Samsung 990 PRO Flagship SSD Has an Endurance Problem, Users Notice Rapid Drive-Health Drops
2,671 (0.94/day)
To keep my【Treasure】:) safe I do regular backup to a secondary RAID within the same NAS ( with hard drives) then rotational backup to 2 USB external drives.
Since the failure only breaches the primary RAID, drive replacement + restore from the secondary RAID is all it needed.
Downtime is about 2 days
Thank god I did all the preparation.
Sounds like a georedundancy with extra steps. :D
CrystaldiskInfo 8
Samsung SSD 850 EVO 500GB 500.1 GB
Windows 10
43TB WRITES
95% GOOD
Is that good?
Looks a bit off to me, but for an EVO might be normal.
1,727 (0.77/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
So what do you recommend for NAS storage?
I prefer MX500
It is cheap, locally.
MX500 $275 for 4tb , $130 for 2tb
870EVO $330 for 4tb, $160 for 2tb
Consider buying 4 of those for RAID5 and you saved up the money for another drive which could be RAID6 / hot spare
There is no meaningful performance difference vs 870EVO
Very reliable in my use case
Currently running 6x2tb + 1x4tb + 3x500gb MX500s in the house in NAS / EPYC VM server
None of them fails so far.
132 (0.03/day)
Mozambique
System Name Frankenstein
Processor Ryzen 9 5800X
Motherboard Asrock Z570 Phantom Gaming X
Memory 2 x 16 GB DDR4 G.Skill 3200mhz
Video Card(s) SAPPHIRE Toxic Radeon RX 6900 XT WC
Storage Corsair MP600 + 2xSamsung 860 Evo + Samsung 950 Pro + Others
Display(s) Samsung Neo G7 32"
Case Lian Li O11 Dynamic Evo White
Audio Device(s) AudioEngine A5+ White
Power Supply Seasonic PRIME 1300W
Mouse Logitech G604 Lightspeed
Keyboard Razer BlackWidow V4 Pro Wired Mechanical
And I just ordered 2TB 990 Pro today. I've been very happy with my 500GB 970 Pro MLC drive that I'd wish to get a new Samsung drive.
50TB so far in 3 years 94% health left.
Canceled my order, not gonna risk if it has same problem or not.
Edit: Ordered Kingston KC3000 instead.
what software is this? WHinfo?
46 (0.01/day)
Istanbul
Processor Q9650 @4.25GHz(8,5*500MHz)
Motherboard Gigabyte EP45-DS3P
Memory 2x2GB Corsair XMS2 1066MHz DDR2 Ram
Video Card(s) Gigabyte GTX 460 1GB OC @975/4600MHz
Storage 256GB Corsair Performance Pro + 2x500GB WD Caviar Black RAID0 + 2TB WD Caviar Green
Display(s) 23'' Samsung 2333T c-PVA
Case Thermaltake Tsun ami Dream Mid Tower Case
Power Supply Seasonic Platinum 1kW
420 (0.44/day)
My 990 pro 2 terabyte still has zero percentage used or 100% life left according to Samsung Magician software even after 2 months of use. I am very interested in how this story unfolds.
9,340 (4.96/day)
Louisiana
Keyboard G710+x3
Samsung magician is bias software
You can verify with above mentioned hwinfo64 using sensors only and agreeing to the warning popup message.
You can also use crystal disk info
947 (0.14/day)
Round Rock, TX
Processor 9800x3d
Motherboard Asus Strix X870E-E
Cooling Kraken Elite 280
Memory 64GB G.skill 6000mhz CL30
Video Card(s) Sapphire 7900XTX Pulse
Storage 1X 4TB MP700 Pro - 1 X 4TB SN850X
Display(s) LG 32" 4K OLED + LG 38" IPS
Case Lian Li o11 Air Mini
Power Supply Corsair RM1000x
Software WIndows 11 Pro
strange issue, clearly not all drives are affected.
Will be interesting to see what's causing it, i would think if its a reporting/calculation bug, it would be the same across all drives with the same firmware.
Here's my 2TB in HWINFO:
9,340 (4.96/day)
Louisiana
Keyboard G710+x3
99% life on a very old 256gb 850 pro os ssd
Guess these days are long gone
Funny 990 has three temperatures now
2,060 (0.48/day)
System Name DarkStar
Processor AMD Ryzen 7 5800X3D
Motherboard Gigabyte X570 Aorus Master 1.0 (BIOS F39g)
Cooling Arctic Liquid Freezer II 420mm AIO (rev4)
Memory 4x8GB Patriot Viper DDR4 4400C19 @ 3733Mhz 14-14-13-27 1T
Video Card(s) GAINWARD GeForce RTX 2080Ti Phoenix GS 11GB GDDR6 @ 2100Mhz Core/16Gbps Mem
Storage 1TB Samsung 990 Pro (OS);2TB Samsung PM9A1;4TB XPG S70 Blade (Games);14TB WD UltraStar HC530 (Video)
Display(s) 27" ASUS ROG Swift PG279Q @ 2560x1440 @ 165Hz IPS G-Sync
Case be quiet! Dark Base Pro 900 Rev.2
Audio Device(s) SteelSeries Arctis Nova Pro Wireless
Power Supply 1000W Seasonic PRIME Ultra Titanium;600W APC SMT750i UPS
Mouse Logitech G604
Keyboard Logitech G910 Orion Spark
Software Windows 11 Pro x64 24H2 (Build 26100.3775)
Two actually: Controller and NAND. Controller temp is usually #2 and is the higher one as NAND does not get as hot unless stressed.
HWInfo64 shows 3 for some reason but Drive Temperature is simply the NAND temp taken from another sensor most likely.
So unless Samsung has placed 3rd sensor on DRAM i doubt it shows more than the Controller and NAND temps.
I still have one 128GB 850 PRO. The thing is a tank. MLC NAND barely degraded. Before i retired it it has only like 1% wear after 100TB+ writes over multiple years, thousands of hours of power on and hundreds of power cycles.
420 (0.44/day)
Both my 3 year old 970 2 terabyte evo plus and 990 pro say 100% life must be a lightweight user compared to some
https://photos.app.goo.gl/eCUa9RFDkTNwa3XJA :cool:
Normally every drive has a small batch of bad drives. Eg. go to any drive review and look at the often insignificant ( although unfortunate ) amount of bad reviews. How many people came forward with 990 pro life degradation so far? I heard 2 so far maybe more. What's the alternative pcie 5.0 nvme ssds that have no user reviews that cost 2 to 3 times the amount for a real world performance that is probably similar. If anyone does experience performance loss please post here. Although I don't want people to go on a testing frenzy even though testing shouldn't cause loss of life that rapid either.
Update: I am running them at Standard Mode, not sure if full performance is also a culprit?
547 (0.09/day)
System Name -
Processor Ryzen 9 5900X
Motherboard MSI MEG X570
Cooling Arctic Liquid Freezer II 280 (4x140 push-pull)
Memory 32GB Patriot Steel DDR4 3733 (8GBx4)
Video Card(s) MSI RTX 4080 X-trio.
Storage Sabrent Rocket-Plus-G 2TB, Crucial P1 1TB, WD 1TB sata.
Display(s) LG Ultragear 34G750 nano-IPS 34" utrawide
Case Define R6
Audio Device(s) Xfi PCIe
Power Supply Fractal Design ION Gold 750W
Mouse Razer DeathAdder V2 Mini.
Keyboard Logitech K120
VR HMD Er no, pointless.
Software Windows 10 22H2
Benchmark Scores Timespy - 24522 | Crystalmark - 7100/6900 Seq. & 84/266 QD1 |
I avoided Samsung SSD after I had 3x 4TB 870EVO in my NAS failed in 2 weeks time.
The 870 series was garbage from the get go. The last good SSD Samsung released was the 970 series.
I have a 960 pro that I had for several years now and its life is still at 98% (13k on-hours, total reads/writes 86/58TB), and the used Crucial P1 that is also a few years old but newer than the samsung is sitting at 99%
AsRock
TPU addict
19,241 (2.96/day)
UK\USA
Cooling D15
Would not be the 1st time SMART has got it all wrong. Who knows SMART might be killing other drives because of PC error's.
Funny there is no way to undo a drive at your own risk when it goes read only.
25 (0.02/day)
I will never ever buy Samsung products again, as I realized that they do not honor their warranty for their products. I had an in-warranty earbuds purchased directly from Amazon that was listed as a US model and when one of the two earbuds failed, I sent it in for warranty repair. Samsung sent it back unrepaired without a reason or explanation. I had to contact them 3 times to get an answer for why the warranty wasn't honored and they said it was a Caribbean model and not for the US market. I contacted Amazon and they assured me it was a US model and they replaced the defective earbuds for me instead. After that, I realized how shady Samsung was and vowed never to buy any of their products again. Just a shameful company and terrible service all around. They obviously don't give a damn about their customers in the slightest.
joesiv
1 (0.00/day)
SSD's have much more complicated firmwares than HDDs, there is so much more to go wrong. With using more layers, and having more features to assist in caching and wear leveling, things can definitely go wrong.
At the company I work for, we did extensive testing on SSD's years ago, after one brand failed us due to firmware bugs. This stuff is not hard to detect with a reasonable testing setup, if you're looking, especially if you have cooperation from the manufacturer, which reviewers typically have. It was a pet peave of mine when I used to read SSD reviews and all the reviewer would say about endurance is the marketing tarabytes written. I used to comment on reviews requesting them to actually test life exepctancy, or at least LOOK at the SMART data after all their testing, and get a gut feeling if it is ok or not. This would have caught this issue and it could have been presented either to Samsung to look at it, and hopefully fix it before it was released, or have a firmware ready to go soon after release. Or, reviewers could have given a warning to buyers.
Something to understand about life expectancy and "terabytes written". The spec that they advertise and gets repeated by most people and reviewers is NAND writes. And this is based on the NAND that was used in the product, it's well tested, how many writes can the NAND handle on average, mixed in with over provisioning, you have your terabytes written.
The problem is, that people (and probably some reviewers) expect that to be "OS bytes written", when you copy 1 TB to your disk, that's an OS write. Unfortunately, unless you look at the SMART data (you may need manufacturers help to understand how to decode it, or to get the the units they are storing in) and look at the NAND writes. you really have no idea how much you've written to the disk.
Your "1 TB" written, may actually be much greater than 1 TB NAND writes. Actually, now that I think about it, DRAMless cached models, it may even be greater than 2 TB, if they are copying it from some SLC mode NAND over to standard multi layer/3d NAND.
The difference between OS writes and NAND writes is called "write amplification", it's a known metric for SSD manufacturers, and different grade SSD's intended for different uses (consumer vs enterprise for example) will have acceptance of different write amplifications to be within spec. Thats why it's a faux pas to use a consumer grade drive in a NAS. Perhaps DRAMless SSD's have higher write amplifications due to caching, I don't know. But I do know that features like wear leveling and maintenance tasks will increase the write amplification, as the SSD maintains the data on the drive and pushes it around. This is all normal and expected, but if something is wrong with the firmware, things can easily go wrong, and write amplification can get out of control.
We should try to get a full dump of the SMART data, and see if samsung publishes it's SMART data documentation, and we'll probably find that NAND writes are actually right in line with the life expectancy that's being reported. If the workload is typical, then this is likely a firmware bug
3,088 (0.78/day)
Mouse Razer Abyssus
Software Ubuntu
No one should be surprised by these news. I've been saying it for years that the endurance ratings of TLC/QLC/... are just marketing BS. I'm at least glad I secured myself one of the last 970 Pros for my next build. (I have 3 in total)
I've also noticed some SSDs tend to wear out very quickly (not this model in particular), without much data written at all. My theory is that lots of small writes will cause a lot of wear, at least in certain patterns. But I haven't tested this out in a controlled environment.
I would actually like if TPU wrote an editorial asking the market to create a proper pro SSD again, like a SLC SSD of 256 GB, 512 GB, 1 TB, 2 TB and 4 TB variants. In a market oversaturated with crappy white label SSDs, isn't there room for at least one proper enthusiast/prosumer SSD? I would buy several.
22,107 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Software Gentoo Linux x64
420 (0.44/day)
Update my 990 pro 2 terabyte lost 1% since a few days (99% life left) ago with almost 10 x less writing than my 970 evo plus 2 terabyte drive which is still reading 100% life. Both on new magician software up version 10.0.22621 and CrystalDiskinfo version 8.17.14. I hardly used my PC since last reading but I did update my Magician software. FYI.
Not sure if this helps Tom's article mentions the 980 pros early death might be fixes with new firmware https://www.tomshardware.com/news/samsung-980-pro-ssd-failures-firmware-update
3,929 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Samsung not doing great with this and 870 EVO issues, but my question, how come this got a story but not the 870 EVO problem?
Update 2 - 2023.01.23
Samsung's RMA division, Hanaro, have reached out and offered to A) Replace this SSD, and B) Try to replicate the problem. Quite why both of these options were not on the table before the issue became public is a mystery.
I was watching a video about a user having this issue, 93% after no more than 10TB ( owned for a month ) writes and apparently samsung told them it's a none issue.
We'll see.
Did they hire the MX500 firmware team?
My 512gig 850 pro has done years in my main PC as OS drive, followed by PS4 duty (which auto records game footage as you play), and is now been used as a ZFS host drive in proxmox, its the best drive I own I reckon.
I think its a combination of chasing good reviews (making it bench well) and been greedy on margins e.g. ditching MLC for TLC on pro drives.
The 870 EVO on paper is no better than the 860 EVO so one wonders why the 870 was even released and the only explanation is they done some cost cutting somewhere.
2,060 (0.48/day)
Mouse Logitech G604
This is the exact same problem that was affecting my PM9A1's that Tom's quoted in the article from Reddit (that's me they quoted).
My post was made before i discovered the new firmware and found a way to update.
Media errors kept increasing and available spare kept dropping. Updating the firmware did stop the degradation.
Atleast currently these values have not changed anymore. It was also way more difficult because OEM versions of Samsung SSD's like my PM9A1 cant be updated trough Magician and have to be updated via command-line utility in a roundabout way.
Even finding this utility took me over a year as it was not available when i first checked in 2021.
2,621 (0.53/day)
Springfield, Vermont
System Name KHR-1
Memory 64 GB G.Skill RipJaws V F4-3200C16D-64GVK
Case Corsair 275R
Mouse Logitech G Pro (Hero)
I have a TeamGroup 1TB GX2 that seems to be having problems with trimm. Speed drops to 5MB/sec in some parts of the drive. Contacted TeamGroup, send them a number of benchmarks, got some replies from them, including one saying that....
in the end because of also a busy period for me with my job and stuff, just gone and bought a Kioxia to replace it.
Some companies aren't really helpful when someone finds a problem with their products. And this case proves that even Samsung that asks from the consumer to pay a premium, isn't better either.
Looks like a faulty SSD.
420 (0.44/day)
Update another Magician software update another 1% loss of life so now my 990 pro has 98% life. The only thing I did was install Hogwarts and 20% complete progress for game. Stay away from Samsung drives until they realize that their laxed approach to this will not be tolerated. They are relying on mind share too much but this arrogance will bight them in the arse!
2,621 (0.53/day)
System Name KHR-1
Case Corsair 275R
The 850 Evo has firmware updates, too. IIRC, Magician alerted me about a firmware update.
9,340 (4.96/day)
Louisiana
Keyboard G710+x3
They need to clean house in their firmware department or actually test the crapware better before release.
Think they adopted microsoft testing which are end users not paid ms personnel :laugh:
2,060 (0.48/day)
Mouse Logitech G604
https://www.reddit.com/r/hardware/comments/110x049/_/j8by0s8
Unfortunately this only stops the degradation. It does not reverse it.
