SAPPHIRE Solves Eyefinity Issue with Active DisplayPort Adapter
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.43/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
I'm trying to show why the two need separate, but compatible standards. Monitors are intended for a viewing distance of less than 2 feet where TVs are designed for 6+ feet. In order to get a good picture at less than two feet away, you need a really high resolution (dpi). Conversly, the farther away you get from the display, the lower the dpi necessary to make it look exactly the same to the eye. More DPI means more bandwidth and more bandwidth means more robust cables. I think it is a bad idea to attempt to merge the two. I mean, HDMI is just now getting market acceptance when DVI has been around a long time.
HDMI is good to go in the entertainment industry but it is time for the computer industry to move on. HDMI is old for that segment of the market.
Mussels
Freshwater Moderator
58,413 (7.89/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
your argument holds flawed logic.
since keyboards and mice dont need the bandwidth of USB and are designed for different things than flash drives, they should go back to PS/2 connectors - its been around longer.
Fair enough that you have your own opinion (dont care about HDMI) but your logic contradicts precendents - people prefer one unifying standard even if it does limit them slightly. its better than everyone having their own incompatible standards.
2,490 (0.38/day)
Your house.
System Name Jupiter-2
Processor Intel i3-6100
Motherboard H170I-PLUS D3
Cooling Stock
Memory 8GB Mushkin DDR3L-1600
Video Card(s) EVGA GTX 1050ti
Storage 512GB Corsair SSD
Display(s) BENQ 24in
Case Lian Li PC-Q01B Mini ITX
Power Supply Corsair 450W
Mouse Logitech Trackball
Keyboard Custom bamboo job
Benchmark Scores Finished Super PI on legendary mode in only 13 hours.
There are no choices anymore. You plug it in and the equipment tells everything connected what it is allowed to do regardless of what you, the consumer, actually want. This is just getting plain silly. Before long, you won't be able to do anything without signing a contract and connecting it to the Internet with which, they see, hear, and whatever else they conjure up without you having any authority beyond installing the equipment or not (and we know people would blindly agree--end justifies the means). The door is wide open to that doom's day prophecy with DisplayPort and once that door is open, it won't close.
Are you honestly surprised? What did you expect?
3,604 (0.57/day)
Terra
System Name :)
Processor Intel 13700k
Motherboard Gigabyte z790 UD AC
Memory 64GB GSKILL DDR5
Video Card(s) Gigabyte RTX 4090 Gaming OC
Storage 960GB Optane 905P U.2 SSD + 4TB PCIe4 U.2 SSD
Display(s) Alienware AW3423DW 175Hz QD-OLED + AOC Agon Pro AG276QZD2 240Hz QD-OLED
Case Fractal Design Torrent
Audio Device(s) MOTU M4 - JBL 305P MKII w/2x JL Audio 10 Sealed --- X-Fi Titanium HD - Presonus Eris E5 - JBL 4412
Power Supply Silverstone 1000W
Mouse Roccat Kain 122 AIMO
Keyboard KBD67 Lite / Mammoth75
VR HMD Reverb G2 V2
Software Win 11 Pro
i agree with GT90Concept
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.43/day)
IA, USA
System Name BY-2021
You know how a keyboard works, right? It has a series of interrupts and each key is assigned to a specific interrupt group. PS/2 is practically the same as USB in terms of wiring. If PS/2 were replaced with a new cable which supports one interrupt per key, there would never be a problem with interrupt collisions again. Instead of improving the keyboard connector, we threw it into a trash bin with all the other flawed connection standards.
Mice don't need as many interrupts as keyboards so more suitable connector than USB would be difficult to come by--unless something revolutionary happened.
The advantage of PS/2 mice and keyboard is that, if they plug in, you can be guaranteed they work so long as they aren't defective.
Standards = compatibility.
I'm not surprised, no. It should be illegal to develop such standards (business, not consumer interest) internationally.
Edit: The USB hub often isn't initialized soon enough. For example, my DFI LP X58 motherboard doesn't initialize the USB hub until an OS is loading. This means that, with an USB keyboard, the BIOS are not accessible. I have to plug in a PS/2 keyboard (which is initialized before POST begins) in order to access the BIOS. Yet another reason why keyboards need their own dedicated cable, connectors, and protocols.
5,250 (0.86/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
Munchy
1 (0.00/day)
Excellent i have found people that actually know what they are on about,
I have been through this saga on several forums now and wondered if anyone can kick me in the right direction,
i have HD5870
3 monitors all working
2 x dvi and 1 passive display port adapter to dvi
now i can only use 2 @ a time so is this really because i need the expensive adapter?
Please do note i do not want extended desktop i only want monitor one and monitor two in extended mode and monitor three mirroring monitor 2
i figured as it is actually working on all three monitors (only 2 at a time) there must be a way to use 3 at the same time.
lol i know my answer but i just need someone to shout it at me so i believe them. :banghead:
i feel a little hard done by shelling out 220 on the card and then another 80 is for the adapter.
ps has anyone seen the active converters for sale anywhere?
Edit,
new train of thought?
Seeing as the passive dp to dvi is working is it possible that they wont all duplicate due to the third monitor being a different size?
467 (0.08/day)
TR
Processor C2duo e6750@ 2800mhz
Motherboard GA-P43T-ES3G
Cooling Xigmatek S1283
Memory 2x2Gb Kingstone HyperX DDR3 1600 (KHX1600C9D3K2/4GX )
Video Card(s) HIS HD 6870
Storage samsung HD103SJ
Case Xigmatek Utgard
Audio Device(s) X-FI Titanium Pci-e
Power Supply Xigmatek NRP-PC702 700W
Software win7 ultimate -64bit
Correct you need active adapter for 3rd monitor http://www.amd.com/us/Documents/ATI_Eyefinity_Technology_Brief.pdf download pdf and read 7th and 8th pages
http://www.widescreengamingforum.com/forum/viewtopic.php?t=16792&postdays=0&postorder=asc&start=570
Read directly from Dave Bauman ( product manager of AMD/ATI )
Munchy i wish you had been written where are you living ,you can find DELL/blizzlink adapters at US and accell and sapphire adapters at Europe ,i gave a link to accell adapter at first page from a netherland company (accell = blizzlink ,retail brand according to info i found )
http://www.amd-news.com/assets/files/amd-cn/Eyefinity_SetupGuide_v1_AMD.pdf setup guide
Mussels
58,413 (7.89/day)
Oystralia
and all three monitors must be the same resolution, thats another requirement
1,675 (0.23/day)
Minneapolis, Mn
System Name Livingston
Processor i7-4960HQ
Motherboard macbook prp retina
Cooling Alphacool NexXxoS Monsta (240mm x 120mm x 80mm)
Memory 16Gb
Video Card(s) Zotac Arctic Storm Nvidia 980ti
Display(s) 1x Acer XB270HU, 1x Catleap, 1x Oculus
Benchmark Scores http://www.3dmark.com/fs/770087
and 1920x1080 max correct? Or can all 3 be run @ say 2048x1152.
Mussels
58,413 (7.89/day)
Oystralia
i didnt see a max res, but that doesnt mean there isnt one
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.43/day)
IA, USA
System Name BY-2021
The safest max res would probably be 1920x1200 @ 60 Hz (single-link DVI). It might be able to go to dual-link DVI res (2560Ă—1600 @ 60 Hz) but don't count on it.
467 (0.08/day)
TR
1,675 (0.23/day)
Minneapolis, Mn
Processor i7-4960HQ
Memory 16Gb
Mussels
58,413 (7.89/day)
Oystralia
Sweet, im glad to hear it. Does anyone know if you can still rotate monitors when using eyefinity? I have not seen anything about that either.
since they all need the same resolution, they'd all have to have the same orientation
1,675 (0.23/day)
Minneapolis, Mn
Processor i7-4960HQ
Memory 16Gb
Yes but they can all be rotated 90 degrees, which you can imagine results in a completely different aspect ratio. The Triple Head 2 Go could do this, thats the only reason I ask.
4,267 (0.67/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
That support came with the 9.12 Hotfix drivers.
Haven't seen anyone here post their experience, but over at WidescreenGamingForum and HardOCP some people have posted that it is working. No benches yet.
10 (0.00/day)
If that's the case, thats awesome. I wonder if it's possible to use the DVI or HDMI on the
2nd or 3rd video card? or is it not physically possible..
1,675 (0.23/day)
Minneapolis, Mn
Processor i7-4960HQ
Memory 16Gb
Rotating monitor support?
4,267 (0.67/day)
Sanford, FL, USA
Case Lian Li PC-Q25
bryantalpinerunner
2 (0.00/day)
Please Help!! Almost Got It!!!
PLEASE HELP!!! I bought the EFX version of ATIs 5670 Card. As you know it had DVI HDMI and Displayport, so without the active adapter i couldnt have all 3 monitors simotaeously. I found Saphires version of the same 5670 card ony difference is it had DVI HDMI and VGA! i thought i found a loophole and wouldnt need the active adapter. After installing the card and the driver it came with, im still have the same issue requiring me to disable one of my monitors to use the 3rd one! NOW IM REALLY UPSET! If anyone has any solution or explanation for this i would really appretiate it!! Thanks in advance - Bryant
Mussels
58,413 (7.89/day)
Oystralia
the models with VGA dont support eyefinity - only two screens will work.
bryantalpinerunner
2 (0.00/day)
Thanks for the info i knew it was too good to be true. Could anyone suggest the cheapest place to get the active display port adapter thats been confirmed to work?
