Shared GPU memory issue
strazbk
6 (0.00/day)
Hello everybody!
I have an issue with my shared GPU memory.
Recently I installed new GPU 3060 rtx (12GB). After completing installation I noticed that my normal RAM reduced from 12 to 8 GB. CPU-Z shows all 6 RAM modules are working properly (6 modules installed, 2GB each) In adapter settings I can see:
GPU memory: 16GB
Dedicated GPU memory: 12GB
Shared GPU memory: 4GB
Can I reduce shared memory to 0?
Motherboard MSI x-58 pro-e
Thanks in advance!
18,584 (2.64/day)
System Name AlderLake
Your system will probably be a massive bottleneck for this new GPU...
strazbk
6 (0.00/day)
I am planning to upgrade my PC step by step, 1st was gpu, 2nd step - everything else )
Toothless
Tech, Games, and TPU!
9,804 (2.43/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Reseat your ram.
2,416 (1.17/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
wow isnt the x58 like 15 years old platform...
surprised it can still install...
631 (0.55/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
Shared GPU memory is not deducted from your system RAM, it is just potentially available to your GPU if it runs out of VRAM. My system have a GPU with 12GB VRAM plus 16GB shared GPU memory. I still have the total 32GB system RAM available.
So, if you lost 4GB RAM there should be another cause.
Toothless
9,804 (2.43/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
X58 overclocked can still hold its own today. Had an x5675 do 4.8ghz all core and ran everything just fine with stronger cards.
60 (0.04/day)
If you see 12 GB RAM in OS (6 x 2 GB) then everything is OK. If not,, reseat memory modules. Dedicated/shared is automatically managed and it is not needed to care about it. OS will take max available when needed.
2,416 (1.17/day)
LV-426
System Name Custom
Processor i9 9900k
Mouse Logitech G403
Oh I don’t doubt the cpu and platform can perform, just things like compatibility uefi etc those things
strazbk
6 (0.00/day)
Any idea what can cause it? As I mentioned, cpu-z can see all 6 modules of ram, also in bios settings I can see all 6 modules
By reseating modules you mean swapping them? I already did it many times, I tried like 10 different combinations - no success. However in one combination I had only 4 total ram available!
