Samsung SSD 970 EVO Plus 1TB - Sequential Write Speed reduced by 1/2
xKoMox
6 (0.01/day)
Should I request a replacement SSD due to the Sequential Write Speed reducing by 1/2 ?
Would you consider the SSD faulty, or at risk of failure?
Sequential Write advertised up to 3,300 MB/S vs currently 1,137 MB/s.
I purchased a new ready to run pc in June 2022, with MS OS installed on this Samsung SSD 970 EVO Plus 1TB. I then purchased an additional new 970 EVO Plus for my data in Jan 2023 and ran my first Samsung Magician test. The test results for the MS OS SSD were fine with Sequential Write at 3,467 MB/s, but then when I ran another test in March 2023 it had reduced to 1,071 MB/s, and ever since stayed quite low. I ran my most recent test as Samsung Magician updated to Version 8, on 03 Nov 2023 and although increased slightly is still only half speed at 1,537MB/s.
I've attached Screen shots of Samsung Magician test results
I'm running Windows 11 Home, 23H2.
854 (1.24/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 9 7900X3D
Motherboard ASUS ROG Crosshair X670E Extreme
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium.
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB
Software W10-11 Enterprise- Linux Mint 22.0 Cinnamon Edition.
Difficult to say... Can you show the screen of the SMART table? But honestly i don't think that the SSD is having problems. Maybe try another NVMe slot? Or boot from another SSD and then test this NVMe drive again without OS or programs that can interfere the test. Maybe it is some other program like an AV that is bothering the test.
For a good test, this SSD should be connected to the first NVMe slot, closest to the CPU. And boot from a Sata drive, then test this NVMe drive again. And if possible, maybe test it on another computer. Do a test like this on an SSD used as C: drive and OS Boot, is giving always mixed results.
You should close most background applications such as indexing, Windows updates, and anti-virus disabled in the OS to reduce run-to-run variability, and get a reliable testing result.
xKoMox
6 (0.01/day)
Hi SPDIF,
Thank you for that information.
I've attached the SMART table report.
From what i've been reading about read and write speeds, is it correct to say its not a real issue as I'm using this SSD only for my MS OS. It's really only going to be an issue if i was installing/writing a lot of programs etc and I wanted it done fast?
  • Samsung Magician - SMART.pdf
854 (1.24/day)
Belgium
Memory 32GB DDR5
As far as i can see your SSD is 100% healthy! So i would not worry about it, there's nothing wrong with it. You should do a test like this only when it is not used as Boot and OS drive. Too many things can interfere with the results. So take what you see with a grain of salt... You will have no issues even if you install a game from 50 or 100GB, so no worry's here. :)
2,403 (1.52/day)
Bulgaria
Reason to half SSD speed maybe is this. Check your Windows update status. In theory update in August fix the problem but... Just make check for sure.
xKoMox
6 (0.01/day)
Well thank you SPDIF, I'll leave it alone, and thank you for your personal and prompt replies.
Thank you also TumbleGeorge for your in put. My issue may just disappear in a future MS update, but until then I'm not sweating about it.
I have to say, I'm fairly new to the computer world, and I'm finding Forums such as TechPowerUp and Community Support sites to be 1,000% better than product support, who just seem to cut and paste information to troubleshoot.
Thanks again for sharing your knowledge.
854 (1.24/day)
Belgium
Memory 32GB DDR5
This SSD is one of the Top best they had available for not to high price, and it still is! have fun!
My very first SSD was an 970EVO from 256GB.... Without the Plus. And it also still works. Back then they where soo damn expensive.
Hugis
825 (0.15/day)
Spain(Living) / UK(Born)
System Name Office / Gamer Mk IV
Processor i5 - 12500
Motherboard TUF GAMING B660-PLUS WIFI D4
Cooling Themalright Peerless Assassin 120 RGB
Memory 32GB (2x16) Corsair CMK32GX4M2D3600C18 "micron B die"
Video Card(s) UHD770 / PNY 4060Ti (www.techpowerup.com/review/pny-geforce-rtx-4060-ti-verto)
Storage SN850X - P41Plat - SN770 - 980Pro - BX500
Display(s) Philips 246E9Q 75Hz @ 1920 * 1080
Case Corsair Carbide 200R
Audio Device(s) Realtek ALC897 (On Board)
Power Supply Cooler Master V750 Gold v2
Mouse Cooler Master MM712
Keyboard Logitech S530 - mac
xKoMox
6 (0.01/day)
Thank you again.
Do i need to do anything to close or mark as resolved or answered?
2,403 (1.52/day)
Bulgaria
There may be a reason you want to post a new comment here to develop your case. If the topic is locked, you will need to contact a moderator to unlock the topic. Which is extra effort.
847 (1.19/day)
System Name Asus G16
Processor i9 13980HX
Motherboard Asus motherboard
Cooling 2 fans
Memory 32gb 4800mhz
Video Card(s) 4080 laptop
Storage 16tb, x2 8tb SSD
Display(s) QHD+ 16in 16:10 (2560x1600, WQXGA) 240hz
Power Supply 330w psu
My 2nd nvme was a 1tb 970, non X. Among the best SSDs I've had so far. Ran fast, ran cool, even on a laptop's small confined space. Later on I fully upgraded to x2 970 2tb. Passed those on to the son's desktop. It was Samsung at the height of SSD manufacturing.
854 (1.24/day)
Belgium
Memory 32GB DDR5
Here the speeds of an old 970EVO no Plus of 256GB, not bad if you ask me!
And the speed of an 970EVO Plus 500GB.
9,340 (5.27/day)
Louisiana
Keyboard G710+x3
Yeah just got mine hooked back up the other day in my z490 rig
I was using linux mint so much I removed them plus playing with 11 to it was just to much to keep removing... to use it
Used it briefly benchmarks back when I got it and also have a 970 evo 500gb at thew same time for my x299 build bur same story why I removed it may hook it back up later.
Well that evo plus above has different parts than mine does mine didn't even get close to that write :p
854 (1.24/day)
Belgium
Memory 32GB DDR5
Different parts? Haha lol. :) No just the same as you have, i am doing nothing special, just test it. I think in your case the writing is lower because your SSD in throttling. Meaning i think it became to hot, and then the speed goes down! I see temperature from almost 70 degrees Celsius, that's your problem. You have to cool it more, and maybe that is the same problem that OP has...
Also your CrystaldiskMark is on the wrong settings... In the settings tab, you have to choose NVMe SSD.
9,340 (5.27/day)
Louisiana
Keyboard G710+x3
I've never poked around in the settings :eek:
Little different but not in the main write
I've got a heatsink with a little fan running at about 5400rpm lol it was way worse than that without it
Think the difference in temp 1 & 2 was 20c+ before
854 (1.24/day)
Belgium
Memory 32GB DDR5
You use this drive as boot and windows installed on it?
As said earlier, you have to test your SSD while you boot from another SSD to get real results.
9,340 (5.27/day)
Louisiana
Keyboard G710+x3
Yep.
C is always boot.
854 (1.24/day)
Belgium
Memory 32GB DDR5
Then you will never get good results on the testing. Windows interferes while you test the drive, or even antivirus programs. You have to close all open programs, including antivirus, windows indexer and so on.
That is why i boot from an 870EVO SATA drive, and then test the 970EVO from this drive. So no programs and no OS that can block your testing.
9,340 (5.27/day)
Louisiana
Keyboard G710+x3
Okay another thing I didn't know lol :banghead:
Well here's the smart stuff
Just snapping this is the regular evo not the evo plus :eek:
xKoMox
6 (0.01/day)
SPDIF, did you leave all the Crystal Disk Mark setting on default, except changing from Default to NVMe SSD in Settings? It appears TharashZone just left everything as default.
I noticed the difference in the title of the second and third test, ie
Default is SEQ1M Q1T1 and RND4K Q32T1
vs
NVMe SSD is SEQ128K Q32T1 and RND4K Q32T16
I did the test myself on all my drives and the results are quite different. Changing settings to NVMe SSD gives the best results.
Heres my data drive on D (boot on different drive C)
Samsung 970 EVO Plus NVMe M.2 SSD 1TB
default
Changed setting to NVMe SSD
854 (1.24/day)
Belgium
Memory 32GB DDR5
See? Your drive is performing very well! The default is used for old HDD and SATA SSD, for NVMe SSD you have to change it in CrystalDiskMark!
Anyway welcome to the club. LOL :) I knew nothing was wrong with it.
xKoMox
6 (0.01/day)
That was my data drive (D)
This is my boot/os drive (C) that i was concerned about showing 1/2 write. But going by what you have been saying I'm not concerned as os is probably affecting the results.
9,340 (5.27/day)
Louisiana
Keyboard G710+x3
I'd contact sammy personally about the issue and rma it
I found and got the same system image on my 970 evo plus finally and it's working fine as os drive on win-11
3,667 (1.70/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Most recent bench of my 970 EVO (non plus) 1TB model. 2nd April 2021, tested on my old 9900k build.
59 (0.06/day)
Lian Yu/Starling City/Star City (multi-timelines)
System Name The NEW Foundry
Processor Intel Core i9 13900K
Motherboard Asus TUF Z790 Plus D4 WiFi
Cooling Arctic Liquid Freezer III 360mm (using Noctua 120mm AF12 Chromax fans)
Memory 128GB (4x32GB) Corsair Vengeance LPX DDR4-3600 (18-22-22-42)
Video Card(s) Nvidia GeForce RTX3080ti 12GB + Intel UHD770
Storage Samsung 980Pro 1TB (Boot) / Samsung 980Pro 2TB / Samsung 980 1TB / 860EVO 512GB / Crucial T700 2TB
Display(s) Samsung Neo G9 49" UltraWide 5120x1440@240Hz + Samsung 28" 3840x2160@60Hz
Case Lian Li Lancool II Mesh Performance-C (2 x 140mm + 6 x 120mm Noctua Chromax fans)
Audio Device(s) Logitech Pro X 2 Headset + Edifier R1580MB
Power Supply EVGA 1000W 80+ Gold Fully Modular
Mouse Logitech G903 "Lightspeed" Wireless
Keyboard Logitech G915TKL + AttackShark X85 ‘Hall Effect”
Software MS Windows 11 Professional X64
Similar speeds to my 970 Pro Gen3 SSD on 9900K build.
Also greetings fellow Leicester citizen (South Central LE2 here) :toast:
