Samsung Announces New 27-inch 3D LED Monitor for Gaming
Easy Rhino
Linux Advocate
15,649 (2.35/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
I don't think there are any 3d monitors in that size for cheaper, regardless of quality.
which is why haters gonna hate. if they can't afford it they get mad.
5,614 (1.01/day)
San Diego, CA
System Name White Boy
Cooling CORSAIR H100
Display(s) 1 Dell 30U11 30"
Case BIT FENIX Prodigy
Audio Device(s) none
Price seems high and the resolution is low IMO.
Easy Rhino
Linux Advocate
15,649 (2.35/day)
Mid-Atlantic
System Name Desktop
Mouse MX Master 3s
1,180 (0.19/day)
Australia
Processor Intel i7 4790K
Motherboard Asus Z97 Deluxe
Video Card(s) Asus R290X
Display(s) Samsung S23A950D
Case Corsair 850D
Power Supply Corsair AX850
Keyboard Logitech G710+
They are not 2 different tech's, ie: you have 120hz, and bam you have 3d also
Still for a 27" monitor at 1080p it is horribly overpriced and under spec'd, in all honesty I could care less about 3d ffs, give me some more real estate especially on a 27" monitor, 1900x1200(+upwards) would be nice and not any more expensive to produce, 3d or not for $600 there are much better 27" monitors out there for that kind of money, I mean who do they think they are? Apple??
You obviously havent tried a 120Hz monitor for gaming. Talking about 120Hz not 3D. If you're a gamer and you dont have a 120Hz monitor you're missing out.
Anyway as i said, we have the SA750 and SA950 series for sale in Australia, although stock hasnt been regular you can buy the 27" for around $500 AUD/US.
BTW, Just to be clear, apart from 120Hz, this isnt your average TN screen. It does more than 100% of sRGB colour. The colours are better than 6 bit IPS panels like the U2311.
This review is for the 950 but the panel is the same...
http://www.xbitlabs.com/articles/monitors/display/samsung-sa950_6.html#sect0
The image quality is very good, surprisingly good for a TN, these monitors are selling like hotcakes and people are very happy with it. Most stores sell out of stock as soon as it arrives, thats why some stores are quoting a high price, they are selling at any price.
53 (0.01/day)
It's taken a long time for this version to hit the market. The 950D has been around for a while now. If I was searching for a 27" 120 Hz panel I'd probably pick that one over this. But I'm actually more interested in the 23" 750D if it can be found at a decent price. This monitor looks to have fairly small bezels so it would fit nicely as the center monitor in my Eyefinity config. At the moment I have the LG 23" 120 Hz monitor but it's just butt ugly and has a fairly large bezel. Also the Samsung monitor should have a bit higher quality panel too.
1,587 (0.21/day)
Poland,Slask
System Name HAL
Processor Core i5 2500K
Motherboard Asus P8P67 Pro Rev3.1
Cooling stock
Memory 2x4GB Kingston 1600Mhz Blu
Video Card(s) Asus 560Ti DirectCuII TOP
Storage Kingston 120 3K SSD,WD Black WD1502FAEX
Display(s) LG 1440x900
Case Chieftec Mesh Midi
Power Supply Corsair TX750V2
Software w8
2 highly anticipated shooters coming up if there was a moment for large/HD/3D screens to bloom now its the time.
This would be nice for Battlefield 3 yumm yumm 27 inches and 3D.
dsdsdk
76 (0.01/day)
Why glossy Samsung?! Why?
Why no DVI for 750 model?
Why not support 3D vision?
Why having to change manually to 3D mode?
Isnt 1920x1080 @ 120hz the max resolution for DVI bandwidth?
5,392 (0.94/day)
Carrollton, GA
System Name ODIN
Processor AMD Ryzen 7 5800X
Motherboard Gigabyte B550 Aorus Elite AX V2
Cooling Dark Rock 4
Memory G Skill RipjawsV F4 3600 Mhz C16
Video Card(s) MSI GeForce RTX 3080 Ventus 3X OC LHR
Storage Crucial 2 TB M.2 SSD :: WD Blue M.2 1TB SSD :: 1 TB WD Black VelociRaptor
Case Fractal Meshify C
Audio Device(s) Onboard Audio
Mouse Corsair M65
Keyboard Corsair K70 RGB Lux
1. It is not glossy, that is a studio light. I don't think 3D monitors or TVs can use a matte finish because it affects the light from the display to much. The Ultra clear screen this monitor is using does a good job of defusing reflective light, but its not perfect.
2. I no idea honestly. I guess they wanted to keep things small and a DVI plug is rather large and would eat up a lot of room in the small stand.
3. 3D Vision is just a name used by Nvidia for their 3D Tech. Monitors do not "support it" they are simply either 3D capable or not. This one is 3D so you can use whatever technology you want to generate a 3D picture.
4. How would you do that automatically? I am sure when you turn on 3D on your computer it will send a signal to the monitor to switch to 3D mode, this is still technically a manual switch as the monitor did not detect this and set itself. It was told by your computer to change. This is just semantics.
5. No. Maximum resolution for Dual link DVI-D is 1920 x 1200 @ 120 Hz. But that is just the different between 16:9 and 16:10. This monitor is 16:9 so 1920 x 1080. I am sure they will released a 760 or something that is 16:10.
Oh and newegg.com has it listed now at $600: SAMSUNG S27A750D Black 27" 2ms Full HD 3D LED Back...
Which begs the question considering Easy's link from earlier. Did the Euro get weaker or the dollar stronger?
5,598 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
I noticed no ones said whether or not it runs 120Hz in normal 2d mode and asfar as I'm aware 120HZ for 3D is just 2 x 60Hz signals
5,392 (0.94/day)
Carrollton, GA
System Name ODIN
Cooling Dark Rock 4
Mouse Corsair M65
Well I can't say for sure, but it does list 120 Hz as a input it will accept. And it has a 2D to 3D upconverter. Those features usually mean the monitor is true 120 Hz and switches to 2 x 60 Hz for 3D. Also Samsung is one of 2 companies that refuse to use gimmicks or tricks to get 120 Hz. There should be no reason you can't run this at 120 Hz in 2D mode.
Black Haru
1,567 (0.29/day)
Indiana
a review of the 950d I read on another forum had a section on 2d 120hz. iirc it did very well.
edit* anyone know if DP or HDMI can actually run 120hz at decent quality? (cause the 750d has no DVI)
5,392 (0.94/day)
Carrollton, GA
System Name ODIN
Cooling Dark Rock 4
Mouse Corsair M65
It would be the same or better. Remember HDMI = DVI-D + 8 channel HD audio. And DisplayPort = Dual Link DVI-D + 8 channel HD audio + new features
767 (0.15/day)
System Name An experiment in continuous upgrading
Processor Intel Core i7 2600k @ 4.4 Ghz | FX-8570 @ 4.0 Ghz | Phenom II X4 965
Motherboard MSI P67A-GD53 | MSI 990FXA-GD80 | Asus M4A79 Deluxe
Cooling Noctua NH-D14 | Zalman CNPS10x | Coolermaster*212+
Memory 24gb DDR3-1866 |8Gb | 8Gb
Video Card(s) ASUS GTX 970 Turbo x 2 (SLI) | Sapphire Radeon 7970 + GTX 670 (PhysX) | Radeon 4870 1Gb
Storage 2x240gb SSD + 4tb SSHD + HDDs | 240gb SSD + HDDs | 120gb SSD + WD Blue 500gb
Display(s) ASUS VG248 144hz + Samsung S23A700D 120hz + 3D Vision | 40" Sony 1080p TV | 23" 1080p
Case Cooler Master HAF-X | Lian-Li PC-8 | Antec 302
Audio Device(s) Senn. PC360 G4ME | Sound Blaster Zx | Generic
Power Supply Corsair TX850W | Corsair TX 750 | OCZ 700
Mouse Steelseries Sensei | Logitech G402 W/L | Generic
Keyboard Filco Majetouch Ninja Tenkeyless MX Black | Logitech wireless |SteelSeries 6Gv2 MX Red
Software About 800 top-rated games. | 200 top-rated games | No games
Benchmark Scores No time for benching, I prefer gaming.
That is most definitely my next monitor. I wonder if my 3D Vision will work on it or not. In theory it should but...
53 (0.01/day)
It won't work, or at least the normal 3D Vision won't, the HDMI 1.4a Blu-Ray 3D support might. 3D Vision only works on Nvidia certified monitors, and this is not one, and doesn't even have the dual link DVI-D it requires. AMD on the other hand supports this monitor, and it and its sibling models are the first to support AMD HD3D through DisplayPort, hence they're the only monitors available that can do 1080p/60Hz with HD3D (since HDMI 1.4a limit is 720p/60Hz or 1080p/24Hz)
5,392 (0.94/day)
Carrollton, GA
System Name ODIN
Cooling Dark Rock 4
Mouse Corsair M65
Well there you go. Sorry it doesn't work with Nvidia 3D Vision.
Although you are completely wrong about HDMI 1.4a since it supports 4k video and will do 1920 x 1200 @60Hz. If that frame rate is a limitation is only for 3D movies and caused by the 3D tech, not the HDMI specs.
767 (0.15/day)
Oh, right you are and damn me for looking at the wrong model. They introduced a slew of similar models, the S and T, the 27 and 23, the 750 and the 950...
My next purchase isn't the model mentioned in the opening post but the S27A950D
Which is similar but has a double-link DVI and comes with its own included 3D glasses (for AMD HD3D)... Still, my current (nVidia-certified) Samsung 2233rz does seem to be nothing else than a 120hz monitor with a double-link DVI, so at first glance, it looks like it might work...
53 (0.01/day)
Technically yes, but I still don't think it'll work just because it's not certified by Nvidia. They might restrict 3D Vision for only those monitors in the drivers.
These monitors do have vendor independent 2D-3D conversion though, but I'm not sure how well that works in gaming since it might introduce too much input lag.
767 (0.15/day)
Hm, maybe someone will hack the 3D drivers just like SLI was hacked by changing the mobo's model string...
3,249 (0.54/day)
System Name White Custom Loop Fractal North XL
Processor AMD 9800X3D
Motherboard GIGABYTE PRO ICE X870E
Cooling AlphaCool Core 1 White CPU Block - 2x Heatkiller 360-L - Alphacool Core 120mm Resevoir
Memory 48GB 7200Mhz Corsair Dominator DDR5 - Overclocked to 8000Mhz
Video Card(s) RTX 5090 32GB Palit Gamerock - Alphacool Waterblock Incoming
Storage 4TB WD Black NVME Gen 4
Display(s) Alienware 38" 3840x1600 (165Hz)
Case Fractal North XL Chalk White Mesh
Audio Device(s) 2i2 Scarlett Solo + Schiit Magni 3 AMP
Power Supply Corsair RM1200x Shift White
Keyboard NEO75CU White + PBTFans Neon R2 Glitter + BSUN Macaron Switches
Sorry to revive this thread, but mine is still running 12 years later, the fan in it is still going strong LOL
