Sapphire RX6900XT Black Screen help !
LuckyOwl
11 (0.01/day)
Hello guys need help and your advice, recently just bought Sapphire Nitro+ RX6900XT Special Edition from Fb marketplace card itself looks like new and warranty seal on screws not broken.
So problem is when I installed everything boot up as normal card working fans and rgb light working display also showing as normal but when I try to instal drivers in the middle of process black screen apiers and stay until you restart or delete drivers. When restarting some times display working again. Also in device manager can see code 43. So basically when GPU hits drivers always black screen appears :(
Recently tryed things:
DDU
Fresh Install of Windows 10
Bios switch tryed all positions
All type of drivers including enterprise one
Also tryed to flash original bios but will find only unverified ones for this card, and will flash without problems but same nothing happens, also tryed to flash another card bios but seems program not allowing this :(
Any suggestions ? Might be faulty memory module ? Thanks in advance
349 (0.07/day)
Tirana,Albania
System Name Red and Green,mean machine!
Processor AMD RYZEN 7 5800X3D
Motherboard Gigabyte B550 Aorus Pro
Cooling Arctic eSports Duo
Memory 16GB DDR4 Corsair 3600Mhz
Video Card(s) Gigabyte RTX3080 Waterforce
Storage Couple ssd , nvme etc
Display(s) AORUS FI25F 240hz
Case Cooler Master HAF X
Audio Device(s) OnBoard
Power Supply Thermaltake Toughpower 750W
Software Win 11 64bit
Had a similar issue a while back on my 5700xt
This did it for me :
Give it a try.Also change monitor if you can or plug your pc to the TV while installing drivers
LuckyOwl
11 (0.01/day)
Thanks will definitely try to connect to different monitor
Just tried another monitor nothing changes :(
Is it possible to flash other card bios to this one ? as I can't found normal bios for this specific card...
Also when trying to flash another card bios like Nitro+ non SE model got SubsystemIDs mismatch, when tried force flash with command prompt it's starting flashing process and installer disappears what's it.
Any suggestions or other ways to flash this card ?
41,724 (6.60/day)
Use enterprise driver
41,724 (6.60/day)
What are your system specs?
I wouldnt buy any gpu from facebook, craigslist as there is no money back protection on there like there is on ebay or amazon.
Try the card in another machine or get it tested at a shop, if it does the same, well then you got scammed
LuckyOwl
11 (0.01/day)
Ahh no way to send it back as bought from stranger on marketplace, will try send it to gpu repair service center
System spec:
Asus rog B550 A
Ryzen 5600X
Evga Supernova 650w Gold
2x8Gb Corsair 3200mhz ram
490 (0.24/day)
Texas
System Name i'm done in
Processor AMD 5950x
Memory GSkil 64gb 3600 cl16
Video Card(s) Power Color R7900xtx Hell Hound oh hell ya
Storage 2x wd sn770 2tb 1-4tb wd- hd 2x8tb wd hd actually 1 fire cuda
Display(s) LG Ultra Gear 1440p 32" 165hz hdr monitor might go oled
Case Corsair 4000D Air Flow
Power Supply EVGA SuperNOVA 1000w G5 80+ Gold
Mouse logitech and roccet wcord
Keyboard logitech
Software W10 forever
psu not delivering enough power causing black screen maybe
41,724 (6.60/day)
System spec:
Asus rog B550 A
Ryzen 5600X
Is this the first gpu you have had in the system?
13,994 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Part number of the Ram?
8,868 (3.29/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
The power limit on a 6900XT is basically unlocked. The 6800 has a set TDP that it will not go past. You need at least a 750W PSU for the GPU to continue the process. My 6800XT/5950X system pulls 647 watts average while Gaming with the CPU pulling between 40-80 Watts. Even though the 5600X is only a 65W part (and does not exceed that) Asus is notorious for over volting their boards so the MB may even be the culprit. The solution though I am 99% sure is more PSU power to mitigate those issues.
LuckyOwl
11 (0.01/day)
Thanks will try another PSU.
1,126 (0.26/day)
Babylon 5
System Name DaBeast!!! DaBeast2!!!
Processor AMD AM4 Ryzen 7 5700X3D 8C/16T/AMD AM4 RYZEN 9 5900X 12C/24T
Cooling Thermaltake Water 3.0 360 AIO/Thermalright PA 120 SE
Mouse Logitech G303 Shroud Ed/Logitech G603 WL
Keyboard Logitech G915/Keychron K2
Software Win11 Pro/Win11 Pro
Please do that! My heart skipped a beat when I saw that you have a 650W PSU.....you'd need 750W, though I'd suggest you go over that, get an 850W Gold rated PSU from Seasonic, Corsair, Enermax, Be Quiet!, etc. My own Nitro+ RX 6900 XT + R9 3900X + 16GB RAM + 256GB NVMe M.2 + 4x SATA SSDs + 2x HDD main gaming rig is powered by a Corsair HD1000 Platinum. When it comes to PSU, my philosophy is to always get more than 'just enough' or recommended.
LuckyOwl
11 (0.01/day)
Thanks ! Also Is your GPU Nitro+ or Nitro+ Special Edition ? As I can't find correct bios for exact same gpu.
Guys also getting this error when trying to flash Original bios file from Nitro+ model, my Model Nitro+ SE but unfortunately can't find exact same bios.
-f option not support in external version of the tool. Please refer to tool help for list of option supported
Old SSID: 440E
New SSID: E438
SSID mismatched
ERROR: 0FL01
8,868 (3.29/day)
Cooling In Win SR36
Old SSID: 440E
New SSID: E438
SSID mismatched
ERROR: 0FL01
You should only be concerned with getting the system to post initially. Any flashing should wait at least a month to make sure all your parts are viable. A 6900XT is not something to mess around with Vbios.
LuckyOwl
11 (0.01/day)
An update will tried everything another, monitor, displayport cable, another psu nothing helps, just spoke with some man who repairing GPUs he says it's definitely memory module failure and will cost about £60 for diagnostic, £50 for work, and £40 for each failed module.
574 (0.11/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Creative AE-9 w/ Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
Yeah I would 2nd a higher PSU. On my 6900XT I originally had, I tried a 850W G.Skill Platinum and as soon as I powered on the system, I was getting an overvoltage error that didn't happen on my 2080 Super. Those cards definitely can pull a lot of power.
What was the other PSU that you tried?
LuckyOwl
11 (0.01/day)
It was 750w gold PSU, I actually can't believe that PSU might couse this problem.
1,126 (0.26/day)
Babylon 5
Old SSID: 440E
New SSID: E438
SSID mismatched
ERROR: 0FL01
Mine is the Nitro+ (non-SE), in other words, no fancy RGB on the fans. As the others have suggested, do NOT mess with vBios now, wait till you've stabilized the system (and have a stable, running card) and monitor for a while before even thinking of doing that. Why flash the vBios in the first place?
My Nitro+ has been on the original shipped vBios since day 1 when I got it, I don't see a need to even think of flashing it. Especially now when prices of GPU's have been crazy, I got mine in January 2021 at about 1350USD, now I see a listing at Amazon for about 2100USD, it's just nuts and not worth bricking a card just for the sake of flashing the vBios. In my neck of the woods, the card has almost doubled its pricing in some cases/listings (saw a listing at local Amazon site for the Nitro+ RX 6900 XT going for about 2530USD, converted local $ to USD), not a good time to be messing around with vBios, no sirree!
41,724 (6.60/day)
Old SSID: 440E
New SSID: E438
SSID mismatched
ERROR: 0FL01
You are using 3.20
You need to do -unlockrom 0 and then
-fa -fp.
-f is for 2.93 and older
I think you were given a broken card to begin with since the 6800 was ruled out.
Next time stick to ebay or amazon so you can contest any foul play, that's how I was able to get $100 back from a 5800 being advertised as a 5800X (called him out with undeniable facts)
The asshole you got it from probably mined on it (sons of bitches)
162 (0.15/day)
Processor 6900K @ 4.3Ghz
Motherboard Gigabyte x99 ultra gaming
Cooling H115i pro xt
Memory Tridentz 3200 32gb
Video Card(s) Galax RTX 4070
Storage 970 EVO 500gb
Display(s) AOC g2460pf
Case Non branded shit
Power Supply Corsair Rm550x
Mouse Logitech G603 Double click mode
Keyboard TGK205
Software Win 10
I feel sorry for you, scams are everywhere! Here when the main online shop mercado livre dont have a secure policy those son of bitches scammers selled alot of rocks and damaged things, now this is upside down and its rough to honest sellers becouse now "buyers" are the scammers, those most shameless fill the return packet with rocks (this is not so worse to seller, an unboxing video solve all) and those insidious send the same model of product with defect or damaged and it a certainlly loss.
I was thinking days ago, what a freaking shit society turned :mad:
