Shadow Of The Tomb Raider - CPU Performance and general game benchmark discussions
416 (0.25/day)
Minbar
System Name Da Bisst
Processor Ryzen 5800X
Motherboard GigabyteB550 AORUS PRO
Cooling 2x280mm + 1x120 radiators, 4xArctic P14 PWM, 2xNoctua P12, TechN CPU, Alphacool Eisblock Auror GPU
Memory Corsair Vengeance RGB 32 GB DDR4 3800 MHz C16 tuned
Video Card(s) AMD PowerColor 6800XT
Storage Samsung 970 Evo Plus 512GB
Display(s) BenQ EX3501R
Case SilentiumPC Signum SG7V EVO TG ARGB
Power Supply ChiefTec Proton Series 1000W (BDF-1000C)
Mouse Mionix Castor
Hello World!
Since Shadow Of The Tomb Raider is a particularly CPU intensive game, or better said, CPU performance has a major impact on FPS, it would be interesting to see how our setups handle the game.
For that, lets settle on very specific in-game settings:
Fullscreen
Exclusive Fullscreen
DirectX 12
DLSS OFF
Vsync OFF
Resolution 1920 X 1080
Anti-Aliasing OFF
Graphic Settings - Lowest Profile (please leave it at Lowest without any changes for the purpose of this test)
We shall gather and centralize the scores once a month, CPU and GPU, and try to find a correlation between them.
Here is the first one
:peace:
1,571 (0.87/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
5600X@4.8GHz 4000cl16 tweaked ram :) I set exclusive fullscreen but it keeps resetting :/
416 (0.25/day)
Minbar
Mouse Mionix Castor
Speaking of CPU centric benchmarks in this game, I noticed that Resizable Bar on my system, 5800X and RX 6800XT, is at best not giving any performance benefits, but actually on average a super slight reduction in FPS, so either same results, but out of a run of 5 an average of minus 2 FPS with Resizable Bar, which could be run to run variance, but still is a minute reduction.
There sometimes is some wonkiness on changing settings ingame, as in some settings needing a full game restart to correctly apply. Noticed it when switching between Lowest and Highest, would get the same score with Highest as with Lowest which is only possible if setting did not really apply :)
1,537 (1.10/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
Here's mine, with 4.5 on all cores. IF and RAM running 1866 at 16-18-18-38-58 (secondary timings untouched). Using the demo, can somebody compare their results with the full version?
416 (0.25/day)
Minbar
Mouse Mionix Castor
Those are actually quit good CPU scores for a 3300X, also keeping in mind this game loves moar cores. I also wonder if there is anyone else with a 3300X that would want to post his results here, we are bombarded to much by last gen CPU's and to few by "older" ones, this type of test brings generations into perspective :)
1,537 (1.10/day)
I've got a couple of older PCs, but they're all running 7 or XP, so obviously no DX12. DX11 would completely skew the results, so here's hoping :)
31 (0.02/day)
UK
System Name Cube
Processor R5 3600 @ 4.325
Motherboard MSI B450m Mortar Max
Cooling Arctic Freezer 34 esports duo
Memory 4x8gb Ballistix @ 3733c15
Video Card(s) XFX 6700 XT Merc 319 Black
Storage WD SN750 500gb, Samsung 850 Evo 500gb
Display(s) Gigabyte M27Q
Case Thermaltake Core V21
Audio Device(s) Edifier R1700BT
Power Supply Corsair SF600 Platinum
Mouse Mionix NAOS 7000
Deleted my old post because I forgot to turn off AA
4.525 all core, 3666 ram 16-16-19-16-36 plus a few secondary timings, +150ish gpu core
416 (0.25/day)
Minbar
Mouse Mionix Castor
cRs
9 (0.00/day)
Germany/Romania
System Name Nzxt Diffuser
Processor FX-8350
Motherboard Asus M5A99X Evo
Cooling Noctua NH-D14
Memory 8GB G.Skill RipjawsX DDR3-1600 DIMM CL9 Dual Kit
Video Card(s) CrossFireX Sapphire HD7850 2GB
Storage Hitachi 1TB/32MB SATA-II
Display(s) Acer G225HQ 21.5"
Case NZXT Phantom Big Tower White
Power Supply Cooler Master GX550W D3
Software Windows 7 x64
all stock 16gb 3600mhz cl 18
416 (0.25/day)
Minbar
Mouse Mionix Castor
Testing some new RAM (and the latest GPU drivers)
5800x, 95w Eco Mode, 32GB (4x8) 3200 14-14-14-34
Interesting, I was playing with this thought in my head to lower the RAM frequency (from 3733 currently) and also lower the timings as much as possible, this game really loves ram with fast timings and low latencies :)
Deleted member 202104
I've been trying to decide which kit I wanted to run, but I think test made the decision. These are standard XMP timings with GDM disabled. I'd like to see what I could get the timings to @ 3600.
Also just put the CPU back to stock (PBO Disabled and standard 105w)
416 (0.25/day)
Minbar
Mouse Mionix Castor
I seem to get better CPU results in SOTR with an all core of 4.7ghz on the 5800X vs PBO to 5ghz boost for some reason, but its very close. One thing that I am not really clear about, I get pretty crappy CPU Render scores for the settings I run, and that bugs me, have to find out why :D
304 vs your 417, that with 3733 dual rank 16CL tuned timings...
Yeah, that doesn't make any sense. That's a really large difference for such similar hardware. Has me curious too. :wtf:
416 (0.25/day)
Minbar
Mouse Mionix Castor
This is a weird game engine, so, played a bit with RAM timings, especially Trfc which I think was a bit too tight, loosened it, tested again:
Initial result on the left, todays result on the right. What is really weird, I got a 40 fps increase in Average CPU Render, but a 40 fps decrease in GPU score, with the final result of the same overall FPS :roll:
Granted, its on different drivers, and there seems to be a slight performance benefit for the previous AMD one 21.3.1, but still, this is odd :laugh:
16,671 (4.68/day)
yeah the 21.3.1 AMD drivers are insanely good with FPS boost... I'm considering never upgrading them from that. AMD seemed to nail something right on them, and I doubt they even know what they did.
416 (0.25/day)
Minbar
Mouse Mionix Castor
Me too, even though I like the Vivid Gaming thing in the last driver, 21.3.1 seems better for sustained performance for some reason. Really good driver.
16,671 (4.68/day)
the vivid thing is terrible. look at techpowerup after you turn on vivid. the gray turns to pink... that's not right...
just calibrate your monitor better to begin with and you don't need vivid.
416 (0.25/day)
Minbar
Mouse Mionix Castor
Might be wrong for others, but on mine it really looks better, does not really change colors, just makes things a bit more ... "vivid" :D . And I am speaking only about how games look, not general windows.
I am trying some more RAM timings to see how the CPU stats in SOTR change, its interesting in a way, though sort of unpredictable.
76 (0.02/day)
MADAGASCAR, Antananarivo
System Name Righolder
Processor intel i5-4590
Motherboard Crap Mobo
Memory Gskill Trident-X 2133mhz 9-11-10-28-1N @1333
Video Card(s) r9 fury nitro 1020/500
Display(s) Philips 227ELH
Case Deepcool Dukase
Power Supply Raidmax RX-1200AE
Software Win 10 64bit
416 (0.25/day)
Minbar
Mouse Mionix Castor
16,671 (4.68/day)
how are you getting so much of a higher score than me?
W1zzard
Administrator
27,253 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
How's the difference between the benchmark and actual gameplay?
416 (0.25/day)
Minbar
Mouse Mionix Castor
Couple of reasons, first being the 6800XT I have vs your 6800, my 6800XT is running at 2.7Ghz with over stock power limits, 400w basically, water cooled, and the second would be, and I know that for sure since I had the 5600X before the 5800X, that I run a 5800X, and this game loooooooooooooves extra cores :)
Was speaking to a mate that has the same setup I have, except a 5900X, that one gets an extra 10-15 FPS at 1080, and the 5950X gets another extra 10 on top of that. Its weird that each 2 extra cores would give extra FPS.
If you mean in regards to FPS only, I would not know since I play it at 3440X1440, I only test it at 1080 in this thread to see the CPU impact on FPS.
I can speak about the difference at 3440x1440, the benchmark gives a bit higher numbers there than normal gameplay, but its rather fluctuating depending on area, so would assume the same is true for 1080.
