beast kits.
41,913 (6.61/day)
The crucial ballistix gaming 3600 works with a ry7 5800, asrock b550 steel legend fine
8,205 (3.93/day)
Case Veddha T2
Mouse MX Anywhere 2
6,029 (2.89/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
947 (0.63/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 10 Enterprise 21H2 LTSC
just mobo qvl. you can find other ram manufacturers too lol
At €99 they're overpriced. They should be going for around €70 which is the price you'd pay if you got 2x16GB kit.
they are hyped out as they are good for oc. mine samsung bdies were twice the price, i paid for what i wanted lol.
1,617 (1.76/day)
G-City, UK
System Name AMDWeapon
Processor Ryzen 7 7800X3D
Video Card(s) Powercolor 7900 GRE Red Devil
Case Montech 903 MAX AIR
Audio Device(s) Corsair void wireless/Sennheiser EPOS 670
Mouse Glorious Model D l Pad GameSir G7 SE
Keyboard Redragon Vara K551P
Software Windows 11 Pro 24H2
Benchmark Scores Fast Enough.
Please tell me you are taking the piss? Even my Micron 16GBx2?
dgianstefani
TPU Proofreader
4,998 (1.99/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Benchmark Scores Legendary
314 (0.23/day)
System Name Back in Black
Processor Ryzen 5 3600
Motherboard MSI B450 Tomahawk
Cooling ID-Cooling SE-224-XT Black
Memory Corsair Vengeance LPX 16GB (2x8) 3000mhz C15
Video Card(s) Asus Rog Strix GTX 1070 TI Advanced Edition
Storage Crucial MX500 500GB / Solidigm P41 Plus 1TB
Display(s) Samsung 32" TV 1080p
Case Montech Air X Black
Power Supply Thermaltake Toughpower GF1 750W Gold
Mouse Redragon M711 Cobra
Keyboard Corsair K55
If it works for you and you have no issues, keep it. I got LPX and haven't had problems directly related to them, but based on what I've read here and in other forums, I'd stay clear from them in the future for Ryzen builds.
1,617 (1.76/day)
G-City, UK
My next Ryzen build will be a 7000 I think. Will keep all that I've currently got probably until DDR5 has come down loads.
3,245 (1.68/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Components:
Ryzen 7 5800x
Rtx 3060
Corsair cv 550
Some kits need a little more loose tRC if I recall.
I had a CMW32GX4M2C3200C16 (ver 4.32) kit needed a bump in tRC to get it working.
Try setting XMP then loosen tRC by +4 or +6 and see if it will post.
Crashing at 2133 sounds like a bad stick which happened to me.
