Samsung 980 Pro or 990 Pro
SaVag3
2 (0.00/day)
If i'm just gaming is it even worth it to spend more for the 990 Pro?
18,584 (2.66/day)
System Name AlderLake
For game storage a 980 pro will do fine.
Since May 2022 I use one for the OS and some games installed.
634 (0.39/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
980 pro is more than enough. I recently ordered my new build with 980 pro 2 tb, even 970 pro would be fine (was not available anymore from the store I ordered the parts). 990 pro is probably slightly better, but we won't be able to notice the difference.
173 (0.28/day)
Holy Roman Empire
System Name Shadowchaser /// Shadowchaser Jr.
Processor AMD Ryzen 7 7700 /// AMD Ryzen 9 5900X
Motherboard Asus ROG Strix X670E-E Gaming /// Asus ROG Strix B550-E Gaming
Cooling Noctua NH-D15S chromax.black /// Thermalright Venomous X
Memory Kingston Fury Beast RGB 6000C30 2x16GB /// G.Skill Trident Z RGB 3200C14 4x8GB
Video Card(s) Zotac GeForce RTX 4080 Trinity 16GB /// Gigabyte G1 GTX 980Ti
Storage Kingston KC3000 2TB + Samsung 970EVO 2TB + 2x WD Red 4TB /// Samsung 970EVO 1TB + WD Red 4TB
Display(s) Gigabyte M27Q /// Dell U2715H
Case Fractal Define 7 Black /// Fractal Define R5 Black
Power Supply Seasonic SS-750KM3 /// Seasonic SS-660KM
Mouse Logitech MX Master 2S /// Logitech MX Master
Software Linux Debian 12 x64 + MS Windows 10 Pro x64
Cannot be wrong with 980Pro, but if Samsung is not a must - Kingston KC3000 2TB is a very very good SSD comparing to 980Pro and cheaper.
6,054 (0.83/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Thank you, I'm gonna get the 2tb one, it should be a huge upgrade from my 970 evo plus 500 GB
Why do you expect that? Most SSDs are equally as fast in desktop use, the increased sequential read/write speeds of the "high-end" models really only makes a difference when copying large files.
18,584 (2.66/day)
ErLucaGiurato
5 (0.01/day)
It's true for gaming scenario. My 990 pro allow me insane response time and instant browser and play samples in my 500gb library of audio plug in and audio sample for ableton live (90% of them are really tiny files). Much better experience than my sabrent. It's also faster in loading autocad and doing other things.
This is a benchmark, sure, but the difference when you start doing something else other than browing or playing can be big.
684 (0.11/day)
Auburn Hills, MI
Processor Intel i9-13900KF
Motherboard ASUS Z790M-Plus
Memory 64 GB DDR5 @ 6000 G. Skill Trident Z
Video Card(s) ASUS TUF Gaming RTX 4090
Storage 2 TB SN850X + 2x 4 TB Lexar NM790
Display(s) 32" 4K/240 Hz W-OLED w/ 1080P/480Hz Mode + 39" 3440x1440 240 Hz W-OLED
Case Lian Li O11 Mini
Audio Device(s) Kali LP-UNF + Audeze Maxwell
Power Supply Corsair RM1000x
Mouse Logitech G502 X Plus
Keyboard Keychron Q6 Pro
The real reason I'd pick a 990 Pro over a 980 Pro is the 990 comes in sizes larger than 2 TB.
That said, I'd buy a 4 TB SN850X, and neither Samsung drive. Similar performance, but usually much cheaper. It was recently ~$250 from WD's site for the 4 TB model.
83 (0.11/day)
Processor AMD Ryzen 9 5950X (4900 Mhz)
Cooling Corsair H150i PRO RGB
Memory Corsair Dominator Platinum RGB 64 GB DDR4 3600 Mhz
Video Card(s) nVidia GeForce RTX 4080 Founders Edition
Storage Samsung 990 PRO NVMe SSD 4000 GB (OS) / Samsung 860 EVO SSD 2000 GB / Samsung 860 EVO SSD 4000 GB
Display(s) Samsung 46" TV
Case Phanteks Enthoo Luxe (Black)
Audio Device(s) Creative Sound Blaster AE-7
Power Supply Corsair AX1500i (1500W)
Mouse Logitech MX518 Legendary 16000 DPI
Keyboard Logitech G910 Orion Spectrum RGB
The 4 TB version of the 990 PRO is still an unreleased product that you cannot buy anywhere (and the ETA is still unknown).
So currently, you can only buy up to 2 TB with the 990 PRO (just like the 980 PRO).
3,811 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
SN850X +1 from me, WD unlike Samsung dont seem to have multiple weird issues with drives.
49 (0.03/day)
Got 990 pro, specifically because I needed to use Bitlocker and it states everywhere it has hardware encryption.
Turns out hardware encryption doesn't work on 990 Pro (unlike earlier models), and I tried to do it multiple times, it always did software encryption despite ensuring everything is set up correctly in Samsung magician and BIOS. There is a long topic on Samsung forum with a lot of people having this issue. Samsung released a firmware update to fix it and apparently it fixed it for some but not the others.
What a clusterfuck, money down the drain. I'll have to use software encryption and waste some performance.
1,062 (0.17/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 990PRO 2TB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/9qw7iq https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
Samsung 980/990 PRO, Kingston KC3000 or Seagate FireCuda 530 should be a great choice.
AsRock
TPU addict
19,175 (2.98/day)
UK\USA
Cooling D15
Yes it will get you insane response how ever by minor percentages and maybe a second here and there. Should only get these drives when there are crazy sales on them other wise a SATA3 6G drive will just plenty.
3,398 (1.68/day)
Power Supply Corsair RM750x
Mouse Logitech M575
The 980's had pretty good sales price at $99. I was eying that WD 4TB that recently went on sale but going to wait it out until the Christmas season.
AsRock
TPU addict
19,175 (2.98/day)
UK\USA
Cooling D15
I picked up 2 990's 2x2TB for $220 just a few days ago.
