- Jul 7, 2019
- 1,034 (0.47/day)
This looks like it's intended to be used with those who also have invested in Custom Cabling, where both colored extensions and colored full-length cables exist and can easily work with both the short cables and direct to the Seasonic power strip.
The idea has merit; but i'd like to see some high-end cases have a "power distribution center" integrated on the back. Like; one just plugs in a full 12V PSU to the integrated center, then the center has all the ports for plugging in the necessary cables to whatever needs it; reducing some of the cable clutter and allowing use of shorter extension cables. Or failing that, a clean pass-through block, where one just plugs the PSU to the appropriate ports, and then on the motherboard side just plug in whatever extensions or custom cables is necessary to power what's on that side. Sort of like one or two of the custom Origin PCs that integrated the power distribution block in the wall separating the cable side from the motherboard side.
