Ryzen 9 3900x Voltage and Temperature
738 (0.43/day)
Processor Intel i7 13900K
Motherboard Asus ROG Strix Z690-E Gaming
Cooling Arctic Freezer II 360
Memory 32 Gb Kingston Fury Renegade 6400 C32
Video Card(s) PNY RTX 4080 XLR8 OC
Storage 1 TB Samsung 970 EVO + 1 TB Samsung 970 EVO Plus + 2 TB Samsung 870
Display(s) Asus TUF Gaming VG27AQL1A + Samsung C24RG50
Case Corsair 5000D Airflow
Power Supply EVGA G6 850W
Mouse Razer Basilisk
Keyboard Razer Huntsman Elite
Benchmark Scores 3dMark TimeSpy - 26698 Cinebench R23 2258/40751
The stock turbo speeds should not be affected.
Are you sure ?
I should do some tests...
Right now I found a good compromise (considering a Tamb of about 28°C) using PBO in Auto setting and an offset of -0.125 V
Core voltage is in the 1.1 / 1.2 V range while browsing and under load it doesnt go above 1.4 V (staying around 1.3 most of the time).
Temperatures are at least 5° C lower than in stock settings.
25 (0.02/day)
System Name AMD Ryzen
Processor AMD Ryzen 9 3950X
Motherboard ASUS TUF GAMING X570-PLUS (Wi-Fi) AM4 ATX
Cooling Noctua NH-U12A
Memory Corsair Vengeance LPX 64GB (2x32GB) DDR4 3200MHz
Video Card(s) Nvidia GTX 1080Ti (Asus)
Storage Sabrent 2TB Rocket Nvme PCIe 4.0 + 4.0Tb samsung 970 SSD
Display(s) Dell U4320Q UltraSharp 43-Inch 4K
Case Phanteks Eclipse P400A (mesh front) white
Power Supply SeaSonic 1200 Platinum
Mouse Logitech MX Master
Keyboard DasKeyboard
Benchmark Scores CB20 all cores 9920
My pbo boost speed is 4.725Ghz on one best core at stock voltage (auto) and 4.7 second best core. If I do -0.2 I think the turbo speed goes to something like 4.65Ghz. CPU is 3950x which has 4.7Ghz advertised boost speed. So voltage does affect turbo speed.
738 (0.43/day)
I was afraid of that.
BTW which voltage do you have at stock settings ? because the reason I undervolted is the insanely high 1.440 V my Asus board is giving at default.
I know that AMD said that boost up to 1.5V are normal, but... :confused:
Ok now I am officially confused :confused:
i just did a test with -0.150 V and my 3900X seems to boost HIGHER than previously :kookoo:
During Cinebench R20 the boost speed was 4/4.1 GHz now it is a solid 4.2/4.3 GHz, which is fine for an all thread load I think. The results is slightly better (100 points).
I tried also CPU Z to stress 1 Thread and the boost was 4.5/4.6 GHz, which is the rated for my CPU .
So basically the undervolt is doing good to my system.
Why are Asus using those insane 1.440 V for Vcore ???? :kookoo::kookoo::kookoo:
25 (0.02/day)
You got luck with your chip I guess. I am running with offset -0.075v and the best one core boost is 4.575Ghz. If I do full auto than it's 4.725
Undervolting does not do good for my chip. But it helps with temps so I am OK with that. NB I have 16 cores so it's harder for my chip to get cooloer ( I have 85C under load ) and 41 idle (room temp 25C)
For the high voltage - you can ignore it. MB will limit it under load to safe values and high voltage helps with boost clock, I see it under 1.25v under CB20
Update: just retested and confirm auto voltage gives me best performance: all core freq: 4.125 in CB20 with two best cores boosting at 4.75 and 4.725
7,315 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
Lol my MSI B450 Gaming Pro Carbon AC had 1.45V as default for my Ryzen 9 3900X I think MSI needs to look at this even loading default didn't get this down.
At Auto the CPU was getting about 1.45V in bios so I lowered the voltage to 1.30V (CPU-Z 1.92.0 x64 shows 1.304V) and just booting up the temps went down with 10C.
At the moment my AIO is running 2xFractal Design Dynamic X2 GP-12 that came with the cooler but i manually set 75% speed at all times even in gaming and the noise ain't bad.
25 (0.02/day)
Can you try to set PBO Max settings and report temps and freqs and voltages?
I can get my CPU much cooler without PBO and much lower voltages, but at the performance loose about 10%. FYI my CB20 score ~9400
738 (0.43/day)
And what about boost clocks with lowered voltage ?
because someone is suggesting a lower boost while I’m experiencing the opposite.
it is quite confusing.
25 (0.02/day)
There are 2 reasons for lower boost with high voltage
1) CPU power limit (most likely, if you did not do override default settings in BIOS)
2) Temperature throttling (less likely if you have good cooling)
tabascosauz
8,200 (2.35/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Within -0 to -0.075V, you may experience an increase in boost performance (on boards with aggressive default voltage settings) or no performance loss.
Going beyond -0.075V, you will begin to lose clocks and scores. The good thing about Ryzen is that when the firmware works properly, it will continue to scale downwards almost indefinitely in clocks/temps as you remove voltage.
Generally, you will not scale past -0.075V without losing performance. Raising LLC at that point may mitigate it to a certain point, but high LLC and Ryzen boost don't mix. Whether that loss of performance shows up in the specific benchmarks you use is another question entirely.
For me, I can run at 100% default clocks and scores with a -0.075V undervolt, but only with Turbo LLC to compensate. -0.05V if I use High LLC. Even at that point, single core boost already takes a hit in benchmarks (though <5% difference). All-core is unaffected until I go to nearly -0.1V.
AsRock
TPU addict
19,126 (2.98/day)
UK\USA
With CB i found that doing a all core is the best way to go by a good 400 points at least. On top of that all core at 4.2 1.27v is much cooler than leaving it boosting a few cores hitting no more than 79c with a ambiant of 34c.
25 (0.02/day)
Mine boosts at 4.15 all cores in CB yet boosting 4.75 in one thread.... But yes, it runs hot!
3,984 (1.11/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
Since I’m not an expert of AMD CPUs (my last was an Athlon 64) I wasn’t sure about the value.
After seeing the video I set an offset of -0.125 V and idle temperature is 41° !!!
Much better.
During Cinebench R20 previously I was reaching 1.48 V and 85°, with a good cooler like a Dark Rock 4, now it tops at 1.37 V and 76°.
Maybe I could try even a bigger offset...
Check your CB scores, you start losing score very fast when undervolting. There is pretty much 0 chance you are not losing performance when undervolting over .100v.
Most will lose performance when lowering voltage. When using PBO, I got the most performance benefit by limiting EDT and lowering voltage via vdroop by changing LLC.
I plan on doing more testing but you know, life happens.
738 (0.43/day)
In my case CB 20 results are better with -0.1 V than at default.
The difference is not huge (around 100 points) but it is consistent.
I’m using -0.1 V offset and LCC Level 4 (there are 5 levels on Asus’s motherboards).
How you check you single thread performance and Turbo boost ? CB20 single ?
And the most important question: what was you Vcore at default setting ? because I have 1.440 V at default, and that seems strange to me.
Maybe your is lower, so you need less undervolt
well my cpu beg to differ :wtf:
I’ve done extensive testing in CB20 and my CPU are obtaining better results with -0.125/0.100 than at default.
The difference is about 100 points
this point is not clear to me...:confused:
“Lowering voltage” changing LCC ? As far as I know using high LCC you are avoiding a Vcore drop... Are you using a low LCC setting on purpose ?
Do you care to explain better, please ?
BTW the most important question also for you: what is your default BIOS Vcore at stock ? :)
Because the main point is my Asus board setting a 1.440 V as default, which is the reason while I was trying to undervolt since the beginning. Maybe your motherboard si using a more reasonable 1.35-1.38 V and in that case your CPU doesn’t need undervolt at all.
Thank you
tabascosauz
8,200 (2.35/day)
Western Canada
System Name ab┃ob
The BIOS Auto "Vcore" numbers literally means nothing. On the default "Auto" setting, the chip itself has complete control over how it boosts, how much it boosts, how it will respond to temperatures, how much voltage it needs at any point and how much voltage it will draw at any point. Seeing "1.440V" in the little black box to the left of the Auto field for Vcore is about as useful as telling us that your computer is powered on.
Open up Prime95 and run Small FFTs with AVX disabled, and keep HWInfo open to see what Vcore is during the test under the CPU Core Voltage SVI2 TFN setting. Or you can do the same while Cinebench is running. The Min and Max values when you're just sitting on desktop are completely useless.
I know for a fact that the B550 firmwares for Asus prior to BIOS 0608 were wack as fuck. You should be on 0608, 0805/0803 or later, even newer BIOS just released a couple days ago.
You see Vcore jump up into the 1.4-1.5V range at low loads/idle because that's what Ryzen calls for to sustain high single core clock speeds so as to meet the speeds on the box, and for AMD to avoid a class action lawsuit. When you offset -0.1V to Vcore and bring the perceived idle Vcore down to 1.3V, it will not be able to sustain high single core boosts, even if you perceive the system as being x degrees cooler. Depending on your settings, multi core may be fully unaffected, but the single core loss due to Vcore offset is plain to see in any single threaded test.
For single thread, run CPU-Z if you don't have time, and CB R20 single core if you do have time.
738 (0.43/day)
first thing first: thank you for your reply.
i understand your point about reported Vcore but ... that’s still the applied Vcore in the bios, and I can’t understand why such an high value.
and it has REAL impact on “idle” temperature in Windows : with default settings is about 49° (is quite hot here now) but When undervolting it is about 42°.
not a big deal, but just to let you know.
I‘m using the latest BIOS released a few days ago.
now I will focus on single core benchmarks to let you know but yesterday i did A LOT of CB20 tests and I can say for sure than I obtained slightly better results with a 0.1 V undervolt (7200 vs 7100). Consistently.
7,315 (1.03/day)
My all core is around 4-4.1GHz but I can see I might need to do some tweaks but I am not that familiar with AMD/MSI's OC menu so I have to read and watch some videos if there are some avaliable for this board.
738 (0.43/day)
4.1 GHz all cores (with ambient temperature of about 30°C) is what I’m getting in CB20.
15 (0.01/day)
scandinavia
Processor AMD Ryzen 5 3600
Motherboard MSI B450 Mortar Max
Cooling NH-D15
Memory Crucial Ballistix 3200 (3800 CL16)
Video Card(s) Powercolor rx6800xt Red Dragon
Storage Adata sx8200 Pro
Display(s) Benq EW3270U
Case Jonsbo RM4
Power Supply Corsair SF750
There is nothing to worry about Vcore 1,44V during bios. It could be even higher. In normal use (if not overclocked manual voltage) Zen2 adjust its voltages rapidly so it is not constantly so high. Constant vaues 1.35V might be actually problematic due silicon aging. Idle temps 49C is also not alarming so no worries either. Of course lower voltage and temperatures are better and I also use currently -offset 0,075V which drops temps, voltage and current consumption. I dont see perf drop until the offset is more than -0.100 but I like to have some margins with this. Zen2 with small 7nm process do cause higher temp peaks than generally used to, but it is still fine as default. I just want to see a bit lower values so small negative offset is applied. Just note that too high negative offset drop performance and occasionally also cause instability depending on chip&CPU combo. This performance drop is described as clock stretching (some overclocker has made clarifications about this behaviour). When CPU detects too low voltages it will delay clock periods and effective CPU speed drops even it is not read correctly in monitoring. User will see just lower perf in tests like CB20 .
7,315 (1.03/day)
Normal voltage is 1.300V so 1.440V is too high for idle even my MSI board got that wrong and a lot of Asus even Maximus boards get this wrong.
@Leonoid007 I do not like AMD's PBO as a lot of other people complains about it's not really good optimized.
@Max(IT) the frequency kept jumping too much and even down to an all-core of 3.8GHz when everything was on auto and now I put in the Offset that it should have 1.300V with an offset of like +0.125V and I do all-core 3.99GHz (40x in Bios) in CB20 with no issues.
tabascosauz
8,200 (2.35/day)
Western Canada
System Name ab┃ob
It's been 13 months since Matisse released. That being so, I'd expect you to know that up to 1.5V at low loads is perfectly normal to see in HWInfo. Only Ryzen Master sees true idle voltage, and up to 1.5V is allowed at lower current (and often necessary for shittier chips) for single core boosting to the advertised Max Boost Speed. At this point, we're beating a dead horse that should have stayed dead a long time ago.
If you apply a negative offset that begins to reduce light load Vcore below what your chip needs for single threaded boost, you will start to see a loss of single thread performance. Whether that's worth it, is up to you. I'm not sure what it takes for @Max(IT) to listen to what other people have said and realize that this:
...means Auto. It does not mean 1.144V, 1.5V, a green unicorn, or whatever the hell happens to be displayed in that box to the left. It means Auto. The BIOS suffers from the same monitoring-software-syndrome that plagues every software that isn't Ryzen Master. It simply takes an instantaneous reading of Vcore when it starts, and that's what you see. Much more often than not, that "value" is over 1.4V. But in this case, the reviewer on the X570-TUF happened to see 1.144V. No Matisse chip is sustaining its advertised Max Boost single thread with 1.144 goddamn volts. Neither is a Matisse chip going to sustain all-core at 1.440V out of the box, because that's suicidal for silicon life.
When you set a Vcore offset , you are still affecting the Vcore at all times by that set amount regardless of what Vcore might be displaying at any given moment or load. Unless you listen for once, open up HWInfo and watch your SVI2 TFN Vcore while you are running CB R20, this is going nowhere and no one will be any wiser as to what's actually going on with your stock settings and your -0.1V offset.
7,315 (1.03/day)
@tabascosauz my SVI2 TFN for SoC is 1.086V current and max is 1.106V in HWInfo64.
Higher then 1.300V I see about 99C under load in CB20 but as for now themps are more controlled at 4.1GHz all-core I see 83C max and Ryzen Master shows 1.3V max.
Where did you see the VDDCK CPU Voltage in Ryzen Master I cannot see that in version 2.3.0.1591 using Advanced View maybe I am just blind.
tabascosauz
8,200 (2.35/day)
Western Canada
System Name ab┃ob
Vcore is Vcore. VSOC is VSOC. Both are reported accurately over SVI2 TFN, and will show up in HWInfo. If you run 1.3V through your SOC you can kiss your I/O die goodbye.
If you don't even have an Asus board, isn't it kinda a given that you won't be finding VDDCR CPU Voltage? It's just the setting for Vcore.
Anyways, all that needs to be said has been said a number of times. Up to OP to decide whether he wants to figure things out or continue down this road of "Vcore is set to 1.440V". Which wouldn't be all that surprising if this was an early B550 BIOS we're talking about, as I've mentioned, but OP still hasn't provided info as to what BIOS he's on, so I'm out.
7,315 (1.03/day)
@tabascosauz I been thinking about getting a B550 board but I rather wait for AMD's Big Navi/RDNA2 price and buy a better graphics then my Sapphire PULSE RX 5700 XT and a Oculus Rift S for Medal of Honor Above and Beyond.
Thank, but I am not going over 1.1V max but what is the default SoC voltage ain't that like V1.000? Because at the moment it's set to AUTO in the bios and with all-core at 4.1GHz at 1.3V Core the SoC voltage maxes out at 1.106V this is what HWInfo64 shows me doing AiDA64 stress test.
738 (0.43/day)
yep, I'n not really "worried". I'm just under the impression the system isn't working the best way.
Using default settings Vcore values are quite often above the 1.35 V.
Is it dangerous ? I don't think so. But I can't see the point, since performance are affected.
I found that an offset of -0.100 V is the sweet spot for me. Maybe with colder temperatures I will try again to see if situation changes.
Excuse me, you put a POSITIVE offset in ? :confused: :confused:
You worte + 0.125V ...
Is that a typo ?
Dude, I can be no expert in Matisse yet, but I'm an IT engineers since 1993 so I surely know how to do tests.
I didn't read that value, but the value reported also in HWInfo64, and during CB20 I saw the SVI2 TFN went up to 1.5 V.
You should learn how to speak with others without being offensive.
I checked SVI2 TFN under load and with an offset is 1.30 V all cores and 1.35 V single core. Without the offset it goes above 1.4 V (thus the higher temperature).
Now I did an extensive testing and I can report what I discovered.
I tried 3 configurations:
A) stock AUTO voltage
B) offset -0.150 V
C) offset -0.100 V (my "daily driver" )
Cinebech results aren't really affected much by the 3 settings, BUT temperatures are.
In option A I had these results:
which is ok but idle temperature is around 49° and under load I reached 85° C.
Options B and C were quite similar in term of results, so I will just report C screenshot:
as you can see, basically NOTHING changed, BUT (a BIG BUT no pun intended :D ) temperature at idle is about 43° and under load I had a spike at 79° but for most of the time it was around 70° C.
A huge difference.
As far as clock speeds well, the results where almost identical: in single core I had 4,541.8 MHz most of the time (with a spike at 4,616.7 MHz) and in multicore it stays around 4.1 GHz.
Now, I need advice (but not lecturing, please), but these are my results. And to be clear, I did AT LEAST 5 TESTS for each configuration, so be sure to report coherent results.
What do you think ?
7,315 (1.03/day)
Is that a typo ?
No typo :roll:
The offset got 3 settings
AUTO
But yeah cloud change it shouldn't hurt :roll:
