Scythe Releases the Mugen MAX CPU Cooler
OneMoar
There is Always Moar
8,794 (1.65/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
welp. just wanna share my story but hey, they are plenty of aio cooling solution and it might be just some first model was not that good (like everything). So new model now shure are more good.
am i off topic off the scythe mugen releases? x) anyway good stuff scythe ::toast:
and thats all it is just a story your "shop" is most likely some hole in a wall in some war torn nation where reliable shipping and people that actually know what they are doing are a rarity case and point
270 (0.06/day)
Canada
System Name custom
Processor intel i7 9700
Motherboard asrock taichi z370
Cooling EK-AIO 360 D-RGB
Memory 24G Kingston HyperX Fury 2666mhz
Video Card(s) GTX 2080 Ti FE
Storage SSD 960GB crucial + 2 Crucial 500go SSD + 2TO crucial M2
Display(s) BENQ XL2420T
Case Lian-li o11 dynamic der8auer Edition
Audio Device(s) Asus Xonar Essence STX
Power Supply corsair ax1200i
Mouse MX518 legendary edition
Keyboard gigabyte Aivia Osmium
VR HMD PSVR2
Software windows 11
am not/gonna point anyone. Material failure is material failure.
3,529 (0.56/day)
Terra
System Name :)
Processor Intel 13700k
Motherboard Gigabyte z790 UD AC
Memory 64GB GSKILL DDR5
Video Card(s) Gigabyte RTX 4090 Gaming OC
Storage 960GB Optane 905P U.2 SSD + 4TB PCIe4 U.2 SSD
Display(s) Alienware AW3423DW 175Hz QD-OLED + Nixeus 27" IPS 1440p 144Hz
Case Fractal Design Torrent
Audio Device(s) MOTU M4 - JBL 305P MKII w/2x JL Audio 10 Sealed --- X-Fi Titanium HD - Presonus Eris E5 - JBL 4412
Power Supply Silverstone 1000W
Mouse Roccat Kain 122 AIMO
Keyboard KBD67 Lite / Mammoth75
VR HMD Reverb G2 V2
Software Win 11 Pro
Not only do you have to worry about leaks with LC but also pump failures.....
I have PCs that are on 24/7 even when I'm not in front of them.
The last thing I need is to worry about pump failures and the PITA it is to set LC up again.
draining the system..... priming the pump.... checking for leaks..... how to setup the tubing ....
check for buildup....
Air wins hands down as the best "set it and forget it" solution.
41,882 (6.61/day)
ahhhhrgh damn it's a 161mm :D i guess i will have to settle for the Mugen 2 (or something else) my Carbide Spec-01 handle 150mm (manufacturer recommendation ) but i could put a IFX-14 with a TY-147 (160mm) and the side panel was barely closing :) so a 158-159 max should fit, still Scythe cooler are pretty much great
What about Ashura
41,882 (6.61/day)
do they require heatsinks no ... not for up to 1600 at cl9 how ever cl7 or 1866+ kits do get quite warm calling it a cash-flow device just shows how much you don't know
my 32nm samsung sticks get upwards of 50c when running at 1900Mhz @ 1.6v ram temps DO matter as does everything else
imagine mine set to 2133
9,900 (1.85/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
yep, one that minus for air cooler is the size is big and bigger, if you want better cooling you need to give it big space
3,529 (0.56/day)
Terra
System Name :)
VR HMD Reverb G2 V2
Software Win 11 Pro
well for water you need space for the Rad....
8,508 (1.86/day)
Ovronnaz, Wallis, Switzerland
Keyboard Endorfy Thock 75% <3/none/touch/virtual
VR HMD Medion Erazer
What about Ashura
if a IFX-14 and a TY-147 barely fit (160mm) and a Mugen Max wouldn't fit at all (161mm) a Ashura (161mm) would not fit either.
according to corsair the max is 150 according to reviews a pass Noctua NH-U12S pass (158) so i have in choice the Mugen 4 (not 2 ... )
funny that's exactly what's hinder me in my Carbide Spec 01 150mm for a Aircooler and single 120mm single thickness rad max , yet i still think i could fit a Seidon 240 without removing the HDD cage like the reviews state. (but the RAM would be touching the rad even if they are LP :roll: )
my G.Skills ARES 2133 who where LP with a HS where barely hot on touch : 2133 could work without HS in a good ventilated case.
well those where CL11 so if yours are CL7 maybe they need one ... bot are they needed? (CL7-9 i mean xD i didn't see a huge improvement between a CL11 and a CL9)
41,882 (6.61/day)
Yeah thats why i got the case i did, talk about huge and a wind tunnel
8,508 (1.86/day)
almost tempted to take a Xpredator Evil White ... but the Spec 01 isnt so small and has a good airflow once you add some fans :D
well i guess it will be Mugen 4 or Seidon 120V/240L
