I guess if you're 100% sure the CPU works fine with SAM in another board you could buy a replacement, RMA the Asus B550 Plus and then sell the new, unopened replacement on ebay or something.
The boards you mentioned are all fine, I've used them all. I've also built dozens of AM4 systems using the Aorus Elite and it's solid. I run an Aorus X570S with my 5800X3D that's about to be retired, it's given me zero problems over the years and I've had several SSDs, GPUs, CPUs, and RAM in it.
Also valid. Might just be a quirk of this particular CPU - the diagnosis steps aren't getting done so not a bad option without any further information.
I forgot to mention(my bad) SAM is not the problem.Even with disabled SAM this problem exist. However I like my current motherboard, it looks and feels premium and I have all the features I want. Wifi and x2 gen 2 argb headers 5v. I ordered Rog Strix B550-A Gaming(the white edition) now - it's only 300BGN which is around 145 dollars.The person who sold me this CPU said that he run this cpu with Rog Strix B550-F gaming in order to test it before sell it and showed me video with SAM working and 2 nvme in the M2 slots.Also offered me to swap my cpu for his cpu(which is the same , he got couple of them)+motherboard(B550-F Gamin ROG strix). Which makes me think that he knows what he is selling and its everything tested) and it's not actually the CPU but my motherboard. Some strange problems started occuring after installing this 5800x3d. 1.5month after I bought it in April 2024th I was running my RAM on D.C.O.P mode which is OC mode right ? I used it like that for about month and a half since purchase and then one day suddenly my PC crashed.I had to remove sticks and try to run it in safe mode in order to boot again,after trying to enable DCOP it crashed again. So now I run my RAM on Manual OC which is set to 3600mhz instead of DCOP.That was the first strange thing that happened to me and now this.. It only makes me thing that my mobo is a lemon. But why would it run okay with 5600x except the RAM OC ?
If it's just a quirk of the CPU it's much easier for me to return the new mobo I just ordered (I have 14 days return policy) and just buy 2TB NVME drive for the working M1 slot so I can compensate for my M2_2 drive. I can do it right now but I feel itchy that something is not working in my system
![Frown :( :(](https://tpucdn.com/forums/data/assets/smilies/frown-v1.gif)
A decent 2TB nvme drive cost the same as a new motherboard AM4 B550 chipset
For me - everything points out to the motherboard.I can't even do a bios flashback with it. Tried with dissasembling the whole pc , do a bios flashback with only CPU power and ATX power cables - the green light goes 3 times and then starts constantly in green. It should keep pulsates but it just turn green.And yes I did the renaming process for older bios, I also tried via EZ flash utility in BIOS too and it says ''not propper bios file'' ... Wheter it is BIOS or some strange incompatibility it is worth to change the motherboard and try again. If this error occurs with the new mobo then everything will be clear as a day - bad CPU
The reason why I choose ROG strix B550 A-gaming is because I found no threads about dead 5800x3d CPU with it.
I tried first searching for ASRock B550 Steel legend frying x2 5800x3d chips on a same person - skipped
Then I looked out for MSI B550 Tomahawk MAX Wifi - again another thread and compatibility issues.
This B550A-gaming is the same as F-gaming (only the colour) and for sure this particular CPU I have was working with that mobo according to the seller and according to the video he showed me.
https://www.guru3d.com/review/amd-ryzen-7-5800x3d-review/page-3/ considering this page information , does it have to do at all with my CPU and Motherboard ?!?!
I am more focusing on ''Of course, if one PCIe Gen 4 NVMe SSD is plenty enough for you, we'd advise B550. And if you are fine with PCIe Gen 3.0, honestly after January 2021 look for a nice B450 or X470 motherboard. The processor and memory performance will not be any different on all platforms. There's a lot of value to be gained by making clever choices here.''
Does that mean I will have to work with only 1 NVME ? And if this is the case then OKAY - I Am good with it as soon as there is not something wrong with my hardware parts I will just switch to bigger NVME storage device rather buying another motherboard lol...
Nevermind: I miscomprehended things maybe
