Ryzen 9 3900x Voltage and Temperature
117 (0.03/day)
System Name Snizzle
Processor AMD Ryzen 9 3900X
Motherboard ROG STRIX X470-F GAMING
Cooling CORSAIR Hydro Series™ H100i PRO RGB
Memory CORSAIR VENGEANCE® RGB PRO 16GB (2 x 8GB) DDR4 DRAM 3200MHz C14 Memory Kit
Video Card(s) EVGA GeForce RTX 2080 Ti XC ULTRA GAMING, 11G-P4-2383-KR
Storage SAMSUNG 970 EVO M.2 2280 500GB
Display(s) ASUS ROG Swift PG279Q
Case NZXT H500
Power Supply EVGA SuperNOVA 850 G2 220-G2-0850-XR 850W
Mouse SteelSeries Sensei
Keyboard Ducky DK2108S
Doing some benchmark with Cinebench R20 . I notice something funny is when the computer is idle the voltage at 1.45-1.46 V and temp is around 45-55 Cel.
When i started doing the benchmark, the Voltage drop to 1.3- 1.4 v. The CPU core is at 4.0 ghz on all cores.
28,464 (6.77/day)
View attachment 126651View attachment 126652
That voltage is WAY too high! For first gen Ryzen 1.35 to 1.4 was common, but these new gen Ryzen CPU's should only be at 1.2 or 1.25.
See this and start at 3:32;
Jay will walk you through what to set and why.
Low quality post by HenrySomeone
117 (0.03/day)
System Name Snizzle
Case NZXT H500
So, what I did was. I offset my cpu by - .1 in the bios. Now it showing 1.35 - 1.39 v
After rerun the benchmark. It showing better result.
28,464 (6.77/day)
Ah, yes, the delights of AMD ownership...
Actually, the problems here are not the fault of AMD, it's the board maker not setting the voltages in the BIOS correctly based on the CPU microcode
Are your temps better as well? I'd still set the voltage lower, say -0.2, if you're not OCing.
17,463 (4.67/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
Jay is great. Always enjoyed his videos, don't watch anyone too much these days, except Linus once in awhile because he is goofy as crap sometimes. lol
117 (0.03/day)
System Name Snizzle
Case NZXT H500
Yes temp drop down to 38-45 Cel. I think i stay at this offset at -0.1 for now and let see on gaming. Voltage will drop down 0.850v when idle and when is use is at 1.345 V, No i don't think i will OCing because of the state we in right now. lots of problem with the motherboard bios.
17,463 (4.67/day)
Honestly Asus has always done this. Even on my Asus Z68 Deluxe or w.e it was called, whenever I flipped the switch to auto OC it on the mobo, called TPU and EPU, it would skyrocket high voltage and only give me 4.3ghz oc on sandy bridge 2500k... everyone always just manually oc'd a 4.5 clock at like much lower voltage than that.
Asus is just overrated as a company as far as I am concerned.
7,267 (3.14/day)
California
System Name His & Hers
Storage lots of SSD.
Similar issues on my Z390 Asus Maximus Code... Regardless of bios version the stock voltages for vccio and SA are way too high.
757 (0.35/day)
All vendors seem to do it. I asked MSI (on the X99 platform) why this was... and their best response was: "it provides guaranteed stability."
Yeah... 1.35 VCCIO on a CPU that only needs 1.05v to function is not what I would deem safe, nor stable. Not to mention that anything over 1.3v on air/water was actually considered a damaging prospect too.
1,577 (0.65/day)
London, UK
That is something that i dont like, if cooling is at 70c, why 4.0ghz? supposed to be all at 4.6ghz, i wonder when the cpu starts throttling, 60c? does anybody know?
What the hell this is supposed to work all with 4.6ghz? 30c and vcore 1.2? well as cold as it gets vcore can be dropped little by little and maintains maximum clock speed allowed 4.6 on 3900x, or same can be said about as hot as it gets vcore and clock speed lowers to maintain temperature that is good to make that vcore stable.
Here at the techpowerup boos analysis, wizzard forgot to show the current temperature graph scale too. I wonder if temperature less than said 50c will still leave it at 4.2ghz maximum on all cores. LN2 bench can confirm my theory or a very good watercooling.
821 (0.24/day)
System Name Harm's Rig's
Processor 5950X /2700x / AMD 8370e 4500
Motherboard ASUS DARK HERO / ASRock B550 Phantom Gaming 4
Cooling Arctic Liquid Freezer III 420 Push/Pull -6 Noctua NF-A14 i and 6 Noctua NF-A14 i Meshify 2 XL
Memory CORSAIR Vengeance RGB RT 32GB (4x16GB) DDR4 4266cl16 - Patriot Viper Steel DDR4 16GB (4x 8GB)
Video Card(s) ZOTAC AMP EXTREME AIRO 4090 / 1080 Ti /290X CFX
Storage SAMSUNG 980 PRO SSD 1TB/ WD DARK 770 2TB , Sabrent NVMe 512GB / 1 SSD 250GB / 1 HHD 3 TB
Display(s) Thermal Grizzly WireView / TCL 646 55 TV / 50 Xfinity Hisense A6 XUMO TV
Case Meshify 2 XL- TT 37 VIEW 200MM'S-ARTIC P14MAX
Audio Device(s) Sharp Aquos
Power Supply NZXT C1500 Platinum ATX 3.1 | Fully FSP Hydro PTM PRO 1200W ATX 3.0 PCI-E GEN-5 80 Plus Platinum -
Mouse G502
Keyboard G413
Waiting till Christmas , lots BIOS updates till then.
learn the hard way with GD80 990FXA,BIOS updates every month for 8 months back in 2011.
1,577 (0.65/day)
London, UK
Can you disable smt and see if you can overclock it better, also can you see power consumption with smt off, 100% load? I just don't understand why no reviewers have done this test.
2,141 (0.52/day)
Serbia
Processor Ryzen 5600
Motherboard X570 I Aorus Pro
Cooling Deepcool AG400
Display(s) 24G2U
Case NR200P
Power Supply Ion SFX 650
Mouse G703 (TTC Gold 60M)
Software W10
You wont get much from overclocking anyway, don't bother. PBO and XFR do a good job. In some cases (like lightly threaded games) you might even lose performance versus stock.
87 (0.04/day)
System Name Shiny Beast 2.0
Processor AMD Ryzen 9 5950x
Cooling Corsair H150i Elite Capillex
Memory 32GB G.Skill Trident Z RGB 3600Mhz CL17
Video Card(s) Asus Strix RTX 3090 OC
Storage Samsung 980 Pro 1TB, Samsung 970 Evo 1TB, Samsung 860 Evo 1TB, Crucial MX500 2TB, WD Black 2TB
Display(s) Asus PG35VQ 3440x1440 200Hz GSync
Case Corsair 500D SE RGB
Audio Device(s) Logitech Z906
Power Supply Corsair HX1000 Platinum
Mouse SteelSeries Rival 600
Keyboard Logitech K750
My Asus Maximus XI Hero used 1.45v VCCIO and 1.4v VCCSA on 3600Mhz XMP and almost 1.38v on the CPU for 4.7Ghz allcore turbo:kookoo:
Manually I got down to 1.365v VCCIO and 1.34v VCCSA with 4000Mhz RAM and 1.3v for 5Ghz on the CPU.
the54thvoid
Super Intoxicated Moderator
13,157 (2.39/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
I can't get it now (on mobile) but I saw a Reddit thread from an AMD rep, could even have been a guy called Rob. But... Monitoring software isn't reporting idle voltage. Effectively, the software wakes the core, which responds to the call as an intense load. Therefore, the idle voltage is actually a load voltage, instigated by the monitoring. Ultimately, it's like quantum. The act of observing the chip, changes it's state from cc6.
Only one single software or bios monitoring tool should be active. I think he said either CPUz was okay or Ryzen master. But only one. Mobo monitoring tools will mess either up.
91 (0.02/day)
System Name RyZEN
Processor AMD Ryzen 7800X3D
Motherboard Gigabyte B650E AORUS ELITE X AX ICE
Cooling Noctua NH-D15 SE-AM4
Memory 2 x 16GB G.Skill Flare X5 DDR5 6000MHz CL30
Video Card(s) MSI GeForce RTX 3080 Ti Suprim X
Storage 2 x Samsung 970Evo+ (500GB + 2TB) & SATA 850 Pro 1TB
Display(s) ASUS PG279Q IPS G-Sync 165Hz
Case Phanteks P600S White + 3 x Noctua NF-A14 Chromax
Audio Device(s) Edifier r1280t & HiFiMan HE400se @ FiiO New K3
Power Supply Seasonic FOCUS Plus 1000W Gold
Mouse Logitech G Pro Wireless
Keyboard Logitech G413 Silver
VR HMD Quest 2
Benchmark Scores https://www.3dmark.com/spy/25161355
https://www.reddit.com/r/Amd/comments/cbls9g
1,010 (0.22/day)
Belgrade, Serbia
Memory CMD16GX4M4A2666C15
Display(s) Samsung P2450H
Case Lian Li PC-O11 WXC
Mouse Logitech G900 / SS QCK
Keyboard Deck 87 Francium Pro
Finally day when gamers could buy killer PC for 2000$.
3900X, 1TB Gen 4 M.2-Radeon 5700XT CH4H Motherboard and 16GB RAM.
2,719 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
Some BIOS and driver tuning is still needed to allow all CPUs to perform as intended for the boost frequencies.
the54thvoid
13,157 (2.39/day)
Software W10
Now a TPU news post.
117 (0.03/day)
System Name Snizzle
Case NZXT H500
I undestand the observer effect on TPU article, but why is it the Temp is so high. I mean if it in idle the Temp should be around 35-45 Cel. When it idle it sitting around 45-55 cel.
I am only running one instance monitor tool. Not opening up 2-3 tools to monitor.
Edit:
ALso, when i use or turn on Icue software from Corsair. The voltage will be at contanst 1.35- 1.37V when idol . When i turn it off the idol will drop down to .885v.
mngew
1 (0.00/day)
My 3900X also idles at those temperatures. I have mine cooled by H115i. I reseated the heatsink 3 times. Didn't make any changes. I'm going to try NH-D15 later tonight.
28,464 (6.77/day)
Like him, check your voltages in the BIOS. If they're above 1.25, set them to 1.25.
Prillan
1 (0.00/day)
Old post but i found that with gaming mode turned on in dragon center will push the cpu all the time hence the extreme idle temps, went from 45-50c to about 35-40 when i turned it off, maybe different utility programs are messing with eachother
