scary reviews say that an external power supply can damage a computer
11 (0.01/day)
Processor 8th Generation IntelR Core i7-8700 processor (12MB Cache, up to 4.6 GHz)
Memory 16GB Dual Channel DDR4 at 2666MHz (2X8GB) Dual Storage (3.5' 1TB HDD+ M.2 128GB SSD)
Video Card(s) GEFORCE GTX 1650 Super
Display(s) hooked to a 4K television
Audio Device(s) speakers of 4KTV
Is it really possible for an external power supply to damage a computer? No matter how good the reviews, Amazon always has some bad ones for every single power supply there is claiming it fried their computer. How would that even be possible?
I bought EVGA - W3 Series 450W 80 Plus Power Supply White from Bestbuy and it was dead on arrival. I then read others had the same problem with that.
I then returned it and ordered a different one from Amazon but it had female connectors instead of male so wouldn't plug into the 6 pin slot of my new graphics board so have to return it.
Anyway, do power supplies honestly have a chance of damaging or destroying a computer or any of its components?
Can anyone suggest a cheap one they have used without problems? Geforce GTX 1650 Super is the graphics board I have.
419 (0.21/day)
Processor R5 5600X
Memory 32 GB 3600 MT/s CL16
Video Card(s) Sapphire Vega 64
Storage 2x 500 GB SSD, 2x 3 TB HDD
Case Phanteks P300A
Software Manjaro Linux, W10 if I have to
What do you mean external? That seems like a normal PSU to me, that goes in the system.
13,666 (2.02/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Don't believe everything that you read on the Internet. And since you didn't provide a link to any of these "scary reviews", or even a brand and model number for those supplies, I sure don't believe what I am reading here!
As far as your female connectors vs male, that makes no sense. I suspect you were looking at the the wrong cable. But since you again told us nothing about this "different one from Amazon" supply, we have nothing to go on.
As far a as suggesting a supply, how about filling out your System Specs then we can go from there?
11 (0.01/day)
Low quality post by R0H1T
Low quality post by rtwjunkie
rtwjunkie
PC Gaming Enthusiast
14,027 (2.32/day)
Louisiana
Processor Core i9-9900k
I can’t tell if the OP is actually this confused or if we are being trolled.
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
It's possible, a bad power supply can harm your hardware. If you want some suggestions for a power supply ask and state what country and your specs
(He's confused)
the54thvoid
Super Intoxicated Moderator
13,284 (2.40/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
https://www.amazon.com/gp/product/B08CXVKP3M/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 This was the other one I got. It has two 6 pin connections, and neither would fit in the six pins of my graphics board. External power sources are outside the computer, and just run the relevant cables into the computer to hook to things. I guess you could fit them inside a computer if you actually had room for them.
Highly improbable. I recommend you start providing pics of the problems because what you're suggesting isn't possible. The 6+2 pin connectors supplied with that PSU are definitely for GPU power. You use the 6 pin part and leave the 2 spare hanging off.
11 (0.01/day)
I already boxed it back up to return it. It had CPU written on all the cables though. And it was just 6 pins, not 6+2. Every single power supply at Amazon, I click the one star reviews, and they clami it damaged their computer. Perhaps people who shove things into their computers have them overheating or something. I had one of these over 20 years ago for an older computer, but it doesn't have the 6 connection(a row of three over another row of 3) but just six in a row and other connections. Can I use a converter with it?
Frick
Fishfaced Nincompoop
19,819 (2.86/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Keyboard Dell SK3205
In short, don't trust user reviews, especially for PSU's. The only thing they can tell is if the unit was DOA, and nothing beyond that. "Fried their computer" I would take with massive amounts of salt unless hard proof. But yeah, it's power electronics, meaning if things go bad enough bad things happen. This is exceedingly rare in with modern PSU's though, at least when it comes to visible damage. The damage that you don't see is caused by ripple and you can't find that without serious equipment.
Could happen to anything, but that PSU is not very good anyway. It works though, but it might not be very suitable for modern GPUs (if it's group regulated, which I assume it is).
Uh. Ok. What? No. I don't believe this is accurate.
Sure. But as said, it's so uncommon as to be unheard of.
A power supply? In your case I'd go with ... like a Corsair CX or somthing. It'll just work and it'll save you trouble. There are better units out there and probably for a better place but I don't know where a good place to find them in the US are these days and Amazon is a nightmare so...
Don't read those reviews. Don't buy bargain bin units. It's as simple as that.
11 (0.01/day)
If not male or female, what do you call it? The thing would not fit. Since it said CPU on it, is there a different connection end for CPU than for graphics boards?
7,668 (1.77/day)
Why don't you post pics of the cables you're having issues with? The PSU linked seems decent enough. Before returning it see if this can be solved over here.
461 (0.21/day)
Western NY, USA
Processor AMD Ryzen 7 3700x
Cooling Scythe Ninja 5
Memory G.Skill Ripjaws V 16GB (2 x 8GB) (F4-3600C16D-16GVKC) @ 3733 MHz 16-19-19-19-36-56
Video Card(s) MSI RTX 2060 Super Armor OC 8GB
Storage 1x Samsung 970 EVO 500GB / 3x Crucial MX500 / 4 HDDs
Display(s) Dell 23" LCD S2316M
Case Rosewill Rise Glow
Power Supply CORSAIR RM650
Mouse Cooler Master MS120
Keyboard Cooler Master MS120
11 (0.01/day)
Thank you. I bought that one just now.
Low quality post by FinneousPJ
419 (0.21/day)
Processor R5 5600X
Case Phanteks P300A
461 (0.21/day)
Western NY, USA
The PCI-E cable (6pin + 2 Pin) is for the Grahics Card and the CPU cable (4 pin + 4 Pin) is for the CPU power connection on your MB (usually located to the left of the CPU socket)
14,304 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Think about this, those one star reviews are more a reflection of the installers I.Q.
And YOU'RE reading them!
rtwjunkie
14,027 (2.32/day)
Louisiana
I’m glad you selected one. Hopefully this will work out. Please though, in the future if there is one component in your system that must be quality, please make it the PSU. I’m not saying overly pay for it, but don’t try to go cheap.
You can save that description for some other components if you really have to. Think of the PSU as the “heart”, providing a stable supply of life to the entire system.
1,349 (0.22/day)
Milwaukee, Wisconsin, USA
Processor i7-3770K
Motherboard Biostar Hi-Fi Z77
Cooling Swiftech H20 (w/Custom External Rad Enclosure)
Memory 16GB DDR3-2400Mhz
Video Card(s) Alienware GTX 1070
Storage 1TB Samsung 850 EVO
Display(s) 32" LG 1440p
Case Cooler Master 690 (w/Mods)
Audio Device(s) Creative X-Fi Titanium
Power Supply Corsair 750-TX
Mouse Logitech G5
Keyboard G. Skill Mechanical
Software Windows 10 (X64)
One thing that you have to keep in mind when reading reviews is that only a small percentage of people actually know what they are doing, when it comes to computer hardware.
290 (0.08/day)
Singapore
System Name Utter Garbage
Processor 9800X3D
Motherboard B650 Aorus Elite AX
Cooling ID Cooling SE214XT
Memory Teamgroup 2x16GB DDR5 6000C30
Video Card(s) Zotac RTX 3070
Storage Hynix 1TB P31
Display(s) AOC Agon 1440p240 QD-OLED
Case Silverstone Fara R1 Pro V2
Audio Device(s) iLoud Precision 6, Topping D50 III
Power Supply Seasonic G 650W
Most people grossly underestimate the technical skills required to build a PC, let alone troubleshoot and picking the best value parts.
Low quality post by Caring1
14,304 (3.80/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Were you one of those children that struggled with Lego blocks?
18,113 (2.45/day)
Now now, that's mean, there's Duplo for those kids...
And if that fails, Playmobile...
On topic, yes, it's possible to damage your computer with a power supply, if you plug things in wrong.
I have to admit that I did it once, but that was only because the modular cables could be put in the wrong holes on the PSU and I wasn't paying attention.
Cost me a couple of hard drive :(
However, that was not really the power supplies fault, it just did its job and delivered powered when turned on.
This should no longer be an issue on most moduler PSUs, as they've made sure that issue can't happen on more modern units.
Even further back, there were PSUs that were rated at a higher capacity than they could deliver, so at 100% load, they would fail and could fry your components.
Shouldn't be an issue today, but don't buy junk brands like the one you linked to at Amazon.
You really don't want a cheap power supply.
144 (0.02/day)
System Name HTPC
Processor Ryzen 3600
Motherboard ASRock X570M Pro4
Cooling Aquacomputer Cuplex Kryros Delrin + Aquaduct 720XT
Memory Mushkin Ridgeback DDR4-3200
Video Card(s) Gigabyte Waterforce WB RTX 2080Ti
Storage Crucial M1 500GB
Display(s) Philips 55POS9002/12 OLED TV
Case Silverstone Sugo SG11
Audio Device(s) FiiO D03k -> Pioneer A676 -> KEF iQ7
Power Supply Seasonic G550 PCGH Edition
Mouse MX Master
Keyboard Corsair K63 wireless Lapboard
If there was no Poka Yoke
/Keying on the cables I would actually blame the PSU designer for that one. On a good PSU that error is technically not possible.
2,715 (0.57/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
This sure happened to me. I have built many many mining computers some years ago. I just upgraded my nephews desktop to something much better including a B550 motherboard, I fried the motherboard because I didnt put spacers between the motherboard and the case, so the mobo was fried. It was a $200 lesson.
18,113 (2.45/day)
Yeah, it shouldn't have been, but apparently it was. I won't be making that mistake again for sure.
Eh? Why would you use spacers between the motherboard and case? You know that prevents the motherboard from grounding properly, right?
I think something else went wrong in this case, as those spacers haven't been in use for like forever.
